Installing crash bars on a 2016 R1200RT - BMW Luxury Touring Community
 2Likes
  • 1 Post By N00bie RT Gawd
  • 1 Post By Lee4BMW
post #1 of 16 Old Sep 5th, 2019, 5:11 pm Thread Starter
Are "head savers" or "valve cover protectors" difficult to install?
I only want them for highway pegs.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
wichitagreg is offline
post #2 of 16 Old Sep 5th, 2019, 6:16 pm
N00bie RT Gawd's Avatar
Re: Installing crash bars on a 2016 R1200RT
Generally, no. However, each kit is different; my Ilium Works engine crash bars needed some bodywork removal, but other than needing some extensions and such, it wasn't difficult to install.
wichitagreg likes this.
Those who say that it can't be done shouldn't interrupt those who are doing it.
Democrats are to America what mold is to bread.
N00bie RT Gawd is offline
post #3 of 16 Old Sep 5th, 2019, 10:06 pm
Skibumwi's Avatar
The Ztechnik bars were pretty easy to install on my 2016 RTW, look great (IMHO), and have a special tab for mounting an aux light.
I've mounted the Ilium Works Adjustable Highway pegs on the lowest horizontal bar on the Ztechniks and they work great, when the pegs are folded it looks like it really belongs on the motorcycle. They do not come cheap but the design, fit, function, workmanship really shows.
I will comment that this setup has the pegs way out past the heads. I"m not certain I'm flexible enough to use both pegs at once.
I'd post a picture but it's too much of a PIA on this site (IMNSHO)
Just my $0.02
Ski
2016 BMW R1200RT in Ebony Metallic
1981 BMW R100RT in Forest Green
Honda 550 Four
Suzuki 250
Honda 175
Skibumwi is offline
post #4 of 16 Old Sep 5th, 2019, 10:21 pm
Just my $0.02
Ski
No picture means it didn't happen.
post #5 of 16 Old Sep 5th, 2019, 11:43 pm
EzyMount's Avatar
Can yu see mine ?
Jim Lawson 2016 R1200RT
Retired to NC !
EzyMount is offline
post #6 of 16 Old Sep 6th, 2019, 8:11 am
Originally Posted by EzyMount View Post
Can yu see mine ?
You should fix the drip loop on your lights, LOL
post #7 of 16 Old Sep 6th, 2019, 8:20 am
hopz's Avatar
My '14's head protectors were easy to install...
I turned the photo upside down so you could see it better...
2014 R1200RT WC
As Woody Guthrie says, Left wing, right wing, chicken wing.I keep my mind open. Whatever you believe, its all a mystery in the end.
hopz is offline
post #8 of 16 Old Sep 6th, 2019, 9:04 am
Booger man's Avatar
Got Ilium Works on my 18 RT along with hi-way pegs. Pretty e-z to install. Took about an hour.
Booger man is offline
post #9 of 16 Old Sep 6th, 2019, 1:42 pm
Lee4BMW's Avatar
I have the same bars with pegs attached...
2016 R1200RT Premium, Platinum Bronze
Riding a motorcycle means never having to smell your own farts.
Lee4BMW is offline
post #10 of 16 Old Sep 6th, 2019, 5:32 pm Thread Starter
Pretty cool, thanks for posting. Where did you get those pegs?
post #11 of 16 Old Sep 6th, 2019, 6:50 pm
Ski
I have the Ztechnik bars on a 2017 and really like them until I changed the spark plugs. It was a pain to get the spark plug covers off with the bars.
Any one else have the same problem or am I mechanically inept? It looks like the bars will have to come off to do a valve check.
2017 R1200RT
prz42 is offline
post #12 of 16 Old Sep 7th, 2019, 9:46 pm
Lee4BMW's Avatar
I got them from Revzilla. I don’t remember the actual product name. Also be aware that those bars are 1 inch in diameter, not 7/8” like the ad might state. I made them aware of that mistake a while ago but I do not know if they have fixed it or not.
Lee4BMW is offline
post #13 of 16 Old Sep 8th, 2019, 9:48 pm
The bars that you have linked are pretty easy to install. You will need a small jack to place under the engine because you will be replacing an engine mounting bolt with a longer one. The jack is to take the load off the bolt.
Kenny M. is offline
post #14 of 16 Old Sep 8th, 2019, 11:19 pm
McWideglide's Avatar
Ilium bars front and rear on my 16RT. Install was quite easy. I did not rush and it took about 4 hours. I am sure it could be done in half the time. I am cautious.
McWideglide
Jeff M.
2002 Harley Dyna Wideglide
2016 BMW R1200RT
2009 BMW K1300GT sold
1976 BMW R90/6 sold
1967 BSA 441 Victor sold
McWideglide is offline
post #15 of 16 Old Sep 11th, 2019, 4:23 pm
I’m looking to buy some heed crash bars, has anyone any experience with these and fitment?
Guardian Angel is offline
post #16 of 16 Old Sep 11th, 2019, 4:42 pm Thread Starter
I got these installed a couple of days ago, very easy. Perfect fit, only two places do they touch the bike, and no adjustment was needed.
You will need a helper to hold the wrench on the off-side so you can take the motor mount rod nut loose, and then again to tighten the new one. My nut was very tight, I mean very very tight. Had blue locktight on it, but was difficult as if it was red.
Also a jack to lift the motor slightly SLIGHTLY, to take the load off the motor mount rod as you use the new one to drift out the old one. A good torque wrench as the lower four bolts go into aluminum and you do not want to over tighten them.
One the bike, they are unobtrusive which I like, and am waiting for some highway pegs to complete this task.
I got them for highway peg mounting, not for crash damage avoidance, but if it helps, it helps.
Once I get the highway pegs I will post photos to close out this thread.
