Changing Coolant Question - BMW Luxury Touring Community
 2Likes
  • 1 Post By wethead
  • 1 Post By Voyager
post #1 of 12 Old Yesterday, 1:27 pm Thread Starter
wethead's Avatar
Does anyone know a video showing how to change the coolant on a late wethead RT?
Thanks, pics, instructions...anything will be appreciated
wethead is offline
post #2 of 12 Old Yesterday, 2:38 pm
TwoWheels's Avatar
Re: Changing Coolant Question
This might get you going in the right direction.
https://xladv.com/topic/499-r1200gs-...lant-exchange/
Doug L.
2014 R1200RT. 57,000+
Previous...
2000 Harley Davidson Dyna Convertible. 101K miles (Gone)
1982 Honda V45 Magna. 45K miles (Gone)
TwoWheels is offline
post #3 of 12 Old Yesterday, 6:57 pm
N00bie RT Gawd's Avatar
Straight from the BMW service DVD...
Those who say that it can't be done shouldn't interrupt those who are doing it.
Democrats are to America what mold is to bread.
N00bie RT Gawd is offline
post #4 of 12 Old Yesterday, 7:19 pm Thread Starter
wethead's Avatar
Much obliged NOObie!!!!
N00bie RT Gawd likes this.
wethead is offline
post #5 of 12 Old Yesterday, 8:34 pm
beech's Avatar
Never gave it any thought that vacuum would be needed. Interesting.
Beech
I change your tires $40, you buy them on the web.
beech is offline
post #6 of 12 Old Yesterday, 9:53 pm
It's a BMW; I'm surprised that it doesn't require even more things!
Is that vacuum-thingy something available at some place like HF?
post #7 of 12 Old Today, 7:01 am
I was going to recommend a Clymer manual, but I donít see one listed for the RTs post 2009. That is a bummer as their manuals are generally pretty good.
post #8 of 12 Old Today, 7:15 am
This is a pretty good overall process, but I do disagree with a couple of things.
1. Many engines will create enough vacuum to drain the overflow tank along with the engine if you leave the radiator cap in place when you remove the drain plug(s). This saves having to suck the old coolant out of the coolant recovery tank. Not sure if the RT is one of these engines, but I would try that first. If this doesnít happen, I would be a little suspicious of the radiator cap and generally not much vacuum is required to open the valve that letís coolant be pulled from the recovery tank back into the radiator.
2. I donít like the recommendation to run the engine with the radiator cap off. The main reason is that many engines have localized hot spots, generally in the head, where the coolant can locally boil even if the overall coolant temp is below 212 F at ambient pressure. Even lower temp if you are above sea level. Having the system pressurized raises the boiling point of the water and lessens the chance of nucleate boiling. And the hotter water will help facilitate a better flush.
3. The article suggests the cooling fans come on before the thermostat opens. If this happens, you have either a bad thermostat or a bad temp sensor for the cooling fans. The t-stat should open 20 - 40 degrees before the fans come on.
Given that the water level will drop the first thermal cycle or two, I do not let my bikes idle too long after the initial fill. I usually feel the radiator hose and as soon as it gets warm indicating that the t-stat has opened, I shut the bike off, let it cool, and then remove the cap and top up the water. Usually, only a cycle or two is required to get it full enough that it will pull makeup water from the coolant recovery tank, which you remembered to fill with distilled water before starting the flush, right?
post #9 of 12 Old Today, 10:58 am
beech's Avatar
Here are some vacuum generating systems. You need a decent air compressor to power these. Get one with a gauge and many adapters.
https://www.amazon.com/s?k=vacuum+ra...b_sb_ss_i_1_20
I use the OEM factory unit on The new generation K bikes, they require vacuum filling. There are other methods but I have not tried them nor recommend them. All these suggested techniques other than the factory manual need some thought and possible modification. If you do go by the OEM manual you will be safe. Many of their procedures seem like overkill and some are but if followed carefully you can keep out of trouble.
Beech
beech is offline
post #10 of 12 Old Today, 11:10 am
It is unfortunate that some engines are poorly designed and require vacuum filling. Sort of like the FDs that were manufactured without oil drain plugs. A well-designed engine will not contain pockets in the castings that will contain air when the system is filled at a reasonable rate.
John Brock likes this.
post #11 of 12 Old Today, 12:55 pm
Stooie's Avatar
Originally Posted by Voyager View Post
I was going to recommend a Clymer manual, but I don’t see one listed for the RTs post 2009. That is a bummer as their manuals are generally pretty good.
Voyager is right; Clymer doesn't seem to have a manual for the later models. Fortunately Haynes does have one for the wetheads. I have it; it seems completely adequate for the routine stuff.
https://www.amazon.com/Liquid-cooled...s=books&sr=1-1
Bob Stewart
Salem, Oregon
2018 R1200RT
Stooie is online now
post #12 of 12 Old Today, 2:33 pm
I have some Haynes manuals for some of my long gone machines and they were fully adequate for most tasks. I havenít had one of late though so I hesitated to mention that as my experience with Haynes is 20+ years old.
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
Beemer Dood, davebullock
