R1200RT (2011) Hose Clamps - BMW Luxury Touring Community
post #1 of 6 Old Jul 9th, 2019, 4:18 pm Thread Starter
I decided to replace the hose clamps after doing some maintenance recently that involved removing the throttle bodies and air hoses. I just ordered 2 each of 11617723636, 13717680687 & 13717728769, and I I'd like to know the correct tool to install these. I'm sure it's at least possible with just needle nose pliers, but I'd like to find the right tool for the job.
It seems like there's a tool for several different kind of hose clamps, all with names that could be easily confused with one another. "Muffler Clamp" doesn't seem to be enough information to distinguish these particular clamps from others.
Any idea what specific tool is called for to install and/or remove these?
Name:	Annotation 2019-07-09 161457.png
veteranbicycle is offline
post #2 of 6 Old Jul 9th, 2019, 7:24 pm
Dann323's Avatar
Re: R1200RT (2011) Hose Clamps
For the throttle bodies clamps, you will need Oetiker clamp pliers
These are the ones I got
https://www.ebay.com/itm/Clamp-Plier...AAAOSwmRFaT9C4
YMMV
Name:	Oetiker pliers.jpg
Daniel
If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
IBA # 56396
MOA # 171966
R1200RT 2007
Dann323 is offline
post #3 of 6 Old Jul 10th, 2019, 8:19 am Thread Starter
Thumbs up Re: R1200RT (2011) Hose Clamps
YMMV
Thanks! For the record, it looks like this is the BMW OEM clamp: https://www.oetiker.com/en/Products/...e-Clamp-PG-168 Or do they just look a lot like them?
According to Oetiker, they're reusable! I didn't use the right tool to remove them so I'm considering them trash, and since they're so cheap I'm just replacing them anyway.
post #4 of 6 Old Jul 10th, 2019, 8:43 am Thread Starter
I think I found the tool on Amazon: https://www.amazon.com/Lisle-30500-B.../dp/B0002SREB8
Lisle 30500 https://www.lislecorp.com/specialty-...t-clamp-pliers
post #5 of 6 Old Jul 10th, 2019, 1:39 pm
Dann323's Avatar
I did reuse mine
Daniel
IBA # 56396
MOA # 171966
R1200RT 2007
Dann323 is offline
post #6 of 6 Old Jul 12th, 2019, 10:16 pm Thread Starter
I did reuse mine
I knew 0% about these until asking, and ordered the OEM clamps just in case.
I can report that I received the Lisle pliers yesterday afternoon and they worked 100%. I was even able to reuse the original clamps, so the new ones will go in the toolbox as spares until the need arises.
I recommend Lisle 30500 pliers without reservation. The cheapest option anywhere and MADE IN USA!
The only caveat is they don't have a double hinge like the Oetiker tool so they have to open fully to contact both catches if they're needed to draw the clamp closed. It was a little awkward until they were close to closing.
