Battery cover/tupperware on the wethead - BMW Luxury Touring Community
 3Likes
  • 2 Post By oldspice
  • 1 Post By PadG
post #1 of 14 Old Jun 3rd, 2019, 11:45 pm Thread Starter
oldspice's Avatar
I noticed on my wethead that the foremost torx screw on the piece of tupperware that covers the battery isn't snug. The screw goes all the way into the clip, but it doesn't pull the panel snug - there's a bit of space left so the panel wiggles.. It's almost as if there's a nylon spacer missing or something like that. Anyone else, or am I just lucky?
"Looks like I picked the wrong week to stop sniffing glue..."
2015 BMW R1200RT - "Artoo"
2012 BMW R1200RT - "Arthur", RIP
1985 Ford Escort L (for Luxury) - Ol' Blue - gone, but not forgotten
MSF RiderCoach
BMW MOA 175432
oldspice is offline
post #2 of 14 Old Jun 4th, 2019, 12:08 am
Dsmith1200's Avatar
Re: Battery cover/tupperware on the wethead
Maybe a long shouldered screw where a short shouldered one should be?
2015 R1200RT
Dsmith1200 is offline
post #3 of 14 Old Jun 4th, 2019, 12:48 am Thread Starter
oldspice's Avatar
You know, that could be it. Looking at the parts fiche, I see the upper screw and lower screw are different. There's a chance I just reversed them when I put the panel back on - I'll have to check that tomorrow. Thanks for the tip!
MSF RiderCoach
BMW MOA 175432
oldspice is offline
post #4 of 14 Old Jun 4th, 2019, 8:37 am
PadG's Avatar
Tom, I am sure that is the problem. I just use the logic that long shoulder screws goes in to hold multiple panels, and the short shoulder ones are used to hold single panel.
BTW, there is a little "trick" on one of the panel that is not mentioned anywhere in any of the official documents. It has to do with the big gray right-hand side panel. This one panel is held be two torx screws and a plastic pin (part of the panel) that goes into a rubber grommet on the frame. Chances are that when you put this panel back, and tightened the 2 screws, you will find that the pin had slipped easily out of the rubber grommet and leave the panel a little loose and flopping, held on by just the 2 screws. Here's the trick. In putting that panel back, I usually position the panel in place and insert the pin into the grommet first. Then I pull the panel back gently to see if the pin will slip out of the grommet without resistance. If that happens, then I would rotate the grommet some amount, and try again. When properly positioned, the rubber grommet should grip the plastic pin, not very hard, but enough to keep it secured. You can see the reason why you need to position the grommet to the pin properly, when you look at the two parts. The pin have a couple of small ridges on it's side, and the rubber grommet have 2 slits through its side. The rubber grommet is quite loose in its metal bracket, and will turn quite easily, whether you want it to or not. So, if the ridges on the pin lines up with the slits in the grommet, there will be no holding at all!
Pad. Gajajiva
Solon, OH, USA
2007 R1200RT (Sold!)
Once Upon a Time........
1963 Norton Dominator 650 SS
1960 Triumph Thunderbird (6T)
1952 Triumph Thunderbird (6T)
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #5 of 14 Old Jun 4th, 2019, 9:00 am
SpinDog's Avatar
When the dealership has worked on my bike they often put the wrong screws in the wrong locations resulting in loose panels.
2014 R1200RT - Quartz blue metallic
2010 Kawasaki VN900
-CT USA-
SpinDog is offline
post #6 of 14 Old Jun 4th, 2019, 9:58 am Thread Starter
oldspice's Avatar
You guys were right - I swapped out the screws. Silly me, thinking that all the tupperware screws were the same, like on my 2012. Of course, I should've known better that Motorrad wouldn't keep things simple on the wethead! Shouldered screws, rubber pins/grommets, tabs, velcro.....
That all said, right as rain now - thanks again, everyone!
PMitchell and wethead like this.
MSF RiderCoach
BMW MOA 175432
oldspice is offline
post #7 of 14 Old Jun 7th, 2019, 3:55 pm
dlong0609's Avatar
I had occasion to remove the body panels on a friend's new R1250RT and was surprised that most of the various size and configuration screws I deal with on my '18 RT have been replaced with binding head screws of uniform length. Go figure.
dlong0609 is offline
post #8 of 14 Old Jun 7th, 2019, 8:59 pm
Does anyone know on the wethead the largest size Yuasa battery?
Something like Battery Yuasa GYZ16H (Better) or YTX14H-BS (Standard)
YTX20CH-BS (Higher Size) ?
It seems like the bike could use more cranking amps. It seems to work great
in neutral but not so good if it is in gear.
2017 R1200RT
prz42 is offline
post #9 of 14 Old Jun 10th, 2019, 6:37 am
bandytales's Avatar
Well that is strange. If you look at the parts fiche for a K52 1250RT the bolts are still all different length shoulders just as they were on the K52 1200RT.
https://www.realoem.com/bmw/enUS/sho...diagId=46_1625
https://www.realoem.com/bmw/enUS/sho...diagId=46_1615
2003 R1150RT & 2017 R1200RT
bandytales is offline
post #10 of 14 Old Jun 13th, 2019, 12:47 am
Cat Herder
tvguy's Avatar
here you go... Just put a GYZ16H in my '16RT. 16H is the highest amp battery for the bike. 14H was the stock battery.
Name:	Screen Shot 2019-06-12 at 9.31.17 PM.png
Tvguy
'16 R1200RT - "Golden Eye"
tvguy is offline
post #11 of 14 Old Jun 13th, 2019, 12:55 am
Cat Herder
tvguy's Avatar
How come you are playing with tupperware and not at the rally??
Tvguy
tvguy is offline
post #12 of 14 Old Jun 13th, 2019, 4:11 pm
Skibumwi's Avatar
And don't forget the stupid plastic washers that they want to charge an arm and a leg for....
Ski
2016 BMW R1200RT in Ebony Metallic
1981 BMW R100RT in Forest Green
Honda 550 Four
Suzuki 250
Honda 175
Skibumwi is offline
post #13 of 14 Old Jun 14th, 2019, 8:41 am
PadG's Avatar
Try this for plastic washers: https://www.mcmaster.com/plastic-washers
Select washers, then M5 for the screw size, and you will have multitude of selections. Quite frankly, when I lose one, I just don't bother to replace it!
NoelCP likes this.
Pad. Gajajiva
Solon, OH, USA
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #14 of 14 Old Jun 14th, 2019, 9:39 am
bandytales's Avatar
+1
