No Start when in Gear 2015 RT - BMW Luxury Touring Community
 1Likes
  • 1 Post By 5336G
post #1 of 3 Old May 22nd, 2019, 6:33 pm Thread Starter
bwoodsom's Avatar
Has anyone had 2014+ RT that will not start without being in neutral. This started happening this spring on my 2015 RT with 60k miles. I suspected the clutch switch but I hooked it up to the GS911 and when I go to real time values I can see the clutch switch activation when I pull in the lever. Also, my cruise works and still disengages with the clutch lever. Am I missing something?
One strange thing I noticed in the GS911. In Real time values there are two clutch switches listed. Clutch switch 1 and clutch switch 2. Any idea what the difference is? I only see clutch switch 2 change.
Thanks!
Bob in New England
bwoodsom is offline
post #2 of 3 Old May 22nd, 2019, 6:52 pm
5336G's Avatar
Re: No Start when in Gear 2015 RT
I had the same issue and it was the following microswitch:
32728537609 SET OF DUAL MICROSWITCHES $86.76 (Max BMW diagram).
Would not start in gear with side stand up or down. I ordered the switch, installed it in a few minutes and the problem was solved. FYI - the part number above is for bikes with cruise control, there is a different part number for those without.
I also know those are generic switches and can be sourced from other places but I wanted to fix it quickly.
The second switch (listed as a dual switch) is for the disabling of the cruise control. The other part number is just a single switch.
Good luck!
beech likes this.
Colorado LEO (Retired)
U.S. Army (Retired)
2014 BMW R1200RT
2015 BMW R1200GS
5336G is offline
post #3 of 3 Old May 23rd, 2019, 1:44 am
GSinNC's Avatar
Yep .... had that same issue on my 2012 GSA and as noted it was just a microswitch. Not expensive at all!
Ed Apelian
'18 R1200GS - Light White
GSinNC is offline
Finally, equipped with proper riding gear Beemer tiger RT Series 2 Feb 11th, 2019 11:36 am
BMW Magazine on Coolant Leak and Noisy Gear Changes R1200RTOwner2B RT Series 12 May 25th, 2015 11:02 pm
Gear shifting points revisited bmwrubbercow K1200LT 20 Jul 10th, 2007 1:34 am
