R1100RT new exhaust question - BMW Luxury Touring Community
post #1 of 6 Old Apr 11th, 2019, 1:53 pm Thread Starter
MarinPhil's Avatar
Thinking of replacing the original existing exhaust from the cat back to the muffler to an aftermarket one that comes with a straight pipe to eliminate the cat altogether. So, besides the nicer growl, without the cat i know the motor will run cooler. Question is will the bike run ok, fueling etc or will i run into problems. O2 sensor? Has anyone gone the route with direct feedback? Thanks
Phil in Marin
2013 K1300S-30 Anniv ED. sold
2006 K1200GT-Blue of course-sold
2005 Ducati 999-the I-talian princess-sold
2004 K1200GT Gen-1, Orient Blue
gone
2016 Triumph Thruxton R
2000 R1100RT.
MarinPhil is offline
post #2 of 6 Old Apr 12th, 2019, 3:41 am
bandytales's Avatar
Re: R1100RT new exhaust question
If we are talking about the R1100 / R1150 series, I would advise against the changing of the stock pipe for an aftermarket one. These bikes have always worked better with the OEM pipe and most attempts at change leave the bike with holes in the power band. Eliminating the Cat is also not the best idea.
I don't have any problem with good aftermarket pipes, but on this bike, not so much!
2003 R1150RT & 2017 R1200RT
bandytales is offline
post #3 of 6 Old Apr 12th, 2019, 7:26 pm Thread Starter
MarinPhil's Avatar
Is your opinion from personal experience? Why is removing the cat a bad move? Weight and a cooler running engine is a good thing right?
Phil in Marin
gone
2000 R1100RT.
post #4 of 6 Old Apr 15th, 2019, 5:45 am
bandytales's Avatar
Yes, my experience and also the experience of many others.
It has a negative effect on performance. As for the weight and the heat, well the heat has never caused an issue on the Oilheads. As for the weight, It is so low down it may even have a positive effect on the centre of balance of the bike.
Again, can I suggest you post this on the dedicated Oilhead section of the BMWST forum and you will get a much more focused response.
https://www.bmwsporttouring.com/forum/16-oilheads/
post #5 of 6 Old Apr 15th, 2019, 3:08 pm
Speaking from an Australian point of view - Our R1100's did not have a CAT (or CAT code plug) fitted, so I can't help you there. I owned a few RT's, and they all benefitted from an exhaust pipe change in parallel with GS intake tubes. It transformed the bike, improving all-over tractability, low-down pickup and most of all - minimised the well known surging of the engine around 3000rpm. The only way to eliminate it completely was a good throttle body synch, but that's a different story.
The pipe I used was an Australian 'Staintune' brand.
Nine out of five pilots are lysdexic.
Ejetflyer is offline
post #6 of 6 Old Apr 15th, 2019, 11:50 pm
Every BMW I've changed (5) lost low end torque, had flat spots and always ended up going back to stock.
Pabst is offline
Exhaust corrosion problem oldjim RT Series 18 Nov 14th, 2010 11:39 am
2010 exhaust note rlv GS Series 10 Aug 19th, 2010 4:25 pm
Cracked exhaust and vibration bowlesj K1200LT 2 Aug 4th, 2009 11:48 am
Chrome Exhaust & Anti Theft Alarm dmchz RT Series 8 Mar 13th, 2009 4:18 pm
R1100RT Newbie Question poldart RT Series 4 Sep 4th, 2008 2:40 pm
