Anyone help decipher powerscreen wiring 1995 RT? - BMW Luxury Touring Community
post #1 of 17 Old Apr 10th, 2019, 4:08 am Thread Starter
Question Anyone help decipher powerscreen wiring 1995 RT?
Hi folks. Newby here - just picked up mint 96 R1100RT last week (my 1st oilhead - always had KLT's & airheads) and the power screen is not working. Well it will work but only if I fudge it....
I have attached the wiring diagram below if anyone can help me decipher whats going ????
BTW what a PITA to get to those relays! Now they easilly sit behind the speaker grill for future probs....
Anyway - battled to get another 2 new realys - fitted them and still not working. So delved in with the manual and got the motor off and its working fine (2 wires) got the power in to both relays from 12v Batt+, got, got the power from handlebar switch 12v ok for both up and down, got the earths on both replays and the motor ok. However nothing happens unless - see pic - I earth the up/down switch from the relays (not the handlebar) to the up/down switch on motor. I've got a bodge (see pic) where if I bridge the 2 switched wires on relays/motor to a common earth the up/down switch on bars activates!!! What the ??? am I missing here folks - BTW - both the old relays are fine!
ID:	150933   Click image for larger version
IrishBob is offline
post #2 of 17 Old Apr 10th, 2019, 4:39 am
Re: Anyone help decipher powerscreen wiring 1995 RT?
Sounds like the relays are good, as is the handlebar switch and the motor, and if there are no obvious wiring faults I would be looking at the up and down position limit switches.
I'm guessing the relays don't operate (click) when you press the handlebar switch - and the power to those relay coils goes through the position limit switches,
You could disconnect the wires from the limit switches and check between pins 5 & 6 on the down switch, also pins 1 & 2 on the up switch with a multimeter.
I would expect the limit switchs to go open circuit when the screen is either fully up or fully down (one switch controlling up, the other down) this is what stops the motor when the screen gets to the end of it's travel. When the screen is somewhere in between fully up and fully down, both switches should be short circuit across pins 5 & 6 and 1 & 2 respectively.
Jon
2017 R1200RT
So many places, so many roads, so few days off work.
JonA is offline
post #3 of 17 Old Apr 10th, 2019, 4:54 am Thread Starter
Hi and thanks for reply. Whilst I can navigate most small elec probs I'm no expert. Unlike the wiring diagram - I have the Haynes & factory manuals - there is only 1 small Blue limit switch on the motor. It has 3 wires - up/down/earth and 1 contact for the touch against the rotating wheel in motor. If I earth the up or down wires the screen will operate.
The 2 main wires to the motor will only power up if I earth these limit switch wires either on the motor or at the multiplug where the relays are attached.
IrishBob is offline
post #4 of 17 Old Apr 10th, 2019, 5:04 am Thread Starter
Further to last post - in the pic I show green arrows - stupid question ??? but if I join both those feed wires on the limit switch on motor to a permenant earth and use the handlebar switch as normal (tried it and it works) what can go wrong? Burn out???
IrishBob is offline
post #5 of 17 Old Apr 10th, 2019, 6:37 am
bandytales's Avatar
Yes, you could destroy the motor drive mechanism as it could over travel in both directions.
Have you checked the 2 limit switches.
2003 R1150RT & 2017 R1200RT
bandytales is offline
post #6 of 17 Old Apr 10th, 2019, 7:18 am Thread Starter
Unsure how to test the LS? - as stated there is only 1 despite what the diagrams state. It's got a single plunger that contacts with the motor wheel and 3 wires: earth and what I assume should be 2 feeds? No power goes to the feeds but they will operate when I put them to earth.
Name:	Webasto4 limit switch.JPG
ID:	150941   Click image for larger version
IrishBob is offline
post #7 of 17 Old Apr 10th, 2019, 7:26 am Thread Starter
and yes you are correct - the relays do not click when handlebar switch is depresed however - there is 12v going into the relay coils terminal 86 and 12v coming out of terminal 85 when switch is pressed but the 30 terminals show nothing - these are the main feeds to motor - does make sense?
IrishBob is offline
post #8 of 17 Old Apr 10th, 2019, 8:02 am
ok, so you have only one pyhsical limit switch, but if you look at the diagram although it's shown as 2 switches, the brown common wire is feeding both switches, so there only needs to be 3 wires connecting to the switch.
Can you try operating the switch manually to see if it clicks - then check the continuity. You should see a 'changeover' action where the brown common wire is either shorted to one or the other of the remaining 2 wires.
Jon
2017 R1200RT
JonA is offline
post #9 of 17 Old Apr 10th, 2019, 8:15 am Thread Starter
OK Jon. Not able to strip motor just now but had a few mins to spare as follows (and it's a pig to get get cover relocated again). Did a continuity test on the limit switch with common earth - result no continuity with either of the other 2 wires. Disconnected the 5 motor wires from the multiplug and checked the 3 on LS again - same result.
Then went to main multiplg into which the 2 relays are located and performed following tests on connections under the relays. Results as follows:
Mains feed to both relays (and using the multiplugs 2 earth wires to check) No87 at 12v
Press handlebar switch (same test to both relays for up/down) Nos 86 & 85 both showing 12v but no click in relay
Double check earth No 87a in multiplugs with a 2ndary 12v feed and both ok
Neither the Blue or Purple feeds to the motor No30 are showing any power
Relays will only click if earthed seperatly via 86/85 (different positions on up/down relays)(and subsequently power the motor if reconnected.
IrishBob is offline
post #10 of 17 Old Apr 10th, 2019, 8:37 am
Looking at the diagram I'm going for a faulty limit switch.
If you follow the path from +12 to ground it goes through the handlebar switch, then one or other or the relay coils, then through the limit switch and to ground.
If the limit switch is testing open circuit both ways, then it won't matter whether you press up or down on the handlebar switch, neither relay will operate, and unless one or other relays operate, the motor won't run.
Jon
2017 R1200RT
JonA is offline
post #11 of 17 Old Apr 10th, 2019, 9:02 am Thread Starter
OK - sorry if I'm sounding dim here - but if the motor assy is disconnected then should the relays still not work as normal via the handlebar switch and send power to the motor only to have the limit switch then do it's thing?
IrishBob is offline
post #12 of 17 Old Apr 10th, 2019, 9:25 am
bandytales's Avatar
If the motor is disconnected, the relays will not work. Their coil supply is through the connector of the motor (which is also the same connector as the limit switches).
post #13 of 17 Old Apr 10th, 2019, 10:22 am
Short all 3 of the wires on the limit switch together. Then if everything else is good, the relays should energise and the motor should run when you press the handlebar button.
As has been said, this is not a fix as the motor will burn out, but it would indicate the limit switch is faulty.
Jon
2017 R1200RT
JonA is offline
post #14 of 17 Old Apr 11th, 2019, 4:58 am Thread Starter
OK folks. Shorted all 3 wires on micro switch and as you stated the handlebar switch works both ways.
Pulled the motor and removed the micro switch. Using multi meter I tested for continuity over the 3 terminals using earth as common but no continuity signal through the other 2. In turn pressed the up/down buttons (I now see there are 2 tiny buttons on the switch 1 on top of the other!) and both ping continuity ok tested.
So this means the micro/limit switch is ok or ????
If the micro is ok what now?
I see Range Rover/BMW use same micro on sunroof motors but cannot for the life of me find anyone who sells these seperatly - not even RS.
Switch only states Swiss made S976 (has 6 poles)
IrishBob is offline
post #15 of 17 Old Apr 11th, 2019, 5:29 am
bandytales's Avatar
Attachment 150969
Hi IrishBob. Can I suggest you post this across on the Oilhead section of the BMWST forum (https://www.bmwsporttouring.com/forum/16-oilheads/)
There is a lot of Oilheas specific knowledge on there - particularly a guy that goes under the name of D.R. or Dirtrider.
post #16 of 17 Old Apr 11th, 2019, 5:43 am Thread Starter
Thanks Bandy - have put a post up and link back to all your good advice.
Cheers
IrishBob is offline
post #17 of 17 Old Apr 12th, 2019, 2:32 pm
wethead's Avatar
1995?
Geez, I thought there were only Harley/s back then...and they were like bicycles with motors.
Nevertheless, I appreciate the love of old things.
wethead is offline
Wiring CD kj4tak RT Series 3 Nov 24th, 2014 5:38 pm
Wiring diagrams for 2002 K1200LT Tat_n_Telle K1200LT 10 Feb 24th, 2014 8:20 am
Wiring Guru Needed! Scouter-50 K1200LT 6 Jun 2nd, 2012 9:10 pm
Factory GPS wiring & BMR shelf sonnata GPS 0 Nov 24th, 2007 12:03 pm
Wiring Suggestions for Kisan Brake/Turn Signal Device Nebish Lighting 0 May 24th, 2007 12:16 pm
