Changing both tires simultaneously - BMW Luxury Touring Community
 2Likes
  • 2 Post By Dann323
post #1 of 12 Old Apr 5th, 2019, 3:32 pm Thread Starter
wethead's Avatar
I would like to get some ideas as to how to take both tires off at the same time on '18 RT. Otherwise I am gonna have to take the long trip to my install place twice.
Thank you for your ideas
wethead is offline
post #2 of 12 Old Apr 5th, 2019, 4:18 pm
N00bie RT Gawd's Avatar
Re: Changing both tires simultaneously
Front lift stand + your center stand. Take rear off first, then front. Put something under your swingarm so the bike doesn't tilt too far rearwards.
Those who say that it can't be done shouldn't interrupt those who are doing it.
Democrats are to America what mold is to bread.
N00bie RT Gawd is offline
post #3 of 12 Old Apr 5th, 2019, 4:39 pm
Pappy53's Avatar
Remove the muffler if needed to clear the wheel. Break the torque on the rear bolts. Loosen the front axle pinch bolt(s) and break the torque on the axle (I don't like to apply torque to loosen big bolts with the machine dangling off some jury-rigged supports but that's just me).
Get a cinder block (or three or anything heavy) and use that to weigh down the rear end. Remove the front tire and reinstall the axle hand tight. Put a jack stand (or any sturdy item) under the axle and slowly lower the front end back down on to it. Don't pitch the bike too far forward or it might pop off the center stand (this would be bad). Then remove the rear tire.
Reverse the procedure to reinstall.
'13 R1200RT 90th Anniversary Edition
Pappy53 is offline
post #4 of 12 Old Apr 5th, 2019, 4:40 pm
Rainman48's Avatar
  1. Put bike on center stand.
  2. Loosen front axle.
  3. Remove rear wheel.
  4. Place an adjustable jack stand under the final drive (with towel under it).
  5. Place a barbell or other weight of about 75 pound on rear seat or remove top case and place weight on rear platform.
  6. With front wheel now raised, finish removing front wheel.
My preferred option is to buy a BMW specific single sided rear bike stand from Pitbull that works on all left-sided final drives, and an adjustable front wheel stand from them. Spendy, but if you are trying to save money in the long run by dismounting your own tires, just do it.
Rear = F0099-400
Front = F0100-100
'16 BMW R1200RT
'10 BMW S1000RR
'09 Suzuki DR650
'05 Honda RC51
Rainman48 is offline
post #5 of 12 Old Apr 6th, 2019, 9:07 am
hopz's Avatar
I did this last week when I got new tires. It is not hard but best if you have a helper the first time... It did mine solo...
Do what Rainman listed above....
I used a heavy plywood box to support the bike/motor...
but you can use any sort of block under the front of the engine, or even a jack if you have one.
Be careful to keep the center of gravity forward... once you take the front wheel off you do not want it tilting towards the rear.
Yes you will have to remove the exhaust and muffler first.. that is easy.
2014 R1200RT WC
“As Woody Guthrie says, ‘Left wing, right wing, chicken wing.’I keep my mind open. Whatever you believe, it’s all a mystery in the end.”
hopz is offline
post #6 of 12 Old Apr 6th, 2019, 10:47 am
kellenbenz's Avatar
Remove the muffler and rear wheel first.
Tie the center stand forward to keep it from folding when pushing on the bike.
Put a floor jack under the engine(using a small piece of wood to protect) and raise the front.
This allows you to remove the front wheel without taking the front fender off. (Caution to just raise enough to get the wheel out)
After changing tires out, install the front wheel first then the rear.
Ron
IBA 45658 MOA167437
Total BMW miles 497,451
Goldwing miles 238,383
kellenbenz is offline
post #7 of 12 Old Apr 6th, 2019, 8:57 pm
Dann323's Avatar
Like this:
Using a front fork lift and the center stand
Or this:
Since I bought a lift, this is how I do it now.
On this picture, the rear wheel hasn't been removed yet, but as you can see it's not touching anything and can be removed easily.
The scissor jack and the center stand support the bike.
Works well for me. I remove both wheels all the time when I change tires.
wetboxerrt and Goose11 like this.
Daniel
If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
IBA # 56396
MOA # 171966
R1200RT 2007
Dann323 is offline
post #8 of 12 Old Apr 7th, 2019, 6:57 pm
McWideglide's Avatar
My RT is nose heavy like my 1300GT was, I use this procedure on both of them.
Centerstand > 1- 20 pounds of weight in top case. ( front wheel up ) > remove front wheel > reinstall axle > place jack stand under axle > remove extra weight in top case to lower axle on padded jack stand > remove rear wheel.
I have used my wife as a counter weight until removal of front wheel complete.
McWideglide
Jeff M.
2002 Harley Dyna Wideglide
2016 BMW R1200RT
2009 BMW K1300GT sold
1976 BMW R90/6 sold
1967 BSA 441 Victor sold
McWideglide is offline
post #9 of 12 Old Apr 10th, 2019, 6:21 am
This what I use.
ID:	150937   Click image for larger version
2014 R 1200 RT
2016 S 1000 XR
bdfbeemer is offline
post #10 of 12 Old Apr 10th, 2019, 10:19 am Thread Starter
wethead's Avatar
Originally Posted by bdfbeemer View Post
This what I use.
I never seen that gadget before, where did you get it? Name?, brand? Model?
It looks like something Inwould like to have
wethead is offline
post #11 of 12 Old Apr 10th, 2019, 10:40 am
EzyMount's Avatar
That is the ABBA Superlift. I also use one. Makes it very easy to get to stuff. You can raise only front, only rear, or complete level lift...
Jim Lawson 2016 R1200RT
Retired to NC !
EzyMount is offline
post #12 of 12 Old Apr 10th, 2019, 1:58 pm
Booger man's Avatar
Sweet Lord that bike looks like it is ready to launch 🚀 Nice 👍
Booger man is offline
Tire changing Charlie's way jrh2020 K1200LT 5 Jun 17th, 2010 11:25 am
Nitrogen in Tires dnifong Tires 22 Aug 2nd, 2009 2:56 pm
Tires? BMWrdr Tires 13 Jul 22nd, 2009 8:52 am
Changing Tires??? rab1967 K1200LT 4 Apr 13th, 2008 12:15 pm
Need the tire changing tools..... riderup1 K1200LT 4 Nov 7th, 2005 8:58 pm
