R1250RT Induction noise under heavy throttle - BMW Luxury Touring Community
 8Likes
  • 1 Post By LAF
  • 1 Post By nox273
  • 1 Post By Ponch
  • 1 Post By heli_madken
  • 2 Post By nox273
  • 1 Post By casbar
post #1 of 24 Old Mar 21st, 2019, 11:50 pm Thread Starter
nox273's Avatar
Hi All
Not having owned an RT before I was curious about how the my new 1250 engine sounds under acceleration. When using gentle to medium throttle the engine is very quiet even when using heavy throttle down low. But once the needle swings past 4000rpm it gives of quite a loud deep growl sounding like induction noise from under the tank area.
Is this common to Rt's or possibly the new ShiftCam taking over moving from the low to high lift on the cam.
Any other 1250/1200 riders notice this?
nox273 is offline
post #2 of 24 Old Mar 22nd, 2019, 5:14 am
LAF
LAF's Avatar
Re: R1250RT Induction noise under heavy throttle
I can only spitball and say you are hearing the full sound of the exhaust as the exhaust flap opens fully at higher throttle position.
It is a little sound deterrent that is built into the exhaust to help quiet the bike and is closed semi closed at lower RPM/throttle position and fully open under WOT or higher throttle openings.
I'll take your problem sounds like it would be music to my ears
beech likes this.
Lee
17.5 R1200 GSW Black Low
ATGATT I am breathing proof.
BMW MOA #135959
LAF is offline
post #3 of 24 Old Mar 22nd, 2019, 7:39 am
Grumpy_Squatch's Avatar
First-time 1250RT owner here too. I'm partially deaf so I might not notice it as much as you do, but ased on things I've read, the Shift Cam works its magic around 5000 RPM under normal loads. So if that's when the sound starts it might be related. I guess under hard acceleration you'd make it from 4K to 5K RPM pretty quickly, so you might be on to something. Otherwise, perhaps as LAF suggests, the changing exhaust port affects the resonance of the whole system.
Grumpy_Squatch is offline
post #4 of 24 Old Mar 22nd, 2019, 9:32 am
bandytales's Avatar
I have ridden both and the noise is pretty much identical on both bikes all the way up to the endstops.
As LAF said, I am pretty sure you are not hearing induction noise, but the exhaust flap opening and you are hearing the engine sing from the back end.
2003 R1150RT & 2017 R1200RT
bandytales is offline
post #5 of 24 Old Mar 22nd, 2019, 10:48 pm Thread Starter
nox273's Avatar
This sounds exactly what I am hearing. Scooter to a sports bike in a couple of seconds.
LAF likes this.
nox273 is offline
post #6 of 24 Old Mar 22nd, 2019, 11:12 pm
beech's Avatar
Once your out of town, keeping you bike above or near 4K RPM is a good thing, don't lug it. You may be surprised what it does above 6K rpm.
Beech
I change your tires $40, you buy them on the web.
beech is offline
post #7 of 24 Old Mar 22nd, 2019, 11:13 pm
Ponch's Avatar
Hi All
And the problem is...
PadG likes this.
Ponch
"I came into this game for the action, the excitement. Go anywhere, travel light, get in, get out, wherever there's trouble, a man alone."
2009 RT
Previous bikes:2007 Nomad | 2001 Vulcan 800 Classic | 1984 GPz750 | 1978 KZ1000A2
BMWMOA 162849
BMWRA 41335
VROC 8109-R
VBA 19
Ponch is offline
post #8 of 24 Old Mar 23rd, 2019, 6:06 am
LAF
LAF's Avatar
He has a 1250 and I don't?
Lee
BMW MOA #135959
LAF is offline
post #9 of 24 Old Mar 23rd, 2019, 7:53 am
Motodan's Avatar
Not a Certified Master BMW Technician however, feel quite safe in stating, "They all do that."
35 BMW Bikes -
the Wetheads
2013 R1200GS (Gone) 2014 R1200RT (Sold back to BMW)
2015 R1200RT (Gone) 2017 R1200RT (Gone)
2018 R1200RT
MOA #46783
Motodan is offline
post #10 of 24 Old Apr 1st, 2019, 5:36 pm
Apologies for hijacking this thread
I have a problem at the other end of the scale, my 1250 has a high pitch rattle just as you roll on throttle, I took it back to the dealer almost immediately and got the 'they all do that' response
I mentioned in another thread that it sounds a lot like the old pre-ignition.
I can hear it even above the radio and to say it 'jangles my nerves' is an understatement, I have grown to hate the noise my bike makes, my 14 plate was much nicer.
Anyone else experience anything like this, certainly the demo bike I had out didnt make this noise, I had hoped it would calm down with some mileage but it isnt going away.
heli_madken is offline
post #11 of 24 Old Apr 1st, 2019, 5:47 pm
LAF
LAF's Avatar
I would keep filling it with 93 octane gas every chance I got a gallon at a time if I had to. I also would add a bottle of Techron fuel treatment.
Since I now understand they have added the knock sensor back to the 1250 motor it might be bad fuel.
You have to ask what kind and fuel and what octane your dealer is throwing into each bike it sells.
Lee
BMW MOA #135959
LAF is offline
post #12 of 24 Old Apr 2nd, 2019, 1:11 am
Thanks for your help, yes last two tanks have been high octane, it doesn't seem to have made any difference, I will try the Techron though. I also feel that the bike is very 'buzzy' at motorway speeds and at idle the screen shakes more violently than my old bike although I am hoping these two elements are due to the engines low mileage.
LAF likes this.
post #13 of 24 Old Apr 2nd, 2019, 3:59 am
If the dealer's demo bike didn't make the noise, then clearly their response "they all do that" is unacceptable. I would be taking the demo bike out again to confirm things, then take a much harder line with the dealer. It's a pretty sad state of affairs that you say you have grown to hate the noise your bike makes. A new (and expensive) bike should make you happy - or what's the point..
Jon
2017 R1200RT
So many places, so many roads, so few days off work.
JonA is offline
post #14 of 24 Old Apr 2nd, 2019, 5:38 am Thread Starter
nox273's Avatar
My 1250 engine is very quiet with no high pitch rattles etc. (I only detect a change in engine tone when the exhaust fan fully opens around 4000 rpm) It is also very smooth at highway speeds. I only get a little shaking of the screen when the bike is idling and the screen is fully up, but I wouldn't call it violent.
Take your bike in and demand they take a look at it and at least compare it to another bike or demo unit.
PadG and Grumpy_Squatch like this.
nox273 is offline
post #15 of 24 Old Apr 10th, 2019, 3:16 pm
AlanColes's Avatar
... It is a little sound deterrent that is built into the exhaust to help quiet the bike and is closed semi closed at lower RPM/throttle position and fully open under WOT or higher throttle openings...
It is my understanding that the primary purpose of the flap is to improve the engine power output by adjusting exhaust backpressure as needed. Freer/freest flowing above 4-5k and partially restricted to increase backpressure below 4k to improve low-end torque.
AlanColes is offline
post #16 of 24 Old Apr 10th, 2019, 4:14 pm
beech's Avatar
I think that is the primary purpose, but it does help with noise abatement around town.
Beech
beech is offline
post #17 of 24 Old Apr 11th, 2019, 9:56 am
Having had two of these flaps replaced (new headers), the tech told me, its purely for emissions and noise, and doesn't do anything for performance or torque. He said if it was stuck open, there would be no issues whatsoever with the bike apart from it throws a code as its tested during initial switch on, so the mothership knows if it's stuck. I experienced no change to how the bike performed when mine was stuck open. But that is obviously seat of the pants and not measured technically
casbar is offline
post #18 of 24 Old Apr 14th, 2019, 10:35 am
My bike has done 75 miles, and I think I have the same noise your talking about. On light throttle it sounds like the engine in pinning, slight rattle, but as you accelerate it goes away. I'll keep an eye on it, but don't think its anything to worry about, just sound different
casbar is offline
post #19 of 24 Old Apr 14th, 2019, 11:19 am
Also I have just realised, I didn't hear the noise when I picked my bike up, it had the sport windscreen on it. Once I got home, I put a Werks screen back on and then I heard the rattle. So I assume as the windscreen makes for a quieter ride, I'm now hearing more of the engine/transmission or whatever. I let my mate ride it yesterday for 40 miles, he rides a F800 and didn't notice anything, so I think its just a different noise to the 1200
casbar is offline
post #20 of 24 Old Apr 14th, 2019, 11:32 am
Thanks Casbar,
Yes the first 1/4" of throttle in any gear just as the engine takes up load, light rattle which goes away as the revs pick up
My bike went in for its first service on Friday so I took the opportunity to talk to the service head again, he heard the noise himself the last time I asked about it on his test run but the mechanic who took it out this time could hear nothing. So needless to say I didnt get anywhere, both stated the bike is perfect.
I have ridden two other 1250's that dont make the same noise, perhaps our bikes are Friday afternoon jobs on the production line
I am sure mechanically there is nothing wrong with our bikes its just the particular noise it makes annoys me.
post #21 of 24 Old Apr 14th, 2019, 11:41 am
Thanks Casbar,
I'm not worried, I'll see how it goes, love the bike and the engine
casbar is offline
post #22 of 24 Old Apr 15th, 2019, 9:56 am
Thanks Casbar,
Have you got the standard can on it? I just realised why I didn't hear anything when I rode the bike home, I had my ear plugs in and when I did hear it yesterday I was riding without plugs Thats obviously the answer, wear my ear plugs
casbar is offline
post #23 of 24 Old Apr 16th, 2019, 1:03 pm
Yes standard can, the noise to me comes from the front of the engine and is separate to the normal mechanical noise.
As suggested by LAF I tried some Techron yesterday, could be my imagination but it does seem to have eased the noise a little.
Earplugs!, My own current solution is to listen to music perhaps a little louder than I used to
LAF likes this.
post #24 of 24 Old Apr 16th, 2019, 1:13 pm
I am hearing the same thing, but went out yesterday and did another 50 or so miles and it appeared to not be as bad, or I'm getting used to it. It almost sounds to me like the pads rumbling in the front calliper, a kind of rattle. But as I said its getting less and less, so I'll wait and see what happens. I've got an Akra can on mine, so I was wondering if that was having an impact, but its not
LAF likes this.
casbar is offline
2014 RT - Engine light on - no throttle - WTF GollyGwiz RT Series 24 May 4th, 2018 6:06 pm
Just how heavy is a heavy throttle ? tombstone K1200LT 10 May 27th, 2013 6:30 pm
Rather longish, but good tips & info! vvk Bike Talk 7 Jun 19th, 2011 4:43 pm
Heavy throttle - Technical question sittonb K1200LT 10 Aug 20th, 2010 11:45 am
Lubed my throttle cables----great result!! wildwestrider K1200LT 12 Apr 21st, 2008 8:13 pm
