TPM 2016 R1200RTW - BMW Luxury Touring Community
 6Likes
  • 1 Post By JayJay
  • 1 Post By RidgeRunner
  • 2 Post By veldthui
  • 1 Post By McWideglide
  • 1 Post By Dsmith1200
post #1 of 32 Old Dec 3rd, 2018, 7:44 pm Thread Starter
McWideglide's Avatar
TPM 2016 R1200RTW
I think I am experiencing a TPM failure. My front and rear display light up after a block plus of riding. 36 - 44 . Riding a few miles the rear display goes blank. About 10 miles along it comes back. Twice the display was ------- long enough to trigger the warning triangle and tire on monitor. Some time later the sensor is detected and warnings clear. Today I had the warning triggered and 8 miles later clear and display pressure 44. Today I lost the display 4 times but restored . I have lost the front display only twice but think it must be on its way out.
Is this the symptom of a dying battery in the sensor .
The bike is still under warranty and hope to convince the dealer to replace both TPM's if that is the problem.
McWideglide
Jeff M.
2002 Harley Dyna Wideglide
2016 BMW R1200RT
2009 BMW K1300GT sold
1976 BMW R90/6 sold
1967 BSA 441 Victor sold
McWideglide is offline
post #2 of 32 Old Dec 3rd, 2018, 10:26 pm
N00bie RT Gawd's Avatar
Re: TPM 2016 R1200RTW
Originally Posted by McWideglide View Post
...shit going down...
I believe a GS911 is able to display the battery voltage. I don't know how long these batteries are supposed to last, but they should last more than 2 years.
So warranty won't cover battery replacement and the warranty won't cover diagnostics unless a fault is returned. I would also think that the battery has a warning light for low TPMS battery voltage (look in the manual in the section for dash warning lights and see if it's there). BUT, it doesn't really sound like a bad battery; maybe they just need reset?
Best bet is to find someone nearby who has one of them GS911 thingamabobs.
Those who say that it can't be done shouldn't interrupt those who are doing it.
Democrats are to America what mold is to bread.
N00bie RT Gawd is offline
post #3 of 32 Old Dec 4th, 2018, 8:25 am
The rear TPM went bad on my 2014 RT. Aftermarket warranty covered the replacement Talk to the dealer. It should show a fault code and should be replaced under the bikes warranty.
2014 R 1200 RT
2016 S 1000 XR
bdfbeemer is offline
post #4 of 32 Old Dec 4th, 2018, 10:35 am
iride4u's Avatar
My rear sensor is going bad. They are around $250 each. I plan on replacing it when I get my tires replaced.
2014 K1600 Exclusive
2015 R1200RTP
2018 Hyundai Tucson Limited
Colorado PGR
iride4u is offline
post #5 of 32 Old Dec 4th, 2018, 11:04 am
JayJay's Avatar
Interesting that you folks are showing failures within a couple of years. The TPMs on my 2009 seem to be doing fine ten years in. I do not ever recall seeing a fault on the GS911, which I hook up every 6K service.
Regardless, this is unacceptable performance and is a warranty item. Take it in to the dealer. (McW, local info - SJBMW has always worked well with me on warranty and recall issues.)
JayJay
beech likes this.
JayJay
'09 R1200 RT
'73 R75/5 Toaster (gone)
'07 Honda Rebel (gone)
Kids (gone - graduated and employed!)
'81 Honda Gold Wing (gone)
'75 Honda CB500 Twin DOHC (gone)
'77 Honda CB750 (gone)
Bride (going strong)
BMWMOA 159659
IBA 63871
[SIGPIC][/SIGPIC]
JayJay is offline
post #6 of 32 Old Dec 4th, 2018, 2:57 pm
I agree with JayJay; take it to the dealer and let them sort it out for you. Most TPM batteries last about 10years. My 2010 Lexus 450h is still on the original TPM batteries; two years is not acceptable performance.
beech likes this.
Bob in the Sonoran Desert
2018 R1200RT Option 719 (Planet Blue Metallic)
2016 S1000XR (White) sold
2014 S1000R (Matt Blue) sold
2008 R1200RT (Biarritz Blue) sold
RidgeRunner is offline
post #7 of 32 Old Dec 4th, 2018, 6:51 pm Thread Starter
I plan to take it to the dealer. I am waiting a bit to see if the front starts to fail more often. I will pick a dry day to this. Will the warning fault store a code so they can see it? Or will it clear itself when the sensor receiver reconnect?
McWideglide
Jeff M.
2016 BMW R1200RT
1976 BMW R90/6 sold
post #8 of 32 Old Dec 4th, 2018, 8:03 pm
NoelCP's Avatar
Jeff, what you describe is very similar to what I experienced when I had two new Conti RA3 tires installed at around 30K miles. Immediately after installation BOTH the front and rear failed to display for many miles of riding which was a first--they always lit up before getting to the end of my short street. The tires were installed the day before we took off for a trip up to the Canadian Rockies. They continued to perform erratically, including getting a couple of low pressure warnings. After several thousand miles it seemed they seemed to be working regularly again. My warranty expired a week after returning home, and at that point both sensors had been working consistently for many days. Of note, I got a flat in the rear tire a month or two later, and a new Conti RA3 was installed. No problems w/ the TPM after! So it's still working, and why it suffered after the prior tire install is pure conjecture!
2016 R1200RT - Dreamliner
2013 F800GT - Sold
1985 Kawasaki 1000 LTD - Sold
1968 Honda 350 - Sold
NoelCP is offline
post #9 of 32 Old Dec 5th, 2018, 9:14 am
Dsmith1200's Avatar
This sounds exactly like what my 15 RT did starting in Nov 2017. Bike went into service in Aug 2015. Intermittent loss of signal from the rear TPMS. I connected my GS911 and it showed numerous episodes of interference. Talked to my dealer and he said that is a common fault. Faults became more numerous and in Jan 2018, at 34500 miles, dealer agreed to replace the rear sensor. Problem solved. In June the front began displaying the same symptoms. I sourced a sensor from the internet for $78.00 and installed it myself. Again, problem solved. The sensors are reputed to have 5+ year lifespans. Some do I suppose but a lot do not.
Dsmith1200 is offline
post #10 of 32 Old Dec 6th, 2018, 12:07 pm
Chieflonghair's Avatar
The TPM units only come in when the bike is moving...this is why you ride a couple blocks before getting a reading...I think battery life may be a bit controlled by time..years..but more so by milage..I got about 75K outta mine before I started to strange behavior...3 years
Chieflonghair is offline
post #11 of 32 Old Dec 6th, 2018, 2:31 pm
NoelCP's Avatar
Do you recall the source? I'm sure I'm headed there pretty soon too.
2013 F800GT - Sold
NoelCP is offline
post #12 of 32 Old Dec 6th, 2018, 6:35 pm
Dsmith1200's Avatar
Not specifically. It was on Ebay. I tried a cheaper one before which worked well but only for a couple months. The last one said it had the 7 digit ID number printed on it making it very easy to register to the bike with a GS911.
post #13 of 32 Old Dec 6th, 2018, 6:51 pm
I'm not 100% sure, but I think your 2016 model uses the same sensors as my 2012 model, even though they are a different generation. GS-911 does not show voltage as far as I've seen, but you can use it to register a second pair of sensors if you choose. So, new sensors are both registered and "activated" with a tool to wake them up. The batteries are common watch batteries, but sealed in epoxy. if your dealer won't replace them, you can install knock-off sensors pretty cheaply. Here's my video on how I did it:
painter is offline
post #14 of 32 Old Jan 23rd, 2019, 2:06 pm
It depends on how much you use it. They are in standby mode using very little power when not in use. Use it very little and it will last forever. Use it a lot and it will not last so long.
My '14 rear lost signal yesterday for a short time yesterday and while it is just over 4 years old it has done over 100,000km so was expecting them to cut out sooner or later. NZ$204 for a new one so next time I change tires I will change the TPMS and should be set for another 4 years.
Nil_Time and NoelCP like this.
Previous Bikes:
Honda VFR800 2011
Honda VFR1200 2012
veldthui is offline
post #15 of 32 Old Apr 5th, 2019, 6:47 pm
Got a tire symbol on the dash and switched to the pressure reading and the back was -- and the tire was showing red. Thought I had a problem but the tire is fine. 2015 with 20k. Unfortunately, the local dealer has a very understaffed service dept and any service appointment is a month out. Going to purchase the gs911 to see what's up and hopefully just turn off the tire symbol for now. Sound like a sensor problem or a dead battery?
MHTOUR is offline
post #16 of 32 Old Apr 5th, 2019, 6:58 pm
Dsmith1200's Avatar
Sounds like a dead or dying battery which is a sensor problem as the battery is not easily replaceable. I have not shopped them recently but I bought one lfor $78.00 from an E-bay vendor last June that is still working fine.
2015 R1200RT
post #17 of 32 Old May 17th, 2019, 11:04 am
ADulay's Avatar
My 2014RT has gone through three sets of the TPW things.
It is VERY disconcerting to have that red and yellow warning come on in the middle of the night.
No problems with the tires, just the indications that the end of the world was about to show up. What a pain.
They were originally replaced under warranty and the last set was covered under an extended warranty.
It would be nice to just be able to turn off the indication after a failure.
AD
2014 BMW R1200RTw
IBA #3281 Blue Knights
Life AMA, ABATE, HOG, VHPA
Certified Glock Armorer
Certified NRA Instructor in a bunch of things
ADulay is offline
post #18 of 32 Old May 17th, 2019, 1:54 pm Thread Starter
I am sorry I did not update my original post. I took the bike in for evaluation. They read a fault in front sensor. They replaced the sensor under warranty. I rode away and within 5 miles had the rear drop out again. I took it back and was told since the fault was not showing on the rear and was on the front, that is why they replaced the front. Rear replaced all is well. Funny my original complaint was for the rear wheel.
PadG likes this.
McWideglide
Jeff M.
2016 BMW R1200RT
1976 BMW R90/6 sold
post #19 of 32 Old May 21st, 2019, 9:56 am
NoelCP's Avatar
Mine faltered (https://www.bmwlt.com/forums/rt-seri...ml#post1894995) about this time last year, both front and back, but after a month or so of not working consistently they've been working fine despite the cool temps here. Nothing like the inside of a tire to provide some heat
2013 F800GT - Sold
NoelCP is offline
post #20 of 32 Old May 21st, 2019, 11:50 am
chromedomeRT's Avatar
The front sensor on my 2015 has not worked at all for 6 months (about 5,000 mi) I have a new one ready to go in next tire change. This is completely unacceptable and pretty unheard of in other cars/bikes. I'm hopeful that a forced recall will eventually put the money back in my pocket (save those receipts) but the hassle factor is irreparable.
Complaints can and should be submitted here:
https://www-odi.nhtsa.dot.gov/VehicleComplaint/
chromedomeRT is offline
post #21 of 32 Old May 22nd, 2019, 6:56 am
Mine starting going bad at about 70K miles...they only transmit info when rolling....that's why they take a minute or so to work....so age shouldn't really have much impact on the life of the tpm....2014 RT
post #22 of 32 Old May 22nd, 2019, 8:26 am
realshelby's Avatar
My rear sensor started not showing pressure when I would check it last fall. Then, in the middle of freeway traffic in Los Angeles, it came up with the red alert that a tire was low. I didn't feel anything, but fought to get off the road. Only to find everything was fine. Just got back from a trip into North Carolina. It started sending the red alert again and done it multiple times.
I have two aftermarket replacement TPS modules ordered. I ordered the "wake up device". I also ordered a pack of the CR 2032 batteries. First attempt will be to inspect sensor in rear for damage ( in case I hurt it changing tires ). If good I will attempt a battery change. I have a GS 911 so I can install and activate the aftermarket sensor if I have to go that route. Don't need a front tire, so won't take that down to install a battery this time.
While I appreciate the onboard TPS and the fact it can warn against a low tire, I do NOT appreciate the anxiety this system has given me. No way to turn it off, so I have to get it back in proper operating condition.
'14 R 1200 RT '12 DL 650
realshelby is offline
post #23 of 32 Old May 22nd, 2019, 9:10 am
SpinDog's Avatar
After reading this post I decided to check mine and discovered that I've had a couple of "reception interference" faults which (luckily) healed themselves; 2014 RT.
2014 R1200RT - Quartz blue metallic
2010 Kawasaki VN900
-CT USA-
SpinDog is offline
post #24 of 32 Old May 22nd, 2019, 9:43 am
Dsmith1200's Avatar
That is how it starts when the batteries begin to die,
SpinDog likes this.
2015 R1200RT
post #25 of 32 Old May 25th, 2019, 10:04 am
I am having the exact same problem on my 15' RT with 18k miles. Unfortunately it is out of warranty and was quoted $235 just for the sensor. It started out showing the ----- on the rear tire display every now and then but never got to the point of showing the two warning signs. Now after a few months of riding, it has got to the point where it only reads the rear sensor during the first few miles of riding that day and never shows up again unless I let it sit for several hours. So I guess that is a symptom of a dying battery. With only 18k miles, I guess it's more time based than mile since some people are hitting over 70k miles.
I had it at the dealer for maintenance and they checked the tpms with the diag tool and it did not show any fault codes or interference. They said that the sensors are reading just fine. Even though I had a warning light of on the dash with a red rear tire and a reading of -----, I thought that would have generated some type of fault code. I guess I was hoping it was an easy inexpensive fix. Guess I'll change it out on next tire change.
Jumpjet is offline
post #26 of 32 Old May 25th, 2019, 10:17 am
EzyMount's Avatar
So, I think I’m seeing 3-4 years on the battery life ?
Anyone seen more than 4 yrs ?
Jim Lawson 2016 R1200RT
Retired to NC !
[SIGPIC][/SIGPIC]
EzyMount is offline
post #27 of 32 Old May 25th, 2019, 11:05 am
PadG's Avatar
My '15 RT was one of the very first one to land here, and so it's been ridden since late 2014, and everything (in particular, the TPM) is still working as it should.
Pad. Gajajiva
Solon, OH, USA
2015 R1200RT (San Marino Blue Met.) - FOR SALES!
2007 R1200RT (Sold!)
Once Upon a Time........
1963 Norton Dominator 650 SS
1960 Triumph Thunderbird (6T)
1952 Triumph Thunderbird (6T)
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #28 of 32 Old May 25th, 2019, 8:22 pm
NoelCP's Avatar
I think you have to factor in miles as well since the batteries do not recharge per se, at least from an outside source. So one that is 5y/o and has only 14K miles on the bike may still well work dandy for another year or two. I have read tales of 6+y/o life for some.
2013 F800GT - Sold
NoelCP is offline
post #29 of 32 Old May 26th, 2019, 8:08 am
LAF
LAF's Avatar
Well if the wheels aren't turning the batteries are sleeping, or supposed to be.
This is another where battery life is all over the place and I have seen no data of miles ridden on active TPS and time battery's lasted in years in relation to miles ridden and time/miles sitting.
I know at the very least they should be battery replaceable. Not having to cutting it out and trying to replace it but a user accessible cover. And I mean a un removable cover like on our key fobs
Lee
17.5 R1200 GSW Black Low
ATGATT I am breathing proof.
BMW MOA #135959
LAF is online now
post #30 of 32 Old May 26th, 2019, 8:21 am
PadG's Avatar
Ok, then, here's another data point. Sold my 2007 RT sometimes in 2014, with original TPM working quite fine, and about 40k miles on the clock. BTW, the '15 RT has about 24k miles on the clock. Would have been a lot higher if I hadn't been riding abroad.
Pad. Gajajiva
Solon, OH, USA
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #31 of 32 Old Aug 8th, 2019, 12:31 pm
Interesting thing happened....
I had new tires mounted last week and had the tire shop replace the dead front tpms with a new dealer purchased unit. The tire shop had only the wheels not the bike. I re-mounted the wheels with the new tires and new tpms and went for a scrub in ride. Low and Behold the new TPMS registered a correct pressure reading! no dealer programming needed!
post #32 of 32 Old Aug 8th, 2019, 2:35 pm
PadG's Avatar
I also have been having some very interesting experience with my rear TPM over the last month or so!
The rear TMP had quit displaying the tire pressure for a minute or two, on one ride about a few weeks ago. The next ride, it went out several times during the 275 miles ride, for duration that lasted several minutes at a time. OK, that sure sounds like the battery is dying!
Now, here's the interesting part. Before the next ride, I had received what I had bought as a GS 911 alternative, to try out, and when I hooked it up to my RT, I checked the fault codes. Sure enough, there were several rear TPM "communication" fault codes, and so I reset them all. Next ride, TPM worked flawlessly, even though there was one fault code, when I checked after that ride. No more issues with the rear TPM since then!
Pad. Gajajiva
Solon, OH, USA
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
RCUDesign Accessory Shelf for 2016 R1200RTW MadHadder RT Series 2 Feb 9th, 2017 10:30 pm
The R1200RTW is just a wonderful motocycle jeffdean RT Series 10 Nov 7th, 2016 11:41 am
New Member and Owner of a 2016 R1200RTW wetboxerrt New Member Introductions 3 Jan 26th, 2016 6:09 am
