2010 RT only starting in neutral - BMW Luxury Touring Community
 15Likes
  • 2 Post By Pappy53
  • 2 Post By beech
  • 2 Post By JonA
  • 1 Post By TWheels
  • 1 Post By TWheels
  • 4 Post By TWheels
  • 1 Post By LAF
  • 1 Post By Black_Dog
post #1 of 37 Old May 23rd, 2018, 10:04 pm Thread Starter
I'm puzzled and appreciate any suggestions or explanations. The bike runs well but with side stand raised or lowered, it will only start in neutral. Once it starts, the bike operates normally and with the stand raised, I can change gears without the engine stopping.
If the engine is running and the side stand is lowered while in gear, the engine stops even if I pull in the clutch. The engine will not start again until I switch to neutral and I have to raise the stand before changing into first. My initial thought was the side stand switch but I'm thinking that if it was stuck in the "stand lowered position", the engine would cut out once I change from neutral regardless of the side stand position. Has anybody experienced this before?
Ride Safe
TWheels is offline
post #2 of 37 Old May 23rd, 2018, 10:51 pm
Pappy53's Avatar
Re: 2010 RT only starting in neutral
You can't start the bike in gear with the side stand extended under any circumstances. It will start in gear with the stand up and the clutch pulled-in. This is how the side stand safety is supposed to operate.
PadG and gerhard like this.
'13 R1200RT 90th Anniversary Edition
Pappy53 is offline
post #3 of 37 Old May 24th, 2018, 1:26 am
beech's Avatar
"it will only start in neutral"
Can you hear your clutch switch click when you put your ear by it and pull the lever all the way back? With the side stand up, you should be able to start the bike in gear and the clutch in if the switch is working. Since you can start it in neutral while the stand is down it seems to be the clutch switch. And just because it clicks does not really mean it works. That will take a meter and some work.
Patric and LAF like this.
Beech
beech is offline
post #4 of 37 Old May 24th, 2018, 4:44 am
You say when you lower the stand the engine stops, so the sidestand switch is working.
My money is also on the clutch switch - either the actual switch, a connector or wiring back to the ECU.
Disconnect the clutch switch from the wiring back to the ECU and put a multimeter set to resistance across the 2 switch terminals. Operate the clutch, it should go from open circuit to very low resistance.
If the switch looks ok, test back towards the ECU looking for volts. With the ignition on you should see a reading.
Patric and rapz like this.
Jon
2017 R1200RT
So many places, so many roads, so few days off work.
JonA is offline
post #5 of 37 Old May 24th, 2018, 5:57 am
TF1200RT's Avatar
I had this same issue on my 2009 K13GT. The problem was the clutch lever. I have Pazzo short levers on the bike and the adjuster moved from position 3 to position 2, which caused a shorter pull on the clutch. It was enough to cause the micro switch to not make contact and it would only start in neutral.
2009 K1300 GT
1984 Kawasaki ZX750-E1 Turbo
1990 Kawasaki ZX600R
2005 R1200 RT - gone
2008 Honda CBR1000 RR - gone
TF1200RT is offline
post #6 of 37 Old May 24th, 2018, 8:36 am
GSinNC's Avatar
Yep! That happened to my 2012
Definitely the micro-switch. Dealer ordered up a new one and it was a quick fix. Was covered under my extended warranty so not sure the cost but an easy fix
Ed Apelian
'18 R1200GS - Light White
GSinNC is offline
post #7 of 37 Old May 24th, 2018, 11:44 am Thread Starter
Thanks Everyone....
I'll check out the switch and go from there.
TWheels is offline
post #8 of 37 Old May 24th, 2018, 9:34 pm
JayJay's Avatar
I had the clutch switch fail on my 2009. It would start in neutral but would not start again in gear even if the lever was pulled in (like when you stall it starting out cold in an intersection, you pull in the clutch lever and hit the starter button). You have to disassemble the left handle housing to get to the microswitch. Some folks have opined that if your cruise control release works with the clutch handle then it can't be the microswitch. Not so, there are actually two microswitches in that assembly, one for the starter cutout and one for the cruise control release.
BTW, on the 2009 fiche the part is actually called "dual microphone switch" but it doesn't have anything to do with a microphone. Not sure what it's called on the 2010 fiche.
JayJay
JayJay
'09 R1200 RT
'73 R75/5 Toaster (gone)
'07 Honda Rebel (gone)
Kids (gone - graduated and employed!)
'81 Honda Gold Wing (gone)
'75 Honda CB500 Twin DOHC (gone)
'77 Honda CB750 (gone)
Bride (going strong)
BMWMOA 159659
IBA 63871
JayJay is offline
post #9 of 37 Old May 24th, 2018, 10:25 pm
Dann323's Avatar
Mine is starting to act up intermittently so I started to look at how to replace it.
The micro-switch itself is over $100 and you need to remove the gas tanks in order to reach the connector.
You also need to disassemble the left handle bar cluster to run the cable through the handlebars.
Daniel
If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
IBA # 56396
MOA # 171966
2019 R1250RT (0 km)
2007 R1200RT (186000 km)
Dann323 is offline
post #10 of 37 Old May 25th, 2018, 3:21 pm
PadG's Avatar
Originally Posted by TWheels View Post
Thanks Everyone....
Don't bother!
You seem to have missed a comment or two that said what you experienced is exactly how the safety system is supposed to work! As a matter of fact, I (and several people here) use exactly the feature to shut down the bike. Come to a stop, hold in the clutch with transmission in 1st, and put down the side-stand. Engine shuts off, and all that I need to do is turn off the ignition.
Pad. Gajajiva
Solon, OH, USA
2015 R1200RT (San Marino Blue Met.) - FOR SALES!
2007 R1200RT (Sold!)
Once Upon a Time........
1963 Norton Dominator 650 SS
1960 Triumph Thunderbird (6T)
1952 Triumph Thunderbird (6T)
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #11 of 37 Old May 25th, 2018, 4:51 pm
mtrevelino's Avatar
I think you may have missed his original comment, which was
"The bike runs well but with side stand raised or lowered, it will only start in neutral."
So following your logic, if I stall my bike when pulling away from a stop, you are saying the only way to start the bike is to place the gear in neutral? This is totally incorrect. I can restart my bike after it stalls while it is in first gear, sometimes in second gear (it happens!).
I agree in that if he does not pull the clutch in it should not start while in any gear, except neutral.
I also notice on my 08RT, that if I do stall it, sometimes I have to "wiggle" (move) the clutch handle to get the bike to crank over and start. That is my story and I am sticking to it!
Mike Trevelino
Williamsburg, VA
2008 RT
mtrevelino is offline
post #12 of 37 Old May 25th, 2018, 5:02 pm
Totally correct, pull the clutch in and you can start the bike in gear (sidestand up)- unless the clutch switch or wiring to it is faulty!
Jon
2017 R1200RT
JonA is offline
post #13 of 37 Old May 26th, 2018, 8:58 am
PadG's Avatar
Sorry! I did miss that part. Somehow it didn't register in my head. Since I always park in 1st, my normal start procedure is to raise the side-stand, pull in the clutch and hit the start button. My bikes rarely sees neutral. So, if his won't start with the stand up and in gear, then it has to be the clutch micro-switch.
Pad. Gajajiva
Solon, OH, USA
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #14 of 37 Old May 26th, 2018, 10:48 am Thread Starter
Probably not necessary at this point but I did want to confirm that it was indeed the clutch switch.
Thank Again Everyone
TMac99 likes this.
TWheels is offline
post #15 of 37 Old May 26th, 2018, 6:03 pm
darammer's Avatar
I have the same problem with my 12 RT. It is the clutch switch, well not so much the switch, but the bearings on the clutch lever itself are loose and so they don't always hit the switch at the right angle. If I play around with the position of the clutch lever it will work for a while...
Eventually I will replace the lever bearings, but for now, this works. You may want to check this before you spend the money on replacing the switch.
Rami
2012 BMW R1200RT - Ostra Grey - Current
2004 BMW R1150RT - Titan Silver - Sold
2005 Yamaha Stratoliner Midnight - Black and Chrome - Totalled
2003 Yamaha Road Star Silverado LE Silver Edition #0298/1600 - Sold
1998 Honda Shadow Ace Tourer- Jade Green and Cream - Rode her till she would ride no more.
darammer is offline
post #16 of 37 Old May 28th, 2018, 7:40 am
GSinNC's Avatar
It is just the micro-switch! Simple fix.
Keep up posted on the resolution.
Ed Apelian
GSinNC is offline
post #17 of 37 Old May 28th, 2018, 8:41 am
PadG's Avatar
It helps if you'd read the posts!
Pad. Gajajiva
Solon, OH, USA
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #18 of 37 Old May 28th, 2018, 8:58 am
GSinNC's Avatar
That is exactly what I did, hence my comment.
But thank you for the reminder.
Ed Apelian
GSinNC is offline
post #19 of 37 Old May 31st, 2018, 4:42 pm Thread Starter
I installed the new switch and still had the same problem. Couldn't figure it out for a while... The old switch tested bad. The new switch tested good ... So I "unmounted" the switch and held it closed in the start position with a small spring clamp. Bike started as it should with the clutch pulled in. Put the switch back and back to the problem. Unfortunately, there isn't an obvious way to adjust the position of the switch.
Has anyone found a way?
Thanks for your help
TWheels is offline
post #20 of 37 Old May 31st, 2018, 4:44 pm
beech's Avatar
There is a way to adjust position. A little 2mm allen screw to loosen the switch and move it. All upside down go slow you can figure it out I'm sure. Listen for the click as you work the lever then you have it.
Beech
beech is offline
post #21 of 37 Old Jun 1st, 2018, 6:49 pm Thread Starter
No Joy I'm afraid. I was rather hoping there would be more adjustment somewhere but thanks for the information
TWheels is offline
post #22 of 37 Old Jun 2nd, 2018, 9:37 am
PadG's Avatar
Yeah, I looked at the RepROM for you, and it seems that there is just one screw that attaches the micro-switch to the plastic part. So, it seems that the switch is supposed to fit perfectly in place. Just make sure that it's not upside-down or something stupid like that!
Pad. Gajajiva
Solon, OH, USA
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #23 of 37 Old Jun 2nd, 2018, 7:47 pm Thread Starter
"Just make sure that it's not upside-down or something stupid like that! "
MMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM ! .....
I checked the switch and there are no markings to indicate top or bottom and I assumed it, therefore, didn't matter. But thinking about it now, there are actually two switches there and one is to disable the cruise control when the clutch lever is pulled in a small amount and the other is made when the lever is pulled fulling in to allow starting in gear. So possibly it does matter which side is up. I'll give it a try.
beech likes this.
TWheels is offline
post #24 of 37 Old Jun 2nd, 2018, 8:39 pm Thread Starter
PadG ... I flipped the switch over and the bike starts in gear.
Thank you!
Patric, LAF, Nil_Time and 1 others like this.
TWheels is offline
post #25 of 37 Old Jun 2nd, 2018, 9:15 pm
mtrevelino's Avatar
Good news! Just double check that the cruise control still dis engages when using the clutch lever.
Mike Trevelino
Williamsburg, VA
2008 RT
post #26 of 37 Old Jun 2nd, 2018, 9:20 pm
LAF
LAF's Avatar
Thank you!
Way to work through the problem.
Anyone can make a mistake especially when the solution is not obvious.
Who would think that they would not make a switch up or down or indicate the operation?
Also great forum when people help out like this.
Happy you are squared away now!
beech likes this.
Lee
17.5 R1200 GSW Black Low
ATGATT I am breathing proof.
BMW MOA #135959
LAF is offline
post #27 of 37 Old Jun 3rd, 2018, 9:44 am
PadG's Avatar
Thank you!
You are very welcome! I was grasping at straws, because the RepROM didn't say anything about which side up either!
I was going to say today that the only thing left to check is the connector that plugs into the switch. If that didn't "make" the contacts properly, you will have the same problem. It could still be the connector, but this time you got it in place fully? Keep that one in mind for the future anyway.
Always good to hear of things going right!
Pad. Gajajiva
Solon, OH, USA
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #28 of 37 Old Jun 3rd, 2018, 6:46 pm Thread Starter
Now I just need some decent weather so I take a test ride
Thanks Everyone
TWheels is offline
post #29 of 37 Old Jun 16th, 2018, 4:06 pm
Remittingaxe's Avatar
Had this same problem happen last week on the way back from Americade in Lake George NY. BMW designs their bikes so that they will NOT start in gear with the sidestand down PERIOD. In my case the sidestand switch went bad causing the engine to shut down while on the highway.
Many of the BMWs have this issie most notably the adventure bike and dual sport bikes, after a little thought I decided the safest option is to bypass the switch AS LOSING POWER AT LOW SPEEDS OR IN A TURN IS NOT A FANTASTIC OPTION.
Ride safe on the Roller Coaster of life that only goes uphill
Remittingaxe is offline
post #30 of 37 Old Jun 17th, 2018, 12:17 am
beech's Avatar
Yeah, I have sent emails to bmw NA (they say no suggestions needed or accepted) that a warning light and over ride option for each key on cycle to let you start and drive with a bad side stand switch. Easy software, answer is we know best.
If you must, there are instructions on the web it by pass it. IS That BETTER BMW? You listening.
Beech
beech is offline
post #31 of 37 Old Jun 21st, 2019, 7:44 pm
Summary: The problem magically fixed itself.
I have a 2014 R1200RT with cruise control and recently experienced this same problem (Will not start except when in neutral) so I went after the clutch switch (two switches in the switch unit).
First, there seems to be some inconsistency in bikes so I though it worth mentioning that the switch on my bike is removed with a T9 torx as opposed to a hex wrench as referenced by others. Also, the switch on this bike is up/down asymmetrical so it cannot be installed upside-down. Furthermore, the switch mounts on a locating pin so adjustment is not possible.
Prior to removing the switch, I did confirm that I could hear two clicks as I pulled in the clutch lever so it seems that the switch was being properly activated. I removed the switch and poked at it with an ohm meter but since I don't know how the two switches are wired, I really didn't know what I was looking for, except that things changed when I activated the switch levers. Finally, I re-connected the switch to the bike wiring but left the switch hanging free so I could activate it manually. I then tie-wrapped the clutch handle down, put the bike in gear, held both switches and tried to start the bike. It started! I looked at the actuator lever and saw that when the clutch handle is pulled, one switch is de-activated while the other is activated. I tried the starting process while better emulating the function of the clutch lever and it started again. I re-installed the switch and it still works.
My current speculation is that either the connector contacts are marginal and the removal/re-attachment cleaned the contacts sufficiently to get things working, or the internal contacts are marginal and my repeated activation was enough to get it working. In any case, I am now more comfortable with the idea that the source of the problem is at switch so if this happens again, I will head down to the dealer and plop down the $100 ($89 MSRP) for a new switch and spend less time on the diagnosis.
KenJW is offline
post #32 of 37 Old Jun 22nd, 2019, 12:32 am
beech's Avatar
Glad it worked out. I think upside down it is hard to tell the difference between a T9 and a 2mm fitting. But it does make a difference. The T9 is used in several switch clusters and the problem is that a T8 "fits" but is not correct. You do not want to strip one of these small screws.
Beech
beech is offline
post #33 of 37 Old Feb 14th, 2020, 8:48 pm
cc cruiser's Avatar
I have 2014 R1200RTW and I too have been experiencing the same problem. When I would stall the engine and try to restart it I would have to put the bike in neutral first to restart which can be a dangerous issue. After reading through this and another forum I found out exactly where this switch was and pulled it out, cleaned the terminals and reassembled it. To test it I cable tied the clutch fully in and held the metal switch down on the contact and the bike started in gear. I re assembled everything back and now it works again. For those that aren't sure where this switch is it's right under the clutch handle. Take out the 2 screws holding the clutch handle to the handle bar and flip it over. There you will see the electrical plug that you can disconnect and then unscrew the switch which on my bike is held on by 1 small Allen screw and pull the switch out. In my case the terminals were not making good contact and I cleaned the plug and terminals and at least for now it is working again.
cc cruiser is offline
post #34 of 37 Old Yesterday, 8:50 pm
Lightbulb Re: 2010 RT only starting in neutral
I have a 2011 R12RT that would not start in gear with the sidestand up 100% of the time. After reading the above thought I'd try cleaning the clutch micro switch. I removed the switch from the clutch assembly but left it plugged in under the tank or wherever it plugs in. I used CRC QD Electronic Cleaner, pic below, on the exterior of the switch fully saturating it and pressing the switch levers while doing so. I'm happy to report that it is functions 100% of the time. I'll report back if it fails again and if so I'll order a new one.
tonyt.0906 likes this.
Black_Dog is offline
post #35 of 37 Old Today, 12:26 am
tonyt.0906's Avatar
Iím having that same issue. Itís hit and miss in first gear. 1: where did you get the cleaner? 2: do you have a picture of the clutch switch, and where, so I can clean mine?
Great Info
2013 BMW R1200RT 90 Years of Motorrad 2014 Harley Davidson Street Glide
Past Bikes:
2009 Suzuki GSX-R 600
2009 Suzuki GSX-R 1000
tonyt.0906 is offline
post #36 of 37 Old Today, 1:36 pm
Thumbs up Re: 2010 RT only starting in neutral
Great Info
Past Bikes:
Tony,
The microswitch is located under the clutch lever assembly. I removed the lever for easier access, it takes a small flathead screwdriver. PAY ATTENTION to the orientation of the switch, it actually has two switches in it, one for cruise control and one to allow it to start. That switch can be reinstalled upside down and then the cruise won't disengage without fully pulling in the clutch. I left the switch connected to the bike with the ignition turned off, placed it inside a cup and shielded the bike from overspray. BE SURE to test your cruise control function once you put it back together.
I bought the cleaner from Amazon and use if for all sorts of stuff.
https://www.amazon.com/CRC-05101-QD-...a-571170828858
post #37 of 37 Old Today, 5:36 pm
tonyt.0906's Avatar
Tony,
Thanks, appreciate it!
Past Bikes:
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
Denis75, grumpyrt
2010 RT windshield sgl0226 RT Series 20 Aug 11th, 2011 8:29 pm
Only starts in neutral cw1200lt Other K-Bikes Discussion 4 Jul 6th, 2011 9:01 pm
2010 No Polio! Rally May 22, Folsom, CA dougholck Northern California 1 May 18th, 2010 4:25 pm
How Much to Pay for Loaded 2010 R1200RT 99chromehead RT Series 10 Apr 15th, 2010 1:29 am
1985 R80 Starting problem mpillis Other R-Bike Discussion 1 Jan 5th, 2006 7:49 am
