2016 RT XM Antenna Replacement ? - BMW Luxury Touring Community
 3Likes
  • 2 Post By DaveM
  • 1 Post By LIRider
post #1 of 27 Old Jul 30th, 2016, 9:53 am Thread Starter
travel_man's Avatar
The XM antenna location for the XM radio must stink as the radio loses reception almost 25% of the time. Does anyone know if we can replace the antenna with a new one and then place the antenna in a better location? The BMW XM antenna is around $137 but there should be cheaper versions available.
I did this with my gold wing's XM antenna and it helped a lot with reception.
Travel_Man
AMA
IBA #382
travel_man is offline
post #2 of 27 Old Jul 30th, 2016, 10:26 am
slothy's Avatar
Re: 2016 RT XM Antenna Replacement ?
ive never had much luck with xm and motorcycles.
xm does make this not sure how much it helps
https://www.amazon.com/Sirius-Satell.../dp/B002HTRELU
2011 R1200RT
1978 R100/7
1973 R75/5 - For sale
slothy is offline
post #3 of 27 Old Jul 30th, 2016, 2:59 pm
iride4u's Avatar
Your problem maybe where or how the antenna is located or mounted.
2014 K1600 Exclusive
2015 R1200RTP
2018 Hyundai Tucson Limited
Colorado PGR
iride4u is offline
post #4 of 27 Old Jul 30th, 2016, 3:15 pm Thread Starter
travel_man's Avatar
l will look into it, thanks.
Travel_Man
AMA
IBA #382
post #5 of 27 Old Jul 30th, 2016, 3:16 pm Thread Starter
travel_man's Avatar
The antenna is under the front fairing where BMW mounts it ( it is the OEM XM antenna ), same way Honda did theirs. I want to buy a new one and mount it in a open location.
Travel_Man
AMA
IBA #382
post #6 of 27 Old Jul 30th, 2016, 11:10 pm
Skup1's Avatar
I have been riding across the country on My 2014 RT. No problems with reception.
Skup1 is offline
post #7 of 27 Old Jul 30th, 2016, 11:36 pm
Using old XM tech here... Roady (portable) in tankbag, with tiny "mouse shaped" antenna in tankbag clear mapcase window. Works most of the time in the flatlands of TX and the Great Corn Desert. Loses reception whenever I duck under a gas station canopy to refuel, or occasionally when I'm able to get into some of those nice "canyon roads" or "tunnel of trees" that make riding so enjoyable. Basically, appears to depend on how much "stuff" is blocking your view of the satellite in the sky, I guess. A better antenna might be able to handle a marginal signal better - but the technology does have weaknesses. As does all the BMW motorcycle audio equipment I've ever experienced... (rolls eyes)
martyg is offline
post #8 of 27 Old Aug 1st, 2016, 9:55 pm
Cat Herder
tvguy's Avatar
The '11RT had the standard little antenna that you would get with a XM Roadie. I tried to move it but there was no enough cable to move it out into open sky. I have not torn into the '16 yet but I assume its the same P.O.S.
So far the '16 has not had any issues. The '11 was crap. It would drop out whenever it felt like it. If you take the plastic off and you can see where the cable goes, I am sure you can replace it with a regular XM antenna.
Please let us know if you do that. AND take a bunch of pictures.
Tvguy
'16 R1200RT - "Golden Eye"
tvguy is offline
post #9 of 27 Old Aug 2nd, 2016, 9:07 pm
DaveM's Avatar
Would it be possible to take a couple of photos of exactly where this antenna is and what it looks like? My reception on my 16 RT is not good and would love to move the antenna or replace with one that works.
Sent from my SM-G900V using Tapatalk
tvguy and Grumpy_Squatch like this.
DaveM is offline
post #10 of 27 Old Aug 30th, 2016, 7:51 pm
Radix's Avatar
You need a bigger antenna.
--Radix
1965 HONDA 50 (sold)
1967 HONDA 90 STEP THROUGH (sold)
1970 HARLEY-DAVIDSON SPORTSTER (sold)
1971 BMW R60/5 (sold)
1980 Vespa P200E (sold)
199? Honda CB750 Nighthawk (sold)
2012 BMW R1200 GS ADV (sold)
2016 BMW R1200RT (current bike)
2017 Moto Guzzi v7iii Special (current bike)
Radix is offline
post #11 of 27 Old Aug 30th, 2016, 8:39 pm
dbaliko's Avatar
Check out this thread that I started on the sport touring forum. I'm pretty sure the same fix would work.
If you're having Sattalite radio reception/ signal problems.... - BMWSportTouring Forums
Doug
Doug
2012 R1200RT - The Green Machine
2007 R1200RT - Sold - but not forgotten
dbaliko is offline
post #12 of 27 Old Sep 2nd, 2016, 4:59 am Thread Starter
travel_man's Avatar
I bought a Siriusxm car antenna from the Satellite Radio Superstore and disconnected the built in Siriusxm antenna and connected the new one. I mounted the new Siriusxm antenna on the top box for now and the reception is much better. The new antenna cost $12.95 and had the same connector as the OEM antenna so it only took two minutes to connect it.
SiriusXM XMICRO2 Magnetic Vehicle Antenna
Travel_Man
AMA
IBA #382
post #13 of 27 Old Sep 2nd, 2016, 9:02 am
I have Sirius radios in both my 2010 Audi S5 and my 2014 R1200RT. Reception sucks for both radios, but a lot of the riding/driving I do are on back country, narrow and hilly roads with high trees. I think the XM satellites are in a location where reception is easily blocked by buildings/trees/mountain peaks. Before I had Sirius, I had an XM radio in my 2004 Audi, and I never lost reception, living in the same area. That leads me to assume that satellite positioning may be a leading cause of poor reception.
Ed
Previous: 2013 F800GT
Recent: 2014 R1200RT Quartz Blue Metallic
Current: 2014 K1600GTL Hannigan trike conversion
Scubadoc is offline
post #14 of 27 Old May 15th, 2019, 6:28 am
LIRider's Avatar
I know this is an old thread but since I found it helpful in solving my satellite reception issues, I figured I'd give it a bump and reference a post on my solution when I encountered increased dropouts after installing an accessory Nav locking product:
https://www.bmwlt.com/forums/rt-seri...ml#post1911133
I choose a solution similar to travel_man above. Although the specific antenna he choose is no longer available, there are similar ones available on eBay and elsewhere for under $30 that will suffice. I really wish I had done this when i first got the bike ... it's simple and for me at least, very effective.
A big thank you to travel_man for getting me pointed in the right direction!
Grumpy_Squatch likes this.
Current Rides:
2016 R1200RT - Platinum Bronze Metallic
Keyless Ride - Alarm - Shift Assist - Central Locking
1996 VF750C Magna - Pearl Shinning Yellow
V&H Classic II Pipes - Factory Pro Jet Kit
Race Tech Cartridge Emulators & Fork Springs
Progressive 440 Rear Shocks
LIRider is offline
post #15 of 27 Old May 15th, 2019, 10:00 am
alegerlotz's Avatar
I never have issues with my RTs Satellite radio and I use it fairly often. Its the stock setup in.. Some of it may have to do with where you're riding.
During Springtime in New Hampshire (when I lived there) the reception would cut out on all of my Sirius/XM equipped vehicles because of the canopy of leaves on all of the trees. Unless you're going to put the antenna on a 50 foot tall pole, I'm not sure how you're going to get around that.
2016 R1200RT
alegerlotz is offline
post #16 of 27 Old May 15th, 2019, 10:37 am
LIRider's Avatar
I agree that it's all situational. I had issues in some spots with the RT but only riding in one direction. Interestingly, I never have any issues in any of my cars in those very same locations. In any event, I'm happy with this particular mod
Current Rides:
LIRider is offline
post #17 of 27 Old May 15th, 2019, 4:55 pm
Grumpy_Squatch's Avatar
If you don't mind, your other thread mentioned that you "choose to install the antenna on my top box and run the cable up to the nose under the seat and side panels". On my 2019 it appears that the module with pink connector and Sirius logo is under the passenger seat. Is the 2016 different? I'm not following why you had to run the cables all the way up to the nose. If it is indeed under the passenger seat it would make such an antenna swap much easier.
Thanks!
2019 R1250RT Mars Red
  • Denali CANSmart
    • D4 driving lights
    • B6 brake light
    • SoundBomb Compact horn
Grumpy_Squatch is offline
post #18 of 27 Old May 16th, 2019, 5:46 am
LIRider's Avatar
To be quite honest, I never looked at the radio connectors under the seat ... you are no doubt correct that I may have been able to get away with pulling the connector to the extension cable right in that location. Since I was working with the Navi lock when this process began, I just naturally went for the connector in that location. Next time I've got the seats off, I'll definitely take a look for it though. Thanks for pointing it out!
Current Rides:
LIRider is offline
post #19 of 27 Old May 16th, 2019, 8:22 am
I'm not sure that would work either but I might give it a try. As someone posted about New Hampshire, here in MA the Sirius reception on this bike is often terrible. I've had Sirius in my last 3 cars and I get drops on the bike in places I've never seen drops in the car.
However, I do know that SiriusXM also uses terrestrial broadcast towers in metro areas to fill in signals lost to buildings etc. Perhaps cars are better at receiving those fill-in signals and the bike antennas aren't? I'll take the $25 risk and see if it works under the seat.
  • Denali CANSmart
    • D4 driving lights
    • B6 brake light
post #20 of 27 Old Jun 21st, 2019, 6:49 pm
Cat Herder
tvguy's Avatar
Re: 2016 RT XM Antenna Replacement? Update
Now having issues with the '16 RT Sirius. Here are what the connectors look like. They are not the same as the average connector. I tried a few different antennas and they did not fit. Called Sirius radio and they flashed my radio a few times. It worked for a little while then had to call them back.
I did order two of these to play with and see what happens
XM satellite radio antenna with pink fakra, Magnetic, Delphi 999U9-VS000
When I have time I will call the BMW car dealer and see what they got.
ID:	152731   Click image for larger version
Tvguy
tvguy is offline
post #21 of 27 Old Jun 22nd, 2019, 8:41 pm
I tried a couple of cheap antennas like the one listed above and the reception was subjectively worse. I eventually switched back to the stock antenna. I tried them mounted on the topcase with magnets and in a couple of other locations around the rear of the bike. My guess at this point is that the bike simply doesn't have sufficient metal to form an effective ground plane for these antennas and there probably isn't much we can do.
  • Denali CANSmart
    • D4 driving lights
    • B6 brake light
post #22 of 27 Old Jun 23rd, 2019, 1:05 am
Cat Herder
tvguy's Avatar
I am not a fan of Sirius hardware. My Dodge van had a Sirius radio and it was terrible. I've never had any problem with Delphi (XM) hardware. The biggest problem is BMW uses the most low-grade garbage radios on the market and now we have to figure out how to fix them to make them work.
The help desk at Sirius said they can reflash the radio system at the dealership and replace the card inside of the radio and replace the antenna. I need to check into that a little bit more and see what I can find.
Tvguy
tvguy is offline
post #23 of 27 Old Jun 23rd, 2019, 8:06 pm
wvandennoort's Avatar
Moved the stock antenna to rcu designs shelf and improved reception. The shelf also helps shade the gps.
Bill Van den Noort
2000 K1200lt
2017 R1200rt
Bmw Moa#96083
Bmw Ra #31818
wvandennoort is offline
post #24 of 27 Old Jun 24th, 2019, 6:50 am
martinbrown9722 is offline
post #25 of 27 Old Jun 25th, 2019, 10:02 pm
golf18's Avatar
I am a Audi Tech. We has a coax cable kit with those connectors in it for making repairs. Your local Audi dealer my sell you some.
Yes the sat reception is poor at times on my 16 Rt. Havenít had time to look into it yet.
Speed doesn't kill - Sudden impact does
golf18 is offline
post #26 of 27 Old Jun 26th, 2019, 10:11 pm
Cat Herder
tvguy's Avatar
Hopefully I will have the new antenna sometime tomorrow or Friday. I will try to install on Sunday or Monday and report back
Tvguy
tvguy is offline
post #27 of 27 Old Jun 29th, 2019, 10:32 pm
Cat Herder
tvguy's Avatar
Bought this from Ebay... fits great
Hooked up the pink connector and its great. temporarily laid out the cable in 16" lengths. Reception is great. Even if I get one bar the signal does not drop and still works great and does not need to re-link.
Test worked great... relocating the connection to the plug under the front end and will see how it works with the antenna taped on the plastic under the wind shield
Tvguy
tvguy is offline
Does anyone have a spare XM antenna for the Garmin 2730? 14wntr GPS 0 Jun 7th, 2012 6:23 am
CB Antenna Disconnect hschisler K1200LT 3 Mar 24th, 2012 8:08 pm
Zumo 665 + Apparent Conflict Between Bluetooth and XM Receiver RMShortley GPS 4 May 11th, 2010 1:11 pm
XM Delphi FM Converter Install MikeERideWNC Satellite Radio 2 May 12th, 2008 5:30 pm
Found a place for my XM antenna SilverBuffalo Satellite Radio 15 Oct 9th, 2005 7:40 pm
