Pump up Helmts - BMW Luxury Touring Community
post #1 of 7 Old Jan 17th, 2013, 12:23 am Thread Starter
BecketMa's Avatar
Pump up Helmts
Any one have experience with pump up helmets, pump air into inserts?
BecketMa is offline
post #2 of 7 Old Jan 17th, 2013, 8:36 am
petevandyke's Avatar
Re: Pump up Helmts
Hey, Bob
I tried the Scorpion with that feature, had to go up a size and then pump the thing about 100 times to snug it up, so it wasn't for me. I like the concept, if it fit me I'd have bought it.
P
petevandyke is offline
post #3 of 7 Old Jan 17th, 2013, 3:03 pm
Re: Pump up Helmts
I had the Scorpion, too. Fit was easy but it never held air, even after a replacement, so I just gave up on it.
Dan
dancogan is offline
post #4 of 7 Old Jan 17th, 2013, 6:42 pm
amarider's Avatar
Re: Pump up Helmts
I have had two Scorpion 1000's they fit true to size and both hold air and have never leaked in over 4 years.
Good helmet only compliant is the flip sun shield rattled a little but it's easily fixed with a little ingenuity.
John & Cathy
Northern CA
01 K1200LTC Basalt - Moose
Posse #2
amarider is offline
post #5 of 7 Old Jan 17th, 2013, 7:03 pm Thread Starter
BecketMa's Avatar
Re: Pump up Helmts
What advantage do the air bladders give you? I've seen mention of a more secure fit if one winds up in an accident; and that the bladders can reduce noise. So they make it hotter in the summer and colder in the winter?
Many Thanks
BecketMa is offline
post #6 of 7 Old Jan 18th, 2013, 7:48 am
Re: Pump up Helmts
The only advantage I've seen advertised is a "custom fit." If you have a lumpy head, I guess this would be perfect as a thicker pad on, say, your left lumpy side might cause sore spots, but the air bladder pads would conform to whatever shape your cranium might be (kinda' like those memory foam mattresses).
post #7 of 7 Old Jan 18th, 2013, 4:50 pm Thread Starter
BecketMa's Avatar
Re: Pump up Helmts
Thanks pete.
No lumps.
No pumps.
BecketMa is offline
2002 k1200lt fuel pump Sjgolden K1200LT 15 Oct 31st, 2016 2:31 pm
Installed a "new" (used) brake pump....HELP...pump "singing" all the time, no rears.. loser K1200LT 22 Jul 11th, 2014 8:09 pm
My Father purchased 2002 K1200LT with 7000 miles the abs pump stays on all the time Autodeal1 K1200LT 6 May 2nd, 2012 6:02 am
HELP PLEASE...my integ brake pump is different.... loser K1200LT 5 Mar 8th, 2011 11:09 am
BMW fuel pump vs GM fuel pump kclineman10 K1200LT 14 Feb 18th, 2011 1:48 pm
