Bmw Vest Cord - BMW Luxury Touring Community
post #1 of 4 Old Nov 11th, 2009, 8:21 pm Thread Starter
Bmw Vest Cord
I just purchased a BMW vest without a cord. Where would I get the cord that plugs into the vest? I assume that this cord plugs into the BMW accessory cord which plugs into the motorcycle.
hphammer is offline
post #2 of 4 Old Nov 11th, 2009, 8:25 pm
shoswell's Avatar
Re: Bmw Vest Cord
I assume you are speaking about a heated vest. The trick is to figure out which vest you have as BMW does not manufacture their own. I'd stop by the stealer and ask as they may know, or cruise the web and look at the connections of various makers out there. maybe 3 or 4 major ones, that you'd have to check...
Hoss
'05- K1200LT - Gretchen
MOA, IBA, EXR & RCB and TMI
shoswell is offline
post #3 of 4 Old Nov 11th, 2009, 8:33 pm Thread Starter
Re: Bmw Vest Cord
Its a black and grey heated vest with two male plug ends exposed on the vest. It only has tags on it that say BMW.
hphammer is offline
post #4 of 4 Old Nov 12th, 2009, 8:53 am
Re: Bmw Vest Cord
that is a fairly standard connector. I use an adapter that makes it a standard male negative female positive which can then be plugged into a lot of "heat troller" units that will allow you to vary the heat. Your vest came with a plug that was strictly on/off so you either boil or freeze. You might check with our own Raffy at http://www.motogear4you.com/ and if he doesn't carry something I'm sure he can tell you where to get it.
Jeff in Myrtle Beach
'01 LTC
'99 Icon champagne
'02 KLR 650
TZ 185 2 stroke
Honda R100R beater
jeffklt is offline
Garmin 550 next to BMW Zumo Oldmanwheeler GPS 23 Jan 1st, 2012 10:05 pm
BMW Recall- 2007 Models RVB1019 Bike Talk 3 Nov 9th, 2011 7:04 pm
