HJC CL-SP Helmets - BMW Luxury Touring Community
post #1 of 2 Old Nov 19th, 2005, 3:21 pm Thread Starter
gdroege's Avatar
Question HJC CL-SP Helmets
Anyone bought or tried the new HJC CL-SP helmets yet? If so, what are your opinions?
Gary & Mary Droege
1999 K1200LT
2008 K1200LT
"Life ain't about how fast you run, or how high you climb, but how well you bounce."
gdroege is offline
post #2 of 2 Old Nov 20th, 2005, 9:09 am Thread Starter
gdroege's Avatar
Hjc Helmet
I'll ATTEMPT (it's not showing up in the preview?) to attached a pic of the helmet and some of the information from their website.
FEATURES
Injection-Molded Polycarbonate Composite Shell Construction
The lightweight injection molded Polycarbonate composite shell is the latest advancement in Polycarbonate composite technology
Wind-tunnel tested aerodynamic shell shape with an extra large eye port for greater visibility.
Channeled, Dual Density EPS (expanded poly styrene) liner.
Three shell sizes provide a comfortable fit for youth and adult sizes.
Flow-Through "ACS" Advanced Channeling Ventilation System
Dual flow-through channels
2 high capacity, multi-stage, forehead intake vents
Venturi exhaust spoiler
Anti-Fog System
Side chin-bar mounted vortex vents create a low-pressure vacuum effect drawing heat and moisture out of the face shield area
Adjustable chin vent re-directs air upward and across shield interior
Anti-fog treated 3D shield.
Next Generation, 2 Stage Compression Shield Closure System
A two-stage pivot mechanism, compresses the shield into the eye-port gasket, providing an extremely secure seal
Improved, no guess work, tool-less shield removal and installation
Aerodynamic flush mounted fit for reduced turbulence
Scratch resistant hard coated shield
Optically superior 3D design
Rated at 95% UV resistant
Removable / Washable Bioceramic Nylex® Interior
Anti-bacterial Bioceramic Nylex ® liner and cheek pads quickly wick moisture away from the skin and eliminate odor causing bacteria
Streamline, wrap-around neck roll reduces wind noise
Padded chin strap design
Nylon strap retention snap
Neatly secures excess chin strap
Soft Helmet Storage Bag Included
Built-in Communication System Speaker Cavity
TECHNICAL INFORMATION
Standards: Dot-218, Snell M-2005
Construction: Injection Molded Polycarbonate Composite
Weight: 1650 grams (approximate based on size medium solid color)
Size: XS to 3XL
Gary & Mary Droege
1999 K1200LT
2008 K1200LT
gdroege is offline
Securing helmet(s) when away from bike justincase K1200LT 43 Jun 11th, 2006 7:46 am
Helmets...? Price? cfell Rider's Gear & Luggage 6 Oct 23rd, 2005 12:01 am
New Bluetooth Nolan helmets buffalo Intercom, CB, & 2-Way Radios 1 Oct 20th, 2005 9:03 pm
Time to purchase new Helmets...HELP!! justincase K1200LT 20 Oct 5th, 2005 12:02 pm
