Another Schuberth J1 Review - BMW Luxury Touring Community
post #1 of 12 Old Jul 4th, 2006, 7:25 am Thread Starter
ecirwin's Avatar
I finally got around to getting this all down on the computer. The week gave me some time to really evaluate the features. Lots of pictures at the link on the bottom and a repeat of the following text:
Out of the box:
My first impression was how light this helmet is in comparison to my 5.5 year old Arai Signet G/T. This thing feels like a bicycle helmet in comparison. All of the little finer details pictured above started popping out at me right away. That shield is definitely a jewel on the front of this lid.
The manual looks like something out of a new electronic gadget. It is huge! Then you start to look through it and realize there are 6 main language sections and even some short sections for another handful of languages in the back. The manual has 322 pages! The English portion is 50 pages. Still a lot to read, but you have to wade through a lot of the legal/safety type stuff.
Mechanisms:
The stops for raising and lowering the shield are very positive. the only thing I have found is that when I lower the shield, I may have to double check both sides to be sure they are down. The first ďupĒ position is more solid than the others. So solid, that one side can be sealed while the other is still in the open position. This could prove to be useful someday, maybe in a cross wind or something. There are very substantial pieces molded into both sides of the bottom edge of the shield for opening and closing. I am very impressed with these in size, form, and location. Very usable!
The shield release is like butter. Arai always says their shields can be replaced without tools, and they can. Problem is, that unless you do it everyday, you never get comfortable with the force and the cracking sounds created during replacement. The Schuberth mechanism is as easy as pushing two buttons and the shield is free. To reinstall, just lineup the large pin and position guide then push until it snaps. Repeat on the other side.
The chin bar is another lovely experience. There are large/long grooves on both sides to guide the chin bar into position. Then simply push until you here it click. If you are wearing the helmet, it could be helpful to put one hand on the chin bar and one on the back of the helmet and push from both sides. Otherwise, you are relying on your neck.
The sun visor slides up and down with ease using the sliding button on the left hand side. If you remove the sun visor, reinstalling it should be done carefully. This one is not nearly as easy as the main shield. You have to be sure that it is completely installed. If it isnít, you will have issues with it dragging, which makes it very hard to use. If it is dragging, double check and make sure it is completely in. Give it a good press on either side. There doesnít seem to be a positive click or any other feedback that it is in place. Too bad, since everything else is done so well.
Chin strap is the standard Schuberth affair. I am getting used to it after years of D-rings. I still have to remind myself every time I remove the helmet. It takes some time to get used to inserting the little forks into the latch, but I am getting better at it. I donít really like the velcro that temporarily holds the flaps in place. Velcro always wants to grab hold something. Sometimes that is the helmet liner, the other strap, my glove, my jacket cuff, etc. Great stuff, but very tenacious. It always grabs when you want it to, but many times it grabs when you donít want it to.
I guess I should mention the AROS (anti roll off system). The only thing I can say is that I would never know that it is there if I hadnít read about it. That is a good thing. Safety devices that are transparent are the best.
Opening and closing the main vent on the top of the helmet is a no brainer. Well, letís not go that far. I am constantly finding myself asking, ďis that position open or closed?Ē It is so easy to use, but like most helmets, unless you can visualize the opening it is hard to remember which way is open. Even with the helmet off, you canít tell open from closed. Behind the screen of the LT, it can even be hard to sense when it is open. I shave my head, so I should be able to sense it, but not always. For reference, sliding the main vent backwards opens it.
On/Off:
I have tried the S1 at the dealership. As has been said before, the experience is like rebirth. The J1 is much easier. The instructions call for removing the chin bar before donning the helmet and installing it after the helmet is on. I have not found that to be necessary. Removing the chin bar does make the helmet more flexible. If you have a wider head, this could be a benefit. My head is more of a long oval shape. For me, I would say that putting the J1 on requires about 20% of the effort for the S1 and even 60% of the effort for the Arai.
Fit/Feel:
This helmet has been very comfortable so far. I have done any multi day riding yet, but it has been great on my commutes. There does seem to be a little bit of pressure on the back of my head in two small areas on the top left and right. Only time will tell if this is truly bothersome or not.
Visibility:
One of the most impressive things. It is possible to even forget you have a helmet on. You have to try and see it. At the same time, I still feel protected. Maybe I am kidding myself, but confidence and security go a long way to being a good rider.
The sun visor is a nice addition. I do wish that it came down lower though. Too much light comes in at the bottom edge for my liking. The sun visor can be flipped so that the straight edge is at the bottom. I found that even more light comes in at the bottom in this position. It seems that the bottom edge is in about the same position as the top of the nose cutout when it is flipped.
The built in reflectors are a nice touch. Even smarter is that they are protected in the front by the shield. So they will not be damaged by debris over time. I have to say that I removed the Schuberth decals. I just donít like branded decals. The good news is that they were not clear coated onto the helmet. A plastic putty knife and some Goo Gone and they were removed in 20 minutes. They did have some reflective safety factor to them. I should add some reflective tape to improve my visibility. There is another reflector built into the fabric on the back edge of the helmet. Nice touch.
Dynamics:
This helmet is an improvement over the Arai for sound. Many others have noted that 3/4 and even 1/2 helmets have been quieter for them than full face units. So far I have been very impressed with the reduction in wind noise. I think that cross winds will always be an issue with any helmet, but the J1 does seem to handle them fairly well.
It does seem that the shield blocks the upper vent when it is opened any further than the first click. This could be caused by the size of the screen on the LT and the general direction of airflow behind that sucker. I have to get more experience with this. I also just installed my VStream windscreen, so that could change things (maybe better or worse). I like having the shield up a little to get air around my face, but I also need some circulation in the helmet. My first multi-day ride is not until August, that will be the real test.
Handling/Storage:
I am so used to handling my full face helmet by the chin bar. It is something I am adjusting to on the J1. I end up holding it by the cheek cover areas instead.
The chin bar is designed to pull off during an accident. This could prevent a serious neck injury. Very nice thought! That also means it could come off at an inopportune time as well. Basically, donít carry the thing by the chin bar. If it pops out because you have something in the helmet or you swung it too hard, you helmet will crash without your head in it. Of course Schuberth would recommend replacement at that point. Not many of us would replace a $550 helmet for a drop on the ground, not matter what the manufacturer says.
The helmet fits snugly into the LT top case. I havenít tried it in the saddle bags yet. I wear the XXL (62/63) in Schuberth sizing.
The pics:
http://web.mac.com/ecirwin/iWeb/Site...6A21D2E68.html
ecirwin is offline
post #2 of 12 Old Jul 4th, 2006, 10:43 am
So is the $550 retail or purchase price? That is a great looking helmet. I am looking for a 3/4 to compliment my 1/2 helmet. Great review too.
"Lately it occurs to me, what a long strange trip it's been." Jerry Garcia
nightcrawler921 is offline
post #3 of 12 Old Jul 4th, 2006, 2:44 pm Thread Starter
ecirwin's Avatar
That price was delivered to my door from:
http://www.motowebshop.com/en/shop/h...j1_premium_jet
Ä 399,00 = $510 U.S.
The delivery time was not so great. The helmet was on backorder for several weeks and then it shipped via USPS, which took about 2.5 weeks more. Roughly 6 weeks from order to delivery. I'm glad I wasn't in a hurry. Of course if they have the helmet in stock, it would come much sooner. Supposedly, this helmet is in short supply right now. If you've got time, MotoWebShop (Netherlands) was a good vendor and they seem to have the best price that I could find. UK stores are charging much more, and some don't ship to the U.S.
Also, be advised, this helmet is not approved for use in the U.S. It even states that in the manual. Don't ask me why. It meets the EU standards, but there must be some detail in the DOT test that it isn't meeting. I have been pretty happy with the German engineered products I have purchased. I have no doubt that this helmet is as safe as a helmet can be. I have always worn full face helmets (Arai and Bell). This was the only 3/4 helmet that I feel comfortable with. The protection is reduced from full face, in terms of a frontal impact, but the break away chin bar offsets that reduction in my mind.
So far, I would highly recommend this helmet. I took a 140 mile ride today and the helmet was never uncomfortable. It is in the low 80's today and the venting worked fine. The upper vent seems to get blocked if the shield is up to the third notch, but the first two notches are enough for air on the face.
Beware of the noise when fully closing the shield. That is something I forgot to mention above. It makes one hell of a "clank" when you push it down that last notch. It is like ringing a bell, with your head in the bell!
Eric
ecirwin is offline
post #4 of 12 Old Feb 16th, 2007, 11:09 am
sheldan2's Avatar
Smile
I have had my j1 for about a month now, as this is my first schuberth, I cannot compare to other models, but I am very impressed with it, light and quiet, and the visibility is outstanding, I have just ordered another for my s.o.
sheldan2 is offline
post #5 of 12 Old Jun 9th, 2007, 10:06 am Thread Starter
ecirwin's Avatar
It has been close to a year since I first bought this J1. I have never been sorry I spent the money on it. It is very rare that I even notice I have it on. Everyone that expresses an interest in it, seems to really like it.
Update to the statement above about the noise when completely closing the shield. It must have broken in a little, because the noise is much diminished when closing it that last notch. Also, both sides will completely close when you push down on one side of the shield. At first, the opposite side would stay open by that one notch.
I just ordered another for the SO from the same place. I'll give an update on the shipping time when it arrives.
Eric
ecirwin is offline
post #6 of 12 Old Jun 9th, 2007, 10:32 am
atrovarious's Avatar
Nice write up, wish I had that kind of time.
MHO, that is certainly the ugliest thing I've ever seen.
I am interested in your performance comparison of the wind screens.
Ghaison (Jason)
2004 K1200LT FOR SALE!!!
Bluefield, VA
atrovarious is offline
post #7 of 12 Old Jun 9th, 2007, 12:19 pm Thread Starter
ecirwin's Avatar
That's too bad. To each his own I guess. I feel the J1 is one of the best looking helmets.
I have found that I like the CeeBailey more than the VStream, but the VStream is better than stock. I do think that there are too many variables in the complete rider/motorcycle system to declare one windscreen the "best".
ecirwin is offline
post #8 of 12 Old Aug 15th, 2007, 7:31 pm Thread Starter
ecirwin's Avatar
Just a quick update to say that it took about 4 weeks to receive the helmet for my SO. She really likes it, but doesn't have any experience with other helmets, other than loaners that never fit her very small cranium. We did a 1000 mile weekend trip and she never complained about the helmet once. Of course, she isn't much of a complainer generally, especially about a gift.
The one difference between her and I, relative to this helmet, is that she needs to disconnect the chin bar on one side to comfortably remove it. I have read other reviews where people have mentioned this, but it isn't an issue for me. I guess I have a fairly "long oval" shape to my head.
It does seem that there is only one shell size for this helmet. Her's is on the small side of the spectrum and mine on the large, but the shell's are pretty much indistinguishable.
That is all for now.
ecirwin is offline
post #9 of 12 Old Jan 28th, 2008, 4:49 pm
J1 + Installing a Headset
Well my J1 arrived and it actually fits pretty good. A little snug at the cheek pads but its brand new so I think it will break in just fine.
I have settled on the EdSets brand since they have a low profile speaker and the owner "Ed" was pretty good about figuring out which microphone to use on the BMW / J+M comm system.
The issue I have is installing the headset. I hate to take this on myself. I didnt make the install on my C1 6 years ago for the same reason. "NO Experience"
Finding someone who has the expertese on this install is getting to be a problem. Schuberths are tough to work on.
I have attached a couple of pics that I found on the net "European Probably" which show two different types of installations. I prefer the one that doesnt penetrate the cheek pad.
If anyone has a suggestion here I would welcome it.
Steve A
Name:	Mic behind and not thru cheek pad.jpg
ID:	16306   Click image for larger version
stevea2980 is offline
post #10 of 12 Old Feb 6th, 2008, 6:19 pm
Headset installed in a J1
Well Boys and Girls:
I have my J1 almost back home and the Headset is installed. It took plenty of research and cordination between myself and "ED" of EdSets.com to finalize which Mic works best with the BMW comm system. The mic we picked works better than my AirRider system that I have presently in my C1.
I would have no hesitance in recommending EdSets to anyone interested in trying there products.
See attached installation pics.
Later All
Steve A
ID:	16482   Click image for larger version
ID:	16483   Click image for larger version
ID:	16484   Click image for larger version
post #11 of 12 Old Oct 19th, 2008, 6:51 pm
WylieCoyote's Avatar
Re: Another Schuberth J1 Review
The helmet is truly innovative and looks awesome.
I couldn't find anyone that would even attempt to install a J&M headset into it, so I bought a couple of the Nolan models with J&M headsets installed. I had to decide which I wanted more..
Mine was $550 when I got it a couple months ago.. I never wore it except to try it on..
I just listed it on eBay (10/19/2008) if anyone wants a bargain.. It is gloss black in size L.
eBay Listing
Brownlow Mullins
Laurel, Maryland
Retired Police Officer
Accident Reconstructionist
2005 K1200LT
WylieCoyote is offline
post #12 of 12 Old Oct 29th, 2008, 8:25 am
LAF
LAF's Avatar
Well I was the winner on the e-bay item above and have to say I am VERY pleased with this helmet.
I wear a Large Nolan and this in Large fits like a glove. Rode in to work this am 39 at 6:00 am and it was GREAT!
First thing is weight, there is none. The next is quiet it is WAY more so then my Nolan Flip. With the visor open it is pretty quiet, but put it down and it really shines.
Little bit of wind on the chin but not where I was really cold or anything. Lot of wind this am and only cross winds bothered me, and then only a bit as far as getting into the helmet.
While I hate spending the kind of money it takes to get to this level of protection and quiet I am very happy I spent it.
I have to say their claims on DB has to be correct and it is amazing how well it works.
The one thing I have been playing with on all the helmets I own is windshield height. It makes a huge difference with just the slightest adjustment to height. Now I am using a Cee Bailey #2 -6 because I dont ever want to look through it unless I am in rain. I have to raise it about 2" and I am in the quiet zone for this helmet. I can see well over the top of the screen and the J1 is quiet.
All in all it will be my main go to helmet all year round here in PA. Cant say enough good about it.
The only other helmet that would interest me is the new C3, but it will never be able to have the amount of view the J1 has.
Good Stuff!!!!!!!!!!!!!
Lee
17.5 R1200 GSW Black Low
ATGATT I am breathing proof.
BMW MOA #135959
LAF is offline
Schuberth C2 & J&M jsr Rider's Gear & Luggage 8 Nov 3rd, 2006 4:06 pm
Schuberth Heated visor leemans Rider's Gear & Luggage 7 Jan 6th, 2006 3:58 am
Arai vs. Schuberth ecirwin Rider's Gear & Luggage 6 Oct 31st, 2005 10:40 am
