How the heck should I do this? - BMW Luxury Touring Community
post #1 of 12 Old Oct 19th, 2015, 1:11 pm Thread Starter
BobbyB26's Avatar
Back in Sept we did a 5 day trip out to Montana and back. I wrote up a ride report but it got pretty lengthy with the pics and all. Is there an easy way to post it without it getting all messed up?
Steve and Shari Kramer
2009 BMW R1200RT
2008 BMW R1200RT (wife rides, I fix)
Sedro Woolley, Washington State
BobbyB26 is offline
post #2 of 12 Old Oct 19th, 2015, 2:04 pm
PadG's Avatar
Re: How the heck should I do this?
Nothing is ever easy!!
I would love to see what you ride report, and perhaps you can look to see what I did for my ride report:
http://www.bmwlt.com/forums/ride-tal...nd-2015-a.html
PS: I first compiled the ride report in MS Words (you can use anything, offline) and then copy/paste them into the actual posts. I also had the image insertion codes in the offline compilation, and named the photo to go along with it. Do remember that you can UL only 10 pictures per post, and that is why my reports were broken up into multiple parts.
Pad. Gajajiva
Solon, OH, USA
2007 R1200RT (Sold!)
Once Upon a Time........
1963 Norton Dominator 650 SS
1960 Triumph Thunderbird (6T)
1952 Triumph Thunderbird (6T)
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #3 of 12 Old Oct 19th, 2015, 2:55 pm Thread Starter
BobbyB26's Avatar
After reading your Scotland report I was hoping you'd respond to this as I liked what you did. I'm not really sure what "image insertion codes" are? I'm sure my ignorance is showing through here. I did the same thing you did and have it in a word doc including all pics in the right spots; so my idea was to "screen capture" the doc in small sections and post them as separate pics in the thread. Suppose that'll work?
2009 BMW R1200RT
BobbyB26 is offline
post #4 of 12 Old Oct 20th, 2015, 8:55 am
PadG's Avatar
Thanks. I am still working on my "day 5" report! I need to ride when the weather is good, and so took my time doing the writing.
OK, with this forum software, when you upload pictures it will appear as "thumbnails" at the bottom of the post, and not in the body of the post. To get the images into the body of the code, you need to do some simple coding. Basically, wherever you want to show the picture in the body of your post, you need to put in [img] follows immediately with the url of the picture with no spaces and then close with [/img], again making sure that there are no spaces in between the first and last [].
How do you know the url of your picture? After you upload the picture(s), click on the thumbnail, and a new window or tab will open (depending on your browser's configuration) showing that picture. You want to click on the address box of your browser and copy everything in there to paste in between the two [] that I had described above. Here is an example. I will UL a picture, and show you the coding using "{}" instead of "[]" to show you what the coding will look like, because the one with the "[]" will show the actual picture:
Coding:
{img}http://www.bmwlt.com/forums/attachment.php?attachmentid=92193&stc=1&d=14453487 39{/img}
Inserted Picture:
With the above in mind, when I do my offline compilation, I will insert the [img] and the [/img] coding wherever I want to show a picture, and since I don't know what the picture's url is going to be, I name my pictures 101, 102, etc instead, and use those id in between the []s. This way, when I copy and paste the compilation into my ride report posts, I can easily replace the 101, 102, etc id with the actual url of those pictures.
There might be an easier way to do it, but this is what worked for me! Oh, if you want to defeat the 10 pictures per post limit, you could upload your pictures to a public picture hosting site, and use the url from those location for your image coding! Personally, I prefers to break up long post anyway, and so the 10 picture limit is fine for me.
I hope that the above is clear! It's beautiful outside today, and so I am going riding now!!
Name:	011 Botanical Garden (Comprs).jpg
Pad. Gajajiva
Solon, OH, USA
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #5 of 12 Old Oct 20th, 2015, 9:18 am Thread Starter
BobbyB26's Avatar
I'm going to give my idea a try as it may just work. If it doesn't, I'll be going back to what you wrote to learn something new. Thanks.
2009 BMW R1200RT
BobbyB26 is offline
post #6 of 12 Old Oct 20th, 2015, 9:23 am
mtrevelino's Avatar
You could also convert either the whole Word document or parts of it into PDF files.
Mike Trevelino
Williamsburg, VA
2008 RT - Sold December 2019
mtrevelino is offline
post #7 of 12 Old Oct 20th, 2015, 9:31 am Thread Starter
BobbyB26's Avatar
Yep thought about that too...is there an advantage to a PDF over a word doc?
Also considered posting the report to an external site and then just pasting a link into the thread. I think it'd work, but I think people would prefer to have the story already in front of them.
2009 BMW R1200RT
BobbyB26 is offline
post #8 of 12 Old Oct 21st, 2015, 8:53 am
PadG's Avatar
Saw your posts! That's a new idea!
Pad. Gajajiva
Solon, OH, USA
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #9 of 12 Old Oct 21st, 2015, 11:45 am
mtrevelino's Avatar
Yep thought about that too...is there an advantage to a PDF over a word doc.
No. Just that the PDFs would become non editable. But I forgot that you can attach either type of file on this forum.
I also saw your posting. At first I could not read the text but I double clicked on each jpg file and it opened to the full page.
Mike Trevelino
Williamsburg, VA
post #10 of 12 Old Oct 21st, 2015, 2:22 pm Thread Starter
BobbyB26's Avatar
Yeah, it was a little different approach to keeping the doc true to it's original. Only down side is that each pic within the story can't be opened up separately and enlarged. You think this approach will work?
2009 BMW R1200RT
BobbyB26 is offline
post #11 of 12 Old Oct 21st, 2015, 3:19 pm
mtrevelino's Avatar
To me, it is a pain to have to open and enlarge each jpg, but it will work. With with a Word or pdf file(s), once opened, you could scroll through multiple pages and enlarge it to take up the full screen (on a desktop pc). You may have been able to get eight or ten pages into one file. But in either case, great write-up!
Mike Trevelino
Williamsburg, VA
post #12 of 12 Old Oct 21st, 2015, 4:18 pm Thread Starter
BobbyB26's Avatar
Thanks. I've always thought that the ability to post ride reports with pics is cumbersome. I've been staying away from it for this very reason....could be why we don't see too many reports? Maybe this will spur others to better approaches.....
2009 BMW R1200RT
BobbyB26 is offline
Where the heck is the starter? Raymarks K1200LT 15 Mar 29th, 2015 8:34 pm
Heck With A New Bike-i Want One Of These! Lynn_Keen Chit Chat 2 Apr 12th, 2012 7:49 am
southern_nj what the heck did you do!!! ebiss9 K1200LT 17 Feb 18th, 2012 6:32 am
Flipping heck!!!!!! grahamw Chit Chat 7 Sep 10th, 2008 11:52 pm
What the heck is HD radio???? rando Bike Talk 8 Mar 31st, 2007 7:10 am
