V1 Windshield mount.... - BMW Luxury Touring Community
post #1 of 9 Old Jul 10th, 2009, 2:09 pm Thread Starter
Vectorprime27's Avatar
Question V1 Windshield mount....
I'm getting ready to head out on my first "long" ride. Since I'll be crossing 6 states, I thought I might pull the V1 from the car and put it on the bike - when the inevitable question of mounting came up. I've had the suction cup mount in my car for a couple of years and it has never broken loose. What do you guys think about using that mount (just above the instrument cluster) on the windshield of my LT? Has anyone tried this? Since it's temporary I thought this might work. BTW, I know it's unprotected from the weather....then again, I'll simply stow it away if I encounter rain as I rarely exceed the speed limit in the wet stuff. Any suggestions are always appreciated.
Vectorprime27 is offline
post #2 of 9 Old Jul 10th, 2009, 2:22 pm
cluainsi's Avatar
Re: V1 Windshield mount....
I use a garmin nuvi 250 with a suction mount on the screen just above the instruments. I have never seen it fall off provided the bond has a complete ring on the suction cup, visible from the front. Also because of the position tucked under the screen generally it does nor get wet. Just put a safety cord to the windscreen mount.
cluainsi is offline
post #3 of 9 Old Jul 10th, 2009, 2:56 pm
cluainsi's Avatar
Sorry thought you were talking about a SatNav.
cluainsi is offline
post #4 of 9 Old Jul 10th, 2009, 3:55 pm
SilverBuffalo's Avatar
I tried my Valentine on the windshield with the suction mount,
it came of when I hit some rough road,
I mounted mine on the right side handlebar so it can still see behind me with this mount.
It works very well.
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
post #5 of 9 Old Jul 10th, 2009, 4:14 pm
Moot's Avatar
On my R 12 C I have my Valentine attached with lock and loop (super Velcro) to the clutch resevoir cover. On the R 12 RT it is attached to the top of the "dash" with lock and loop. Never had a problem. I also use a Legal Speeding cover for waterproofing. For a windshield mount, rather than trust suction cups, look at the Legal Speeding windshield mount system.
http://www.legalspeeding.com/products.htm#AWM
2004 R 1200 C (Fire Starter)
2007 R 1200 RT (Heavy Feather)
2008 Ducati 999 S (Shock and Awe)
Moot is offline
post #6 of 9 Old Sep 27th, 2009, 2:57 pm
atrovarious's Avatar
It won't work.... I tried it several times different ways.... even with new cups.... it always works it's way loose.
Ghaison (Jason)
2004 K1200LT FOR SALE!!!
Bluefield, VA
atrovarious is offline
post #7 of 9 Old Sep 27th, 2009, 4:20 pm
Gold Supporter
Lonewuff's Avatar
Mounting it is one problem, hearing it is entirely different. I went with a RAM mount from Cycle Gagets and a Radar Screamer. I put the unit on my right handle bar like Hans, so it can still receive to the rear, but I put it in a weatherproof box (Legal Speeding). When not in use you can remove the RAM mount, box and all. All the mounts, Radar Screamer and box are available at Cyclegagets and they will treat you right.
Besides once you get used to having it on the bike you will probably want to keep it on there.
Jerry
2008 FLHTCU White Pearl
Lonewuff is offline
post #8 of 9 Old Oct 2nd, 2009, 5:15 pm
rdtebeau's Avatar
I mounted my detector in the Legal Speeding moto locker radar box and used the Marc Parnes Visual Alert. Mounted it all on my added on dash tray and hardwired the detector into my electrical system. Just did a trip from GA to CA and back (5000 mi) with no problems, it all worked great. I attached the visual alert with velcro on two sides so I could position the alert at different angles for day vs. night. I could see the visual alert in the daytime and at night it will blind you if you don't reposition it. I really liked the way it all worked for about $140 total. Ordered it all from www.cyclenutz.com.
Randal Tebeau
Blairsville, GA
CMA National Evangelist SE Region
BMWMOA, AMA, ABATE
2006 K1200LT
1996 F650
rdtebeau is offline
post #9 of 9 Old Feb 20th, 2010, 3:03 pm
AFineRide's Avatar
I mounted mine using the RAM magnetic mount and an arm connected to my Migsel. It comes with a magnetic plate that you attach to the RD and it sticks to the plate like glue. It won't come off unless you want it to come off.
You don't need a Migsel, you could mount the RAM plate and ball to the handlebar or other location. I bought it at Cycle Gadgets. (Hope that was ok). Hope this helps.
2009 1200 RT
2010 STriple
1976 R90/6
2002 FLSTF
2009 G650 GS
1976 DT 250B
AFineRide is offline
V1 How to mount? pieceofficer K1200LT 21 Mar 29th, 2013 2:39 am
Bent windshield mount. Hackercraft792 K1200LT 0 May 20th, 2008 7:39 am
Broken windshield arm retaining pin holder on the plastic mount jers99lt K1200LT 9 Mar 25th, 2008 7:03 am
RT specific mount and accesories for V1 nazdravanul Radar Detector 2 Jan 5th, 2007 6:36 am
$1.25 V1 Weather Protection ErnieA Radar Detector 10 Jul 2nd, 2006 6:49 pm
