Sena Escort 8500 - BMW Luxury Touring Community
post #1 of 7 Old May 30th, 2017, 1:34 am Thread Starter
drmajor's Avatar
Sena Escort 8500
Any good ideas on getting the 8500 into the Sena 20s?
I tried their bluetooth unit, but all I got was a slight bump-- had to be listening for it. Also, according to Sena, it is LOW priority..Not what you want.
Suggestions??
David Major
Charleston, SC
-2003 LT
-2007 GS Adventure. White
drmajor is offline
post #2 of 7 Old May 30th, 2017, 10:08 am
TF1200RT's Avatar
Re: Sena Escort 8500
Don't know if you would want to go this length, but I used to run an Escort 8500 on my '05 RT through a Mix-It2 amp to a Sena SMH10 because I couldn't hear the navigation and the music. I ran output from a Zumo 660, Escort 8500 and an MP3 player from an iPhone. I paired the phone to the SMH10 also. See attached PDF. I also had a USB adapter for charginh when I needed to charge my Sena, iPhone and bluetooth dongle.
2009 K1300 GT
2005 R1200 RT - gone
1984 Kawasaki ZX750-E1 Turbo
1990 Kawasaki ZX600R
2008 Honda CBR1000 RR - gone
[SIGPIC][/SIGPIC]
TF1200RT is offline
post #3 of 7 Old May 30th, 2017, 10:37 am
Which bluetooth transmitter dongle did you use?
post #4 of 7 Old May 30th, 2017, 11:16 am
TF1200RT's Avatar
The one I used is no longer available, but one like this will work. Transmitter. The problem with just plugging a transmitter into the Escort from what I heard is that there is no constant polling between the transmitter and detector, so you get a delay on transmit. When it is plugged into an amp the way I used it, it was always communicating with the amp so it picked up the signal from the detector instantly.
2009 K1300 GT
[SIGPIC][/SIGPIC]
TF1200RT is offline
post #5 of 7 Old May 30th, 2017, 12:56 pm Thread Starter
drmajor's Avatar
Good input!
Didn't know the TX & RX needed constant connection...
I had thought of an amp...
Good solution..Shame SENA does not have a solution..Maybe a TX Dongle with a small carrier wave signal(low power) to maintain the input.
Wonder if a small amp connected in line between thr 8500 and the BT TX would maintain it?
David Major
Charleston, SC
-2003 LT
drmajor is offline
post #6 of 7 Old May 30th, 2017, 1:32 pm
TF1200RT's Avatar
It's not a Sena problem, the bluetooth dongle that I was using needed to see output or it would go offline, that's why I used one that could be recharged while it was in use. The dongle would last about seven hours on a charge but the Sena would work for ten hours.
2009 K1300 GT
[SIGPIC][/SIGPIC]
TF1200RT is offline
post #7 of 7 Old May 30th, 2017, 1:37 pm
TF1200RT's Avatar
A small amp like a Boostaroo would probably work, but the output from the 8500 is mono. All of the amps will probably will be stereo, that's why I used the Mix-It2. It has a mono input for radar detectors.
2009 K1300 GT
[SIGPIC][/SIGPIC]
TF1200RT is offline
escort 8500 help sanjaun2 Radar Detector 10 Jun 15th, 2009 6:54 pm
Escort Pasport 8500 On Ebay Razmataz Radar Detector 0 May 29th, 2009 3:50 am
Buy an Escort 8500 on eBay? zippy_gg Radar Detector 7 Apr 13th, 2007 1:55 pm
Escort 8500, Bel RX65 and Valentine V1 strsout Radar Detector 17 Apr 8th, 2006 9:43 pm
