Valentine V1 & 2006 VOICEII Audio Connection - BMW Luxury Touring Community
post #1 of 9 Old Jun 28th, 2006, 6:02 pm Thread Starter
I read the following thread (http://www.bmwlt.com/forums/showthread.php?t=7099) and believe I have decided on getting the Valentine V1.
However, after receiving an email from J&M that they do not make a cable or modify the V1 to work with the 2006 VOICEII, I am wondering if anyone has any suggestions.
I would rather not use the AUX port as that port is not active unless AUX is selected, thus I would not hear any alerts when not using the AUX.
I'm I missing something?
Mark
MarkEngland is offline
post #2 of 9 Old Nov 1st, 2007, 9:07 pm
V1 Audio and 2005 Voice
I have the same question. Anyone have information on interfacing Valentine audio with Voice on 2005 K1200LT
barney is offline
post #3 of 9 Old Nov 1st, 2007, 9:19 pm
Old Dawg
scottydawg's Avatar
In case you didn't know (although at this point you probably do) J&M does not make the VoiceII.
Scott
Sacramento CA
HDDC Posse
''03 Ducati ST4S with ABS - '12 KTM 500EXC - '19 BMW GS/A
(Jessica Focker's) '15 BMW S1000RR - '17 KTM 350EXC-F - '09 Yamaha XT250
Some of the most asinine things people do are typically preceded by the two words "Watch this."
scottydawg is offline
post #4 of 9 Old Nov 12th, 2007, 3:28 pm
On my 2005, I tapped the output from the V1 remote audio adapter into the VOICE unit using the input for the GPS. It has worked very well in that it will mute the music for the alarm. If you do that, you will need to add a ground loop isolator to the V1 output. If you also have a GPS, you will need to make a very simple passive mixer to combine the audio from the V1 and GPS.
- Kirk Simons -
2005 K1200LT - LeRoi
1988 NT650GT - One of these days
1986 VFR700 - VFROOM
LeRoi is offline
post #5 of 9 Old Nov 13th, 2007, 3:40 pm
GBaker's Avatar
If you have a CB or GPS with a plug for a mp3 or cd player would that not work. Making a cable is not that hard just a pain in the @##.
I had a local TV repair shop make a couple for me. Be sure to use shielded wire.
Radio shack has all you need to do it just need to know if two pole or three pole plugs and if 2.5 or 3.5 mm plugs on which end. Having the cable that comes with it helps re verifing the continuity to which connection.
GBaker is offline
post #6 of 9 Old Nov 14th, 2007, 11:44 pm
Question Help With GPS & Radar To Voice II
Does anybody have this figured out? I'm trying to interface a Garmin ZUMO 550 audio out which includes the XM output plus a Valentine 1 audio out into the Voice II on a 2007 K1200LT. Any help would be most welcome.
StevenC56 is offline
post #7 of 9 Old Nov 21st, 2007, 6:21 pm
Sounds like a combo of above. your Zumo would go to the GPS input. Maybe the trick would be to get a "Y", put that into the Voice-II GPS port and then put the V-1 and Zumo into the "Y".
The trick though is that the Zumo has XM and mp3 (?).
So maybe plug the Zumo into the Aux to get your music, I think the Zumo would mute it's own music volume for directions and then put the V-1 into the GPS port on the Voice II. Yeah, probably the second configuration...
used2jeep is offline
post #8 of 9 Old Feb 24th, 2008, 6:56 pm
Re: Valentine V1 & 2006 VOICEII Audio Connection
I recently purchased a 2007 LT and am still in the process of figuring all the electric/audio inputs and outputs out. I was looking for a much longer cable to used for my Blackberry to I could mount it outside the little box they want you to put it in. I found http://www.mycableshop.com/index.asp. They seem to have just about any kind of cable you could possible want or they can create it in any length needed. Not sure if this will help but worth a try for the connection.
jrowlandesq is offline
post #9 of 9 Old Mar 9th, 2008, 3:32 pm
Thumbs up Re: Valentine V1 & 2006 VOICEII Audio Connection
I have a 2002 LT with the BMW Comm system.
I saw a note in the doc that there was a connector for radar audio.
It took me 2 days to find it, but here it is:
Radar audio input is located in the left handlebar cover
3 wire connector (same as GPS connector)
Red = 12V power when key in ON position
White = Audio input for radar
Black = ground for both audio and 12V
Works great for me - GPS and radar audio mutes my audio as expected.
RickC is offline
Garmin 2730 audio connection to Autocom wcarter GPS 5 Jan 8th, 2011 9:12 am
Escort 8500, Bel RX65 and Valentine V1 strsout Radar Detector 17 Apr 8th, 2006 8:43 pm
Does the Valentine have audio out? hammick Radar Detector 1 Oct 24th, 2005 10:51 pm
VoiceII GPS audio in: Help please hammick Intercom, CB, & 2-Way Radios 2 Oct 24th, 2005 7:36 pm
