want cruise control on 2000 r 1200 c boxer - BMW Luxury Touring Community
post #1 of 13 Old Mar 23rd, 2014, 7:37 am Thread Starter
good am, i just bought the boxer 27k miles and the only only option is ABS.
i own a '09 triGlide,87 sporster,79FXEF, & the boxer.
is there options to get some cruse control for this bike. it has 1 throttle cable
going to the grip. looked at dozens of general items on e bay. thanks lb
brownfoxx1 is offline
post #2 of 13 Old Mar 24th, 2014, 3:43 am
Gruivis's Avatar
Re: want cruise control on 2000 r 1200 c boxer
I'm not aware of an oem control but in the mean time try using a Throttle Rocker. It will take pressure off maintaaining a set speed.
Your bike is setup similar to the C I used to own. Miss that bike!
Airwolf - 2018 K1600GTL (planned acquisition!)
2005 Charcoal LT - 48K
2003 Antracite LT - 76K
2001 R1200C 24K
1999 Honda Magna - 5K (RIP)
Gruivis is offline
post #3 of 13 Old Mar 24th, 2014, 7:47 am
05hexhead's Avatar
There has been some conversions on the Chromeheads site. Lots of info for other aspects of your new C
http://www.chromeheads.org/discus/me.../6/411646.html
Nick
'05 R1200RT
'00 R1100S
'01 R1200C Phoenix
'04 R1200C Montauk
'95 R100R Classic
'84 R80RT (naked)(sold)
'94 R100GSPD (sold)
'84 R100S (wannabe)(sold)
'97 R1100RSL (sold)
'81 R100 (sold)
05hexhead is offline
post #4 of 13 Old Mar 24th, 2014, 9:27 am
taylorjn's Avatar
You may want to check out McCruise . com. Have installed several. All work well. Even have one on our 08 CanAm Spyder (which works as well as the OEM unit on my K12LT. Yeah, they are in Australia, but the support they give is tops.
Jim Taylor
Minneapolis
07 Black LT "Dancing Heart", 03 Quantum "Ice"
02 Black LTC "Raven" (RIP 8/26/06)
08 Can-Am Spyder (hers) (#731)
taylorjn is offline
post #5 of 13 Old Apr 30th, 2014, 12:25 pm
lkchris's Avatar
You can spend 50 cents at True Value and get an o-ring that you insert between your handgrip and the bar-end weight and it will serve quite nicely as a cruise control.
Unlike what I think are dangerous products (throttlemeister, etc.) you can just roll off without having to disengage anything.
Kent Christensen
Albuquerque
lkchris is offline
post #6 of 13 Old Apr 30th, 2014, 1:51 pm
kk610lt's Avatar
I have a Throttlemeister. Nothing to dis-engage. You can just roll it off even if you have it set tight.
McCruise is true electric cruise control.
Throttlemeister, Vista Cruise and o-rings just sort of hold the throttle/grip in a desired position. Good for some short time hand relief but not the best for keeping a set speed for an extended length of time.
kk610lt
2007 K 1200 LT
2004 R 1150 GS Adventure
2002 K 1200 LT (totaled by a SUV 10-7-08)
1988 Concours
Why do bullets bounce off of Superman, but he ducks when you throw a gun at him?
kk610lt is offline
post #7 of 13 Old Apr 30th, 2014, 6:04 pm
njl4's Avatar
Here is a link to install a real cruise control on your r1200. It works great and not to bad to install.
http://www.ibmwr.org/ktech/k11cruise...eInstall.shtml
Good Luck, Ride Safe
njl4
96 R1100RT
85 K100RS
njl4 is offline
post #8 of 13 Old Dec 29th, 2014, 8:14 pm
Tricky_dickey's Avatar
If you go to the Chromeheadsforum I bought a throttle lock there- it was under $25.00 easy install
Tricky_dickey is offline
post #9 of 13 Old Jan 2nd, 2015, 11:28 am
Hammam's Avatar
You don't seem to ever have used a Throttlemeister. I've had one on a couple of bikes, and it is NOT a dangerous product, nor is Kaoko for that matter, if you know what you are doing, like everything motorcycling, and use it as recommended. You do NOT have to disengage anything. Just roll off the throttle and it disengages itself easily. OTOH, an o-ring between grip and bar-end, now THAT sounds like a dangerous idea. If the idea is to create enough friction to hold the throttle open, then how do you disengage THAT? Just quickly unscrew the bar-end, remove the ring and apply the brakes?
No, I've no vested interest in Throttlemeister or Kaoko.
Hammam is offline
post #10 of 13 Old Jan 2nd, 2015, 12:28 pm
njl4's Avatar
http://www.bmwlt.com/forums/rt-serie...l-r1150rt.html
Here is the system I used for my R1100rt it works great. You set it and it holds speed uphill or down hill. This is a real cruise control system.
It may seem like alot to hook up but after you read the write up a few time it's not that bad.
The other thing I like about doing this is when I had it apart I got to lube the all the cables that are in the boden box.
Your other options are to spend $1200 and buy the system from Australia.
njl4
96 R1100RT
85 K100RS
njl4 is offline
post #11 of 13 Old Jan 2nd, 2015, 4:02 pm
lkchris's Avatar
Guess again.
My glove size is 10-10.5 or XXL and the little finger end of my hand is nowhere near the bar end area of my handgrips in my normal riding position. In order to "easily roll off" with Throttlemeister for me would require first changing hand position on the grip before I could do it.
Once I almost ran up the back of a friend on her bike, I removed and tossed the Throttlemeister my previously owned R1100S was fitted with.
I still think they are dangerous. The o-ring works perfectly.
With throttlemeister it's a 2-step process, i.e. move hand outward, then roll off. With o-ring just roll off. Try it, you'll like it.
Kent Christensen
Albuquerque
lkchris is offline
post #12 of 13 Old Jan 2nd, 2015, 6:30 pm
Hammam's Avatar
Guess again.
No offense, but you have missed something, then. Like reading the instructions. Like I said, you do not have to disengage it first when you want to close the throttle. Here is an excerpt form Throttlemeister Web page:
"Easy to Use
Once you've mounted the Throttlemeister bar ends to your bike, they work like this: All of the workings of the Throttlemeister are inside the bar end itself. Once mounted, you turn the whole bar end in the same direction as opening the throttle. A piston moves in and out of the Throttlemeister itself and puts friction against the throttle tube, which in turn counteracts the throttle return spring. When installed properly, the Throttlemeister will not completely lock the throttle. You can always override the Throttlemeister in any situation. If you need to stop quickly you can just grab the throttle and turn it off. "
Hammam is offline
post #13 of 13 Old Jan 6th, 2015, 3:48 pm
lkchris's Avatar
Good to know--instructions didn't come with used bike.
Nevertheless, I managed to get into a situation where I couldn't get the throttle rolled off.
Kent Christensen
Albuquerque
lkchris is offline
Cruise Control and Radio Quit Working Arthur K1200LT 2 Apr 7th, 2011 8:21 pm
Difficult cruise control question coug66 K1200LT 9 Dec 28th, 2009 11:55 am
PIAA 1100X Lights coupled with Cruise control ? Orhansky Lighting 3 Jul 23rd, 2007 8:20 pm
Section speed trap in The Netherlands vvk Europe 4 Apr 18th, 2006 3:40 am
Speed traps in The Netherlands vvk Chit Chat 0 Oct 24th, 2005 9:38 am
