'95 R1100R - BMW Luxury Touring Community
post #1 of 6 Old Mar 13th, 2014, 9:04 pm Thread Starter
'95 R1100R
A buddy of mine has a '95 R1100R sitting in his mother-in-law's garage, and she's moving, so it needs to go somewhere.
I looked at picking it up, but it hasn't run in at least 3 years. Step-dad bought it to fix up, tore it apart, then passed away.
It looks reasonably complete, but I did notice they'd pulled all the brake lines off the ABS unit. I don't know if he thought the unit was bad, or if he just started taking everything apart . . .
82K miles, but the DMV tags are June 2010, so there's that added expense as well . . .
So what might that bike be worth in complete, running condition? I'm thinking around $2,000, but there aren't many comparables out there.
Are there places that rebuild those older ABS units if needed? There's no way it justifies the cost of a new part, even if I could find one.
Anything else to look out for on this model?
Or any good Oilhead forums to look at?
Thanks for any help.
post #2 of 6 Old Mar 13th, 2014, 9:35 pm
Re: '95 R1100R
Re-psycle (Lithopolis, Ohio) is a shop dedicated to older (1955-2005) BMWs. They stock parts, do routine maintenance, complete rebuilds and restorations. They also buy and sell BMW bikes. They should be able to advise you or assist with any aspect of what needs to be done.
post #3 of 6 Old Mar 13th, 2014, 9:58 pm
Re: '95 R1100R
http://www.ibmwr.org/r-tech/oilheads/index.shtml
http://www.bmwmoa.org/forum/forumdis...hp?14-Oilheads
They have been of great help to me with my 96 R1100RS.
JimE is offline
post #4 of 6 Old Mar 13th, 2014, 10:41 pm
bandera's Avatar
Re: '95 R1100R
Things you'll want to consider replacing:
Hall Effect sensor - or at least replace the wiring
All rubber brake lines
All internal fuel hoses - in the tank
Check
Clutch thickness - a new disk will require a completely new clutch pack. They updated the clutch and the older disk compatible with the old assembly is no longer available.
Gaskets around throttle bodies for cracks.
Injectors for a good spray pattern.
Throttle cable - is it binding? There is a newer version for that year. It may have a single throttle cable vs. a two piece.
Gold shimmer in the gear box oil may mean the shift forks are worn and a rebuild is in order. Some M94 boxes were good and others not so good.
The single rear engine seal is prone to weeping with age. Check it when you pull the box to examine the clutch and grease the splines.
The ABS unit may be fine. Fill it and flush it after you replace the old brake lines. It will probably be fine. They are rebuild able.
It is a manual clutch - check the cable and the free play.
Have fun with it.
Cheers.
bandera is offline
post #5 of 6 Old Mar 17th, 2014, 7:53 am
Re: '95 R1100R
Well I bought my 1996 R1100R for 2k with 45k miles on it in running condition, but with that one in pieces and out of registration 1k sounds like a good deal to me. You could spend a good chunk of change just getting the ABS pump working. Not to mention any of the other work that has been mentioned on the other post.
rdriver is offline
post #6 of 6 Old Mar 17th, 2014, 12:50 pm Thread Starter
Re: '95 R1100R
Thanks for all the info.
I may pick it up as a project bike, but I'm not sure if I have the time or space for another project right now.
Still, I hate to see a decent bike go to waste . . .
R1100R rdriver Other R-Bike Discussion 7 Feb 9th, 2014 7:56 pm
R1100RT, R1100RS, R1100R K100RS, K1, K1100RS Tire Deal Wolfgang Tires 2 Jul 29th, 2009 5:31 pm
Mounting an Autocom on an R1100R ? brianbeemer Intercom, CB, & 2-Way Radios 4 Jul 30th, 2007 5:04 am
R1100R clutch/starter switch brianbeemer Other R-Bike Discussion 1 Jul 2nd, 2007 2:52 pm
