2004 R1100S Shifting Problem - BMW Luxury Touring Community
post #1 of 4 Old Sep 23rd, 2013, 12:28 pm Thread Starter
I have an intermittent problem where the bike will not shift from 2nd to 3rd or other higher gears without downshifting one gear first. The shift lever moves but no gear is engaged. Double clutching occasionally works but most of the time I have to downshift before going to the higher gear. There is never a problem downshifting. I just has the clutch spline lubed so I think the problem is confined to the gearbox. Does anyone have any ideas for a fix before I commit to a complete teardown?
goodgravity is offline
post #2 of 4 Old Sep 23rd, 2013, 8:52 pm
lkchris's Avatar
Re: 2004 R1100S Shifting Problem
Ask your question here:
http://forums.pelicanparts.com/bmw-r...0s-tech-forum/
Kent Christensen
Albuquerque
lkchris is offline
post #3 of 4 Old Sep 24th, 2013, 3:13 am
dadicool59's Avatar
I had a similar problem with mine when I first got it.
Check that your gear change linkage hasn't come loose at the selector spline and slid backwards.
This had happened to mine and the linkage was binding on the frame and not getting full range of movement.
You will find where the linkage is attached to the selector spline below and behind the starter motor as seen in the attached pic and you will also see where the linkage binds against the frame where the large nut is at the engine mount in the second picture.
I hope this works for you, it was a huge relief to me when I discovered it on mine.
Name:	R1100S selector 2.JPG
ID:	41842   Click image for larger version
Name:	R1100S selector.JPG
2017 R1200RT
2010 R1200RT Sold
2002 R1100S
1993 R100RT
07 K1200GT R.I.P.
86 K100RS Sold
07 R1200GSA Sold
07 Softail Heritage Sold
86 K100RS Sold
82 R100RS Sold
82 Suzi GSX1100 Sold
75 Honda 750/4 Sold
74 Yamaha XS650 Sold
dadicool59 is offline
post #4 of 4 Old Sep 24th, 2013, 7:32 am
05hexhead's Avatar
I agree on checking the linkage alignment. If that does not solve your problem I would check to ensure your clutch slave cylinder is properly bleed and functioning correctly.
Nick
'05 R1200RT
'00 R1100S
'01 R1200C Phoenix
'04 R1200C Montauk
'95 R100R Classic
'84 R80RT (naked)(sold)
'94 R100GSPD (sold)
'84 R100S (wannabe)(sold)
'97 R1100RSL (sold)
'81 R100 (sold)
05hexhead is offline
Radio Problem fixed thanks to the HoW... lhamonic K1200LT 8 Oct 20th, 2016 11:30 am
2004 R1150rt Fuel Leak... kuiama RT Series 8 Dec 14th, 2011 11:16 pm
Problem shifting out of neutral to first c_ford K1200LT 16 Aug 28th, 2011 8:22 pm
Weird electrical problem ronbok K1200LT 5 Jul 2nd, 2008 10:37 pm
Intaride RP-1 and cell phone problem bowlesj Intercom, CB, & 2-Way Radios 0 Nov 7th, 2007 8:15 pm
