flasher/hazards problem - BMW Luxury Touring Community
post #1 of 2 Old Aug 13th, 2011, 7:01 am Thread Starter
hi, can anyone help me with my r1200c when engine is not running indicators work ok as soon as i start up they will only flash a couple of times and then stop working also includes the hazards.the engine is lumpy on idle which is when they stop working when you raise the engine rpm they stay working,have changed the indicator/hazard relay @77 ouch! cheers.
ianpaterson is offline
post #2 of 2 Old Aug 16th, 2011, 12:13 pm
05hexhead's Avatar
Re: flasher/hazards problem
I had a similar problem with faulty flashers when the engine was running. They worked fine until I pulled in the clutch then they would cancel, engine vibration transfer to frame. For me it was a faulty flasher relay. I was able to find a good used one for $25.
Sounds like yours is most likely vibration caused. For your situation I would also check the contacts in the cancel switch, make sure the contacts are clean and maybe stretch the spring to make better contact.
Good luck.
Nick
'05 R1200RT
'00 R1100S
'01 R1200C Phoenix
'04 R1200C Montauk
'95 R100R Classic
'84 R80RT (naked)(sold)
'94 R100GSPD (sold)
'84 R100S (wannabe)(sold)
'97 R1100RSL (sold)
'81 R100 (sold)
05hexhead is offline
2003 LT a No Start Problem knlkern K1200LT 11 Aug 26th, 2008 9:00 pm
Very strange electrical problem starvingdrummer K1200LT 10 May 21st, 2008 10:17 am
Could my '05 center stand problem be this simple? mrbiker K1200LT 3 May 6th, 2008 8:17 pm
Computer Problem Response Form Lonewuff Humor 3 Mar 14th, 2008 3:53 pm
Problem with a BMW car - Am I being unreasonable? DanDiver Chit Chat 8 Dec 20th, 2007 11:51 am
