R80RT Brake question - BMW Luxury Touring Community
post #1 of 6 Old Aug 11th, 2011, 10:42 pm Thread Starter
Angry R80RT Brake question
Front brakes locked up, they will engage but not release. Changed flex lines and rebuilt cals. I am getting air bubbles back into res. when lever is pumped, there just does not seem to be a lot of fluid movement. I'm thinking piston on the hand grip is stuck, or not returning to rest position. Is there an easy way to free it up or does it need to be replaced? Or am I missing something else?
Toby in New York
1983 R80RT Red (sold)
Lusting after K1600 GTL
tobiwan is offline
post #2 of 6 Old Aug 12th, 2011, 9:00 am
Gold Supporter
Re: R80RT Brake question
Most of the time when the brake lock up on an airhead it is due to the return hole in the master cylinder being stopped up. There are two holes inside the recess area in the bottom of the master cylinder. One is easy to see the other is very small and sometimes hard to find especially if the brake fluid is old. Take a single wire from a wire brush and run it thru this small hole normally that will fix the problem. After that be sure to change your fluids annually.
Jim Davidson
2007 R1200RT
hp1bmw is offline
post #3 of 6 Old Aug 12th, 2011, 4:25 pm Thread Starter
Wink Re: R80RT Brake question
Thank you for responding. She has been somewhat neglected since the o3,04,and 05 purchases. Out of the elements but not ridden much. Does the piston slide or move at all during use? I see the easy to see hole but only about 1/3 of it is in view to the right side of the hole as you sit on the bike. Is the small hole more to the right or left?
Thanks again for the help.
Toby in New York
tobiwan is offline
post #4 of 6 Old Aug 15th, 2011, 9:02 am Thread Starter
Talking Re: R80RT Brake question
located the hole. cleared same. problem solved.
thank you again.
Toby in New York
tobiwan is offline
post #5 of 6 Old Aug 15th, 2011, 11:39 am
Gold Supporter
thank you again.
Glad that was all it was. That is a real common problem on neglected brake systems.
Jim Davidson
2007 R1200RT
hp1bmw is offline
post #6 of 6 Old Aug 15th, 2011, 12:02 pm Thread Starter
And they were neglected. will pay better attention from now on
Toby in New York
tobiwan is offline
BMW Bulletin on Installation of Steel Brake Lines rdwalker Bike Talk 5 Feb 12th, 2011 11:25 pm
Brake Fluid Question garyw K1200LT 6 Jan 28th, 2011 12:35 pm
Brake System Question rovero K1200LT 5 Dec 22nd, 2010 12:06 am
A brake question on my '06 bflemingor K1200LT 10 Apr 9th, 2007 1:31 pm
Rear Brake caliper question mpillis K1200LT 2 Jun 21st, 2006 10:14 am
