Oil pressure light on R80RT - BMW Luxury Touring Community
post #1 of 9 Old Jun 13th, 2011, 9:58 am Thread Starter
BMWCharlie's Avatar
After sustained highway speeds, when my '85 R80RT comes back to idle, the oil pressure light comes on. I can turn it off by slightly opening the throttle, but the light comes back on at idle. Anything above idle and there's no light. And, the light never comes on when I'm in city traffic. I've owned the bike since new, and I vaguely recall changing the oil pressure sending unit on the side of the sump maybe 15 years ago or so. Is it time to change it again? Or should I just blip the throttle whenever the light comes back on?
Charlie
99 K1200LT
85 R80RT
81 R100RS (Sold it 4/10)
03 Moto Guzzi V11 LeMans
BMWCharlie is offline
post #2 of 9 Old Jun 13th, 2011, 10:50 am
Gold Supporter
Re: Oil pressure light on R80RT
Most likely the sending unit needs to be replaced. When did you change the oil last? You might have a crimped gasket at the filter.
Jim Davidson
2007 R1200RT
hp1bmw is offline
post #3 of 9 Old Jun 13th, 2011, 12:16 pm Thread Starter
BMWCharlie's Avatar
I changed the oil and filter about 400 miles ago.
Charlie
99 K1200LT
85 R80RT
post #4 of 9 Old Jun 13th, 2011, 1:24 pm
Gold Supporter
It is still probably the sending unit, but if it started right after the oil change it might be worth check the filter gaskets and metal shim to make sure they are not damaged. It is fairly easy to pinch one of the outer gasket parts when putting the cover plate back on.
Be sure the metal shim goes in first then the o-ring.
Jim Davidson
2007 R1200RT
hp1bmw is offline
post #5 of 9 Old Jun 14th, 2011, 8:01 am
05hexhead's Avatar
Not to be a jerk, but is it your generator light?
Nick
'05 R1200RT
'00 R1100S
'01 R1200C Phoenix
'04 R1200C Montauk
'95 R100R Classic
'84 R80RT (naked)(sold)
'94 R100GSPD (sold)
'84 R100S (wannabe)(sold)
'97 R1100RSL (sold)
'81 R100 (sold)
05hexhead is offline
post #6 of 9 Old Jun 15th, 2011, 2:34 pm Thread Starter
BMWCharlie's Avatar
A valid question. But, no, I bought the bike new in 85 and quickly figured out the difference between the lights, thank you very much. In 85 the airheads quit using a metal shim so that's not an issue, either. There is an o-ring around the triangular cap, but there's no evidence of weeping oil so I'm pretty sure that's correctly installed. I'll just keep monitoring the condition. If it gets worse I'll swap out the sending unit.
Charlie
99 K1200LT
85 R80RT
post #7 of 9 Old Jun 15th, 2011, 2:40 pm
jers99lt's Avatar
I replaced my sending unit last year due to it leaking. It was pretty easily to do since there's no oil leakage when removed. I tried to find one at a local auto parts store, but the threads were wrong. Found it with an internet search. I believe it was under $10. If you need I'll look up the specifics when I get home later.
HTH,
Jer
Jerry Palma
85 R80RT 'Lady in Red'
08 535xi Space Gray metallic
09 328i Silver Convertable
17 X3 Glacier Silver metallic
jers99lt is offline
post #8 of 9 Old Jun 15th, 2011, 2:45 pm
jers99lt's Avatar
WOW! Looks like we're riding the same BMW bikes.
Jer
Jerry Palma
jers99lt is offline
post #9 of 9 Old Jun 15th, 2011, 3:08 pm Thread Starter
BMWCharlie's Avatar
Two out of four ain't bad. The larger question is how is it that a bike I bought new is now eligible for an antique license plate?
Charlie
99 K1200LT
85 R80RT
What is the best way to break in your new K1600GTL ? DanDiver K1600GT/GTL 7 May 8th, 2011 9:13 am
Oil Light On gpolakow K1200LT 6 Apr 14th, 2010 8:53 pm
potentially dumb air pressure question petevandyke K1200LT 11 Sep 24th, 2006 7:44 pm
How many forum members does it take to change a light bulb? RoyvL Humor 12 Feb 13th, 2006 12:49 pm
