steering damper r850r - BMW Luxury Touring Community
post #1 of 4 Old Nov 8th, 2010, 10:28 am Thread Starter
hello to all...i am new to this so be kind.....just bought 96 r850r and started riding after 38 yrs. off. the excitement is back again...anyway...i have noticed that the front end tends to flop around easily when the bike is on center stand. seems too loose. which brings me here.... i have read various older posts on the steering damper but still would like some info...are there any new dampers out there? the info i read on rebuilding kept referring to #4 ? i don't know what that means....is it something i should really worry about. thank you in advance for your help.
regards tom
tschmidt51 is offline
post #2 of 4 Old Nov 8th, 2010, 7:41 pm
Re: steering damper r850r
regards tom
The first thing you should do is make sure the steering stem bearings are properly torqued. Then check the trailing arm bushings. When you're sure all of that is OK, you could spring for a new steering dampner, which is about $300.
Scottly is offline
post #3 of 4 Old Nov 9th, 2010, 8:17 pm Thread Starter
is there a way to rebuild the damper....
post #4 of 4 Old Nov 10th, 2010, 1:19 pm
To the best of my knowledge, the dampner is a sealed unit and cannot be rebuilt.
You do have other options, though. Measure it and see if you can find an aftermarket replacement cylinder for it. Steering dampners are real common, and somewhat cheaper, in the road race world. Do some searches and make some calls...I bet you can save some cash.
Scottly is offline
Steering damper is damping my spirit pushin9s K1200LT 13 Aug 14th, 2010 7:42 pm
HyperPro Steering Damper oknplm K1200LT 11 May 17th, 2008 2:59 am
Steering Damper, Cause of Slow speed instability Jabrown K1200LT 22 Oct 18th, 2007 12:55 pm
Steering Damper wkclark K1200LT 0 Oct 13th, 2007 11:07 am
