1996 R1100R Fuel Filter - BMW Luxury Touring Community
post #1 of 2 Old Oct 7th, 2009, 8:38 pm Thread Starter
I am trying to locate the fuel filter on this bike and was wondering if anyone has any ideas before I do an all night disassembly?? Thanks in advance
BEEMER69 is offline
post #2 of 2 Old Oct 8th, 2009, 1:02 am
glenn's Avatar
Re: 1996 R1100R Fuel Filter
Helps to have almost empty tank.
Pull the fuel tank, marking hoses as you disconnect so you you can put them back. On the underside of the tank you will see where the hoses are connected, remove three nuts from plate and carefully pull fuel pump/filter assembly out, noting alignment marks. Pull hoses off filter, replace, noting correct flow direction. Install in tank. Do not over tighten nuts on plate.
Glenn BTW
California Delta Country
05 LT, ocean blue ( the replacement player)
05 LT, dark graphite (motorcycle heaven)
1100RT-P in a previous life
glenn is offline
Alternate Fuel Filter saddleman K1200LT 8 Aug 23rd, 2009 6:26 pm
Fuel Injector cleaning-on the bike PhillWard Australia, New Zealand, and AsiaPac 4 Nov 28th, 2008 12:02 pm
Fuel Filter outside the fuel tank strsout Bike Talk 4 Aug 2nd, 2007 5:45 am
Fuel filter replacement...Necessary? BLBantz K1200LT 20 Feb 19th, 2007 8:50 am
