Juicing a R1200C - BMW Luxury Touring Community
post #1 of 5 Old Sep 16th, 2009, 11:18 am Thread Starter
Juicing a R1200C
Are any performance parts available to get some upper rpm power in the R1200C bikes?
I've ridden a couple of these models and like the handling and low-end grunt, but, the bike's performance faded pretty badly at higher speeds and is pretty anemic above 80 mph. I couldn't get the bike to go above about 105 at WOT in 5th gear.
Are better cams and higher compression pistons available. Any better carburetion options available? The mediocre performance is the only thing stopping me from buying a R1200C.
DakotaDude is offline
post #2 of 5 Old Sep 16th, 2009, 11:29 am
Re: Juicing a R1200C
You may find answers to your questions here www.chromeheads.org
simoncharles is offline
post #3 of 5 Old Sep 16th, 2009, 11:32 am
Moot's Avatar
Folks have tried cams, throttle bodies, 6 speed trannys, chips and exhaust mods all with postive results. +1 on chromeheads.org. You will find all you want to know in the posts on that site.
2004 R 1200 C (Fire Starter)
2007 R 1200 RT (Heavy Feather)
2008 Ducati 999 S (Shock and Awe)
Moot is offline
post #4 of 5 Old Sep 17th, 2009, 12:03 pm Thread Starter
Thanks for the replies. I'll check the chromeheads site for info.
post #5 of 5 Old Sep 17th, 2009, 12:47 pm
San Jose (CA) BMW is known for their expertise in performance upgrades. When I purchased my 04 CLC I talked seriously to them about upgrading the top end to RT type specs but decided against it because they were talking 3 grand.
Not sure where you are located but if you are distant, they will likely work with your to spec out the changes.
Jim
Woodbridge, CA
TheSnake is offline
Help - bar backs for R1200C ajs K1200LT 1 Apr 27th, 2009 11:39 pm
looking at purchasing a 2001 r1200c need help making this decision troymenace Other R-Bike Discussion 5 Apr 14th, 2009 4:43 am
Smokin' R1200c UL2MIT Other R-Bike Discussion 7 Dec 29th, 2008 12:58 pm
Considering 04 R1200C, questions.... WCO1 Other R-Bike Discussion 12 Jan 27th, 2008 7:04 pm
