Drilling weep hole on other BMWs? - BMW Luxury Touring Community
post #1 of 4 Old Jul 4th, 2009, 11:51 am Thread Starter
I have read that some people here drill the clutch housing to keep a seal leak from filling the cavity up with fluid and ruining the clutch. Can this be done on other BMWs such as the R1200C?
A family member has an R1200C that has a leaky engine seal and the dealer has said that it will eventually ruin the clutch. She is not in a position financially right now to get the seal replaced but I would be willing to drill this hole for her in the clutch housing if it is possible on this bike and if it would help.
I know this is not the correct forum for a question about an "R" bike, but this is the only forum where I have seen any info about this procedure. Any help would be appreciated.
Gabriel is offline
post #2 of 4 Old Jul 4th, 2009, 12:12 pm
simonrobi's Avatar
Re: Drilling weep hole on other BMWs?
Hi Gabriel,I have only drilled weep holes on my LT.Both slave cylinder housing and clutch housing.No big deal to do it,about 4-5 hours of work including slave cylinder replacement and clutch line bleeding.It may save a lot of work if I notice fluid coming out the slave housing,as that is a sign of either a leaky slave cylinder or rear transmission seal (not output seal!) and fix that before oil reaches and ruins the clutch.As for the clutch housing,I really do not know what good will do other than it gives you access to spray some break cleaner to wash the clutch components from time to time.I will look at my R1200C later today or tomorrow and give my opinion about drilling holes on it if nobody else has by than.Robert.
Four wheels move the body,two wheels move the soul.
2004 R1200CL Silver - Torquey
simonrobi is offline
post #3 of 4 Old Jul 4th, 2009, 2:08 pm
I had a leaking rear main seal on my R80 for several months before I finally got around to changing it. I don't think there is any place to drill a hole there that would help. It never did contaminate the clutch. The difference then was I could do the job in my driveway in one afternoon comapared to the LT which will take a full weekend to do.
post #4 of 4 Old Jul 6th, 2009, 2:46 pm
Gabriel, go on the Chromeheads.org site (dedicated to the R1200C) and search for the answer. If you don't find it then ask. There are some really competent people there and they will know for sure.
Gael is offline
Drilling the weep hole. joevano K1200LT 13 Nov 15th, 2012 11:41 am
Q's about Weep Hole in Tranny Housing (not the slave cyl weep hole) Toolman K1200LT 1 Jun 9th, 2009 11:18 am
Drilling the clutch weep hole jonny65 K1200LT 6 Jun 15th, 2008 9:55 am
Is it time to start drilling TWO weep holes? Dean_BMW K1200LT 10 Dec 5th, 2007 5:29 pm
First time Slave weep hole drilling bigbear K1200LT 0 Apr 10th, 2007 1:19 pm
