wheel bearing's for R80RT - BMW Luxury Touring Community
post #1 of 2 Old Jun 30th, 2009, 2:25 pm Thread Starter
Question wheel bearing's for R80RT
Let me try the question this way. What is the secret for removing them for service?
Toby in New York
1983 R80RT Red (sold)
Lusting after K1600 GTL
tobiwan is offline
post #2 of 2 Old Jul 22nd, 2009, 6:46 pm
05hexhead's Avatar
Re: wheel bearing's for R80RT
Just noticed your post. On my '84 R100RT which should be the same as yours.
With wheels removed place flat on bench, use flat screwdriver to pry out hat style collar, it comes out easy.
Place the flat screwdriver under the dust seal pushing until blade touches cast wheel. I use a piece of 1\8 inch plywood under screwdriver shaft at the other side of the seal (on the cast wheel) as a fulcrum point.
While holding blade tight under the seal and on the plywood, use the palm of your other hand to tap down on the screwdriver handle.
Take your time and seal\dust covers will pop out.
Important *** keep covers, spacers, etc separate for replacement in original location as there are different size spacers on the rear wheel.
Clean and repack, I use a large socket and hammer to knock the seal lightly until it is flush with the cast wheel.
Nick
'05 R1200RT
'00 R1100S
'01 R1200C Phoenix
'04 R1200C Montauk
'95 R100R Classic
'84 R80RT (naked)(sold)
'94 R100GSPD (sold)
'84 R100S (wannabe)(sold)
'97 R1100RSL (sold)
'81 R100 (sold)
05hexhead is offline
Rather longish, but good tips & info! vvk Bike Talk 7 Jun 19th, 2011 4:43 pm
Another Final Drive Pivot Needle Bearings Post Bear-KLT K1200LT 17 Mar 10th, 2009 6:08 pm
Checking rear wheel bearing play Oisin K1200LT 3 May 26th, 2008 2:08 pm
Front Wheel Bearings DanMartin K1200LT 10 Feb 13th, 2008 4:08 pm
