new R90S owner, elect question - BMW Luxury Touring Community
post #1 of 5 Old Aug 17th, 2008, 8:02 pm Thread Starter
Ok, so I got this BEAUTIFUL specimen of a 74 R90S on ebay. It's a numbers matching, carefully rebuilt looker. What a blast to ride. I noticed that the volt meter wasn't registering well. No surprise there, so the plan was to connect a proper volt meter and observe the charging. I must have touched something improperly and blew a fuse. headlight, clock and instrument lights work but nothing else, and no starter click. So. Are there fuses in the headlight bucket? Whats the trick to getting the fairing off? It looks like you have to remove the turn signals and kid of bend the fairing (eek) to get around the turn signal stalks. What am I missing here? Anyone out there had their fairing off to change the headlight bulb? Help !!!???
thanks,
Joseph
yudin is offline
post #2 of 5 Old Aug 17th, 2008, 9:08 pm
JATownsend's Avatar
Re: new R90S owner, elect question
Yes, the fuses are in the bucket. I thought you could rotate the headlight or its bezel to remove it for access. You should really ask this at: Airheads.org Those guys have all the answers!!
Good luck.
J. Averill Townsend
Bloomfield Hills, MI
IBA# 24374
2002 K1200LTC - Silver
JATownsend is offline
post #3 of 5 Old Aug 19th, 2008, 9:14 pm Thread Starter
Thanks.
I found that the headlight ring has a screw with retaining clip at the bottom. You just remove the screws holding the upper fairing brackets in place, lean the thing outward, remove the ring and the headlight comes out. It easily clears the rubber gasket and goest through the fairing, you dont even have to unplug it. the wires are long enough. There was my blown fuse, easily dealt with.
Thanks again,
Joseph
yudin is offline
post #4 of 5 Old Aug 20th, 2008, 5:31 am
JATownsend's Avatar
Joseph, Glad you found the secret! That's a GREAT bike for Autumn rides in Vermont...
J. Averill Townsend
IBA# 24374
post #5 of 5 Old Aug 17th, 2010, 9:00 am
x101bigfoot's Avatar
you really should wire up fuse holders to a remote place i have mine neatly mounted between gages and handelbars there is also electronic voltage regulators instead of oem coil and points regulator
x101bigfoot is offline
New Owner Question about second hand parts streakyb K1200LT 8 Feb 19th, 2009 3:59 pm
New owner question country-bum K1200LT 3 Aug 7th, 2007 10:10 am
New LT owner question boeingdriver K1200LT 6 Apr 6th, 2007 5:26 am
New Owner - 1st Question BToliver K1200LT 13 Aug 28th, 2006 8:50 am
New Owner... dumb question... Torpedo K1200LT 10 Jun 1st, 2006 6:30 am
