Dual front brakes on R65 - BMW Luxury Touring Community
post #1 of 3 Old Jul 21st, 2008, 7:44 am Thread Starter
Hello,
I have a 1979 R65, with single front brake. What all do I need to convert to the dual discs, and is this possible. I would assume yes as the R65LS had the duals. I would think duals would make a big difference, the single just plain sucks, though granted I dont ride the bike very fast for this very reason.
GSJak is offline
post #2 of 3 Old Jul 22nd, 2008, 7:23 am
Re: Dual front brakes on R65
I had an '83 R45 with the dual disc setup. The brakes were phenomenal. You'll probably have to scour the breakers for a complete R45/R65 front wheel, caliper(s)discs, lower fork legs and master cylinder.
Check first if you already have lugs for a second caliper to be mounted and check the wheel as well for disc mounting. You may be lucky and just need a disc, caliper, master cylinder and hoses.
BTW the R65LS had different wheels as I remember.
axamax is offline
post #3 of 3 Old Jul 23rd, 2008, 2:44 pm
Have a look at the MAX BMW On-Line Parts Fiche. Click on the link, select R65, select 34-Brakes, and then look for Diagram #34_0597, Retrofit Kit, Double Disc Brake. That one is for models up to 09/1980.
My 1980 R65 came with dual discs. They were excellent and much needed in the 14 years I used that bike in the Alps.
BMWGS is offline
Rather longish, but good tips & info! vvk Bike Talk 7 Jun 19th, 2011 4:43 pm
Front and shake/ shimmy front, ... revisited andy K1200LT 12 Jan 12th, 2007 7:16 pm
02 Front Brakes Grabbing / Pulsing vipergman2 K1200LT 6 Aug 16th, 2006 6:30 pm
Lost my front brakes Chuck_Gardner K1200LT 4 Jun 9th, 2006 2:31 pm
Rear brake squeal linked to front brakes? Vince_nj1 K1200LT 19 Apr 2nd, 2006 10:37 am
