CLC doesn't like LED tailight - BMW Luxury Touring Community
post #1 of 4 Old Apr 5th, 2008, 12:12 am Thread Starter
joevano's Avatar
I installed a LED in my wife's tailight ( on her CLC ) and the "general" warning light came on. I put the standard bulb back in and it went off. Evidently, the LED does not draw enough and the bike thinks the bulb is burned out. Is there any way around that?
Joe Van Orsdol
Zimmerman Mn
'02 K1200LT
'94 K75S for sale
'11 DR650 Alaska Bike
'13 KTM 250XCW
joevano is offline
post #2 of 4 Old Apr 5th, 2008, 2:36 pm
Re: CLC doesn't like LED tailight
Some of the manufacturers of other LED units include a load resistor to wire across the leads to fool the monitor into thinking there is a regular load. If you can find a 50 ohm 5 watt (or higher) resistor (Radio Shack?) that would emulate the 5 watt load of a normal tail light bulb. Just wire it across the leads.
post #3 of 4 Old Apr 5th, 2008, 5:56 pm Thread Starter
joevano's Avatar
Thanks, that's exactly what I was looking for. I have a couple more LED arrays and a modulator to put in the circuit, perhaps that will add enough load. If not, I'll try your suggestion!
Joe Van Orsdol
Zimmerman Mn
'02 K1200LT
'94 K75S for sale
'13 KTM 250XCW
joevano is offline
post #4 of 4 Old Apr 6th, 2008, 7:30 am
BMWphreak's Avatar
It won't. You will need a resistor. You might want to consider using the OEM bulb and auxillary LED arrays instead of the bulb replacement LED.
'07 - R1200RT Slippery Silver
MOA #107139
RA #28511
Past rides:
'03 R1150RT - MAXed out
'03 K1200LTC - Gone to the Darko side
'00 Kawasaki Concours - Buzz
'71 Honda SL350 - The original dual-sport
'72 Kawasaki 250 triple - The smoking gun
'67 Montgomery Wards 125 - Thrashed to death
BMWphreak is offline
LT Tailight Bulbs NascaLT K1200LT 8 Jul 15th, 2006 7:51 am
LED Brakelight Working Now jorawro Lighting 4 Jun 5th, 2006 1:23 pm
