R1100RS sat idling... - BMW Luxury Touring Community
post #1 of 4 Old Feb 19th, 2008, 10:53 pm Thread Starter
Question R1100RS sat idling...
Started my bike up for a "charge the battery" ride as I had left the light on... anyways. Step into the house while its idling and get a phone call from a relative. One thing leads to another and I end up on the phone for an hour. As I hang up I realize that I have left my bike running! I ran out there and it was no longer running. It was radiating ungodly heat and I even managed to locate a few melty looking pieces of plastic on the engine. (specifically two cable stays that were hard plastic) I was hoping it just ran out of gas but it seemed to have plenty so I went into a panic. I was sure that I had managed to seize the engine with heat but when I tried to restart it turned over just fine but did not start. I tried again later when it had fully cooled and still no start. I have an idea of what might be causing this but could really use some advice from the community here.
Why won't my bike start? (aside from my idiocy mentioned above =P )
Thanks.
~QuickQuestioner
QuickQuestioner is offline
post #2 of 4 Old Feb 19th, 2008, 11:34 pm
amarider's Avatar
Re: R1100RS sat idling...
First check your fuses, then I would pull the spark plugs and see if their fried.
You might get lucky but warming up and overheating an R engine standing still is not good.
Best of luck.
John & Cathy
Northern CA
01 K1200LTC Basalt - Moose
Posse #2
amarider is offline
post #3 of 4 Old Mar 9th, 2008, 8:44 pm Thread Starter
Checked the fuses and got new plugs but still no go. Hot tip from the local BMW service side was to check the hall sensor. Opened up the front plastic to see the alternator belt and sure enough saw what look like oil dripping down near the hall sensor wire retaining clip. After getting in there and removing hall sensor it looks like the first thing the heat got to was the hall sensor wire, melt down and short out.
Any advice on whether a new length of wire can be soldered in?
QuickQuestioner.
post #4 of 4 Old Mar 11th, 2008, 12:00 pm
Short answer is, yes you can fix'em. I think diagnosing and fixing the HES has been addressed in the MOA mag within the past couple of years. There is a guy in Tucson, sorry I can't find his contact info, who rebuilds HES's. Googling may turn up something.
QuickQuestioner.
Motor On ,/'
jkersh1 is offline
K1200 GT Idling dcrawford K1200LT 5 Oct 5th, 2007 4:21 am
Rough idling RILaw78 K1200LT 6 Apr 21st, 2007 12:05 pm
Down-time Idling hschisler K1200LT 14 Feb 28th, 2007 10:11 pm
Smell of fuel while idling damenke K1200LT 2 Mar 26th, 2006 9:34 am
