R1100S Problem - BMW Luxury Touring Community
post #1 of 5 Old Feb 4th, 2008, 3:03 am Thread Starter
R1100S Problem
I am a new member to this forum in need of some helpful advice, please.
I have an R1100S which has an intermittent problem which others may be familiar with. After giving it a bit of a brisk run, it feels like it is running out of fuel when rolling off the throttle. It also pops a little at the same time. It feels fine when the throttle is opened again. The bike has a Staintune pipe and performance chip but no after market Fuel Injection Control Unit. Does anyone have a suggestion as to what it may be, especially if you have had the same problem? Any help would be greatly appreciated, thanks.
beemapilot is offline
post #2 of 5 Old Feb 4th, 2008, 10:03 am
amarider's Avatar
Does the after market Exhuast still use the stock O2 sensor?
John & Cathy
Northern CA
01 K1200LTC Basalt - Moose
Posse #2
amarider is offline
post #3 of 5 Old Feb 4th, 2008, 1:25 pm Thread Starter
R11000S Problem
I'm not sure. I bought the bike with 70000 km on it and have done a further 12000. I'll have to ask the bloke I bought it from as I know him. By the way, he says he never had this problem himself and this is probably true as I had had it a while before the problem showed up.
post #4 of 5 Old Feb 4th, 2008, 2:24 pm
amarider's Avatar
Take a look at the Exhaust pipes around the foot pegs, there should be an O2 sensor like this
The top half will be pointed up out of the pipe with a wire.
If not then the performance chip alone with not compensate for the air mixture. If the O2 sensor is there it may need replacing.
John & Cathy
Northern CA
Posse #2
amarider is offline
post #5 of 5 Old Feb 5th, 2008, 12:30 am Thread Starter
Thanks for your suggestion about the 02 sensor. I have booked the bike in to have the valve clearances done next week so I'll get them to check or replace the sensor. It just may be the answer.
Radio Problem fixed thanks to the HoW... lhamonic K1200LT 8 Oct 20th, 2016 11:30 am
Sputtering problem speedy K1200LT 22 Nov 20th, 2009 11:17 am
Rain induced problem on '04 LT? bwdjr K1200LT 3 Nov 19th, 2009 11:01 am
Weird electrical problem ronbok K1200LT 5 Jul 2nd, 2008 10:37 pm
Oil Usage Problem Solved..Finally herk402 K1200LT 7 Sep 26th, 2006 12:51 pm
