Newbie w/r1150rt surge question - BMW Luxury Touring Community
post #1 of 4 Old Aug 6th, 2007, 6:09 pm Thread Starter
Hi, I'm new to the board. I just purchased my first BMW: 03'r1150rt after selling a Honda ST1300. It was like riding on top of a furnace! My only problem with the RT is the surging. I have seen some info about different fixes, and seem to be steering toward the Techlusion 1332. Does this "totally" remove the surge? I have tuned the balanced the throttle bodies, adjusted the valves, removed the pink CCP, and installed Autolite 3923 plugs, and it probably reduced surge by 40%.
Is there someone out there with some personal experience with this fix?
Pat
RTPatC is offline
post #2 of 4 Old Aug 7th, 2007, 5:06 pm
drmajor's Avatar
I did all the work on my '97 RT 1100. It surged pretty good when I got it_used.
A large part of fix = spark plugs- not Autolite. I tried many plugs- Brisk, Bosch, NGK. The Bosch and NGK did best and made a significant reduction in surge.
Throttle body tuning.... a fiend suggested setting the TB at idle and then at the speed I ride at, say 3500 RPM. I used a fan to keep the motor cool during this, as I went back and forth between idle and for me 3800 rpm.
The valves I set fairly loose by my standards- ie, go/no go with next size up/down. This combined with plugs and TB made my bike really run like no other. In fact, a friend who had a 2002 1150 RT said my 1100 ran better than his. I agree.
I now have a 02 GSA that runs very good. The other day, I put Autolite plugs in and felt it didn't run as well. I am going back to the NGK $9 a-pop ones. Can't think of the number right now. The ones I took out were had dual electrodes. One 1150R owner said he liked the Split Fire Tri electrode ones. I just don't think the Autolite works as well. The Iridium plugs also worked well on my RT!! best on it, as I remember.
Be sure your air filter is clean.
After some input on riding in the bike's RPM power band, I now ride at a higher RPM more. I found that I tended to run my LT at about 3-4000 in the mountains. After learning more about power band, I went back to mountains and stayed in the 5-7000 range. WHAT A DIFFERENCE!!
Now with my 02 1150 GSA, I find it really likes to stay up in the power band and that greatly reduces any tendency to surge or chug along. Motor just likes it. One service manager also said these motors need to be run and not lugged along.
hope some of this helps. Play with your Valve and TB settings. Nothing is sacred here and you might find your bike wants a slightly varied setting.
David Major
Charleston, SC
-2003 LT
-2007 GS Adventure. White
drmajor is offline
post #3 of 4 Old Aug 8th, 2007, 9:42 pm
BMWphreak's Avatar
Go over to http://www.bmwst.com/ There is plenty on reducing surge. Most bikes can be cured with a careful valve adjustment followed by a throttle body sync.
If not, then I have an almost new Techlusion FI adjuster for sale if you want it. Many swear by this unit.
'07 - R1200RT Slippery Silver
MOA #107139
RA #28511
Past rides:
'03 R1150RT - MAXed out
'03 K1200LTC - Gone to the Darko side
'00 Kawasaki Concours - Buzz
'71 Honda SL350 - The original dual-sport
'72 Kawasaki 250 triple - The smoking gun
'67 Montgomery Wards 125 - Thrashed to death
BMWphreak is offline
post #4 of 4 Old Aug 8th, 2007, 11:10 pm
Talking
This is what I did Link.
My Tec is for sale.
Nathan is offline
Newbie with BC1 question pushin9s Intercom, CB, & 2-Way Radios 2 Feb 28th, 2007 8:23 pm
Newbie question about lowering seat height jomalley K1200LT 3 Jun 30th, 2006 6:06 pm
Trunk Rack (newbie question) tdraper K1200LT 4 Jun 14th, 2006 7:36 pm
Central Locking... Stupid Newbie Question buddoggin K1200LT 3 Jun 9th, 2006 9:39 am
Another dumb newbie question ... How to set the clock.. GSinNC K1200LT 8 Apr 2nd, 2006 3:04 pm
