Gas tank reserve - BMW Luxury Touring Community
post #1 of 4 Old May 29th, 2007, 10:50 pm Thread Starter
Gas tank reserve
Here's a silly question. How do you switch the gas from main to off or to reserve on an R1150RT? The manual says it has a reserve, but doesn't say how to switch it.
The manual also left me wondering how to check the oil level. I have ridden bikes for about 30 years, built a few hot rods and am generally pretty capable with servicing motors. Peaking through a little window in the lower fairing is a long way from the Harleys that I am used to dealing with.
neepawa is offline
post #2 of 4 Old May 30th, 2007, 12:08 am
BMW Guru
Ted Shred's Avatar
There is no switch or petcock. The low fuel light will come on when you have about a gallon left. Just like a newer car.
There is an oil site glass under the left cylinder head. The level should be visible in the red circle when the bike is on the center stand.
__________
2016 R1200GS Adventure
2006 DRZ400E
2007 G650 X Challenge
2006 GT200
2005 R1200GS
Ted Shred is offline
post #3 of 4 Old May 30th, 2007, 12:14 am
amarider's Avatar
I'll add a little to what Ted said about checking the oil. On all my oil heads I've had to be carefull about how I check the oil so I don't over fill.
If you just pop the RT on the center stand right away you may get at false low reading. After riding a least 5 or so miles and the engine is fully warm let the bike sit on the side stand for about ten minutes then put the RT up on the center stand. This allows the oil cooler to drain, this worked on my RT and also currently on my 05 GS.
John & Cathy
Northern CA
01 K1200LTC Basalt - Moose
Posse #2
amarider is offline
post #4 of 4 Old May 30th, 2007, 12:16 am
BMW Guru
Ted Shred's Avatar
If you just pop the RT on the center stand right away you may get at false low reading. After riding a least 5 or so miles and the engine is fully warm let the bike sit on the side stand for about tem minutes then put the RT up on the center stand. This allows the oil cooler to drain, this worked on my RT and also currently on my 05 GS.
Good point John. Also, if you ARE low on oil, never add much. A 1/4 of a quart usually does the trick...
__________
2006 DRZ400E
2006 GT200
2005 R1200GS
Can You See Your GPS with a Chicane Tank Bag? jhsonderb Rider's Gear & Luggage 8 Apr 8th, 2007 5:33 pm
RECALL: Oil Tank Ventilation eljeffe K1200/1300GT (The Next Generation) 2 Feb 9th, 2007 9:47 pm
Tank bag question mpillis Rider's Gear & Luggage 14 May 2nd, 2006 1:12 pm
Reserve Tank makinne K1200LT 10 Apr 14th, 2006 10:00 am
Aux tank Help RMW K1200LT 7 Apr 8th, 2006 9:56 am
