76R75/6 - BMW Luxury Touring Community
 1Likes
  • 1 Post By McWideglide
post #1 of 4 Old Apr 24th, 2020, 4:24 pm Thread Starter
76R75/6
I have an R75/6 that starts up every time, doesn’t smoke, doesn’t use oil, but has only 80psi in each cylinder. Does have 74K on clock. Just use it locally. What could be wrong, valves?
Robool is offline
post #2 of 4 Old Apr 25th, 2020, 8:03 am
Patric's Avatar
Re: 76R75/6
Could be the valves.. The bikes from back then don't do well with today's gas. I had a /6 & a /7 from that time , & ended up changing the valves & seats.
Did you set the valves before the compression test?
You might want to re-torque the heads , set the valves every 2,500 miles . The cylinder studs stretch & effects the valve clearances....That is what we did in the old days...
Patric Blackman
2002 K1200LT/Hannigan2+2
AMA Charter Lifemember
Patric is offline
post #3 of 4 Old Apr 25th, 2020, 2:18 pm
McWideglide's Avatar
Re: 76R75/6
try adding a tablespoon of motor oil to each cylinder via spark plug hole, crank for a few seconds then try your compression . If it goes up, likely rings if not, likely valves.
Patric likes this.
McWideglide
Jeff M.
2002 Harley Dyna Wideglide
2016 BMW R1200RT
2009 BMW K1300GT sold
1976 BMW R90/6 sold
1967 BSA 441 Victor sold
McWideglide is offline
post #4 of 4 Old Apr 25th, 2020, 8:43 pm Thread Starter
Re: 76R75/6
THANKS MUCH! Will try both suggestions
Robool is offline
