2000 R1100RS just stopped running - BMW Luxury Touring Community
 1Likes
  • 1 Post By beech
post #1 of 3 Old Jul 30th, 2019, 6:11 pm Thread Starter
I was about 2 miles from home when the bike hesitated once, then again, and when I pulled the clutch lever in, it quit. I had to have it towed home. Where do I start? I turned the key on just now and heard the normal whirr. Is that the fuel pump or the ABS I don't know. What do I check first? It has gas.
Jebb Remelius is offline
post #2 of 3 Old Jul 31st, 2019, 12:47 pm
beech's Avatar
Re: 2000 R1100RS just stopped running
Just to keep the thread at the top of the list, I suspect your Hall Effect device.
BMW calls it ignition sensor
12 11 2 306 137 IGNITION SENSOR $370.12
But the basics are fuel and spark. So there could be more to the story.
Patric likes this.
Beech
beech is offline
post #3 of 3 Old Jul 31st, 2019, 2:40 pm
Does the whirr stop after a couple of seconds or does it continue? If it stops then it is the fuel pump. If it doesn't stop it could still be the fuel pump with one of the gas tank internal fuel lines either leaking or loose.
That would also explain why the motor quit. No fuel pressure.
dedgar is offline
