IABS light flashing, warning ligh on, no speedometer r1200cl 2004 - BMW Luxury Touring Community
post #1 of 2 Old Oct 28th, 2016, 5:23 pm Thread Starter
I am attaching link to a very lengthy description of the problem and the troubleshooting
The executive summary is
Brake light is always on (both filaments)
Speedometer does not work
so IABS (servo unit in 2004) light flashes fast and warning light is on
Test cycle does not complete so no servo brakes
Troubleshoot steps
Tested both break switches and work fine. Front shows 3.85 V and goes to 0 when pressed. Rear same voltage and goes to 0. When bike is with no ignition key, both switches show 1.4 V. (is this ok)
Blue ABS relay under tank is ok, tested and clicked and tested two other connectors of relay and they have Voltage
I tested the speed sensors by pinching the cables before they get to the wheel. I understand that will only tell me volts being sent to the sensor, but not if the electromagnetic coil is working correctly. Nevertheless...
In the back sensor I got 0V when off and 9.95V when switch on. On the front was weird. With switch off I got 2.3v....and with switch on got the 9 something volts. Seems is not ok. Problem is front sensor plug is under cockpit (so very difficult to reach and replace)
The complete story with pictures etc is at
If want to read it all, be sure you also go through archives as the thread is new but has lots of inputs and pictures.
mayojuaf1 is offline
post #2 of 2 Old Nov 15th, 2016, 6:49 pm
Re: IABS light flashing, warning ligh on, no speedometer r1200cl 2004
Don't see any links but the volts must be referenced to battery (-) not the metal parts of the bike. BMW only uses Brown wires for ground return, not the frame.
A more definitive diagnosis is only possible with a GS-911 unit or the dealers computer.
I thought the user name looked familiar, I answered you earlier post in the technical files area. Still think you have a fried ABS brain if the GS-911 unit will not read it.
Intermittent flashing brake failure light Rob-K12LT K1200LT 7 Aug 1st, 2014 6:29 am
WARNING: Check bolts for rear light assy. tumbleweed K1200LT 3 Oct 9th, 2006 8:06 am
How many of us does it take to change a light bulb?! Bruce_Yates Humor 4 Mar 1st, 2006 8:03 am
How many forum members does it take to change a light bulb? RoyvL Humor 12 Feb 13th, 2006 12:49 pm
General Warning Light mitch K1200LT 5 Nov 15th, 2005 6:33 am
