Buy or walk away/ 79 R100 - BMW Luxury Touring Community
post #1 of 5 Old Sep 3rd, 2006, 8:41 pm Thread Starter
alanforn's Avatar
Happened upon a 79 BMW R100 standard model with no fairing or bags, fair condition in need of TLC. Don't have too much knowledge on older BMW's however have some background tinkering with older British and Japanese. Long story short, older couple, gentlemen had developed health problems and could no longer ride. Bike hadn't been run in a year or so. I offered to see if we could get started, drained gas. Owner had bought a new battery, starter turned over slowly even after new battery installed, followed up by some electrical smoke wisping from the area. Figured starter was toast. This bike is the European model, 80,000 kilometers. It has the mostly useless kickstart mechanism which I was told had been abandoned on US models. Anyway I got the bike to start with the kickstarter. The owner is asking $1000.00 so I figure could probably get for $800. I know it's hard to relay condition by typing, bike is complete but has general wear. Any opinions appreciated on whether I should acquire or not.
alanforn is offline
post #2 of 5 Old Sep 3rd, 2006, 9:01 pm
Buy.very easy to work on,wonderfully dependable bikes.Plenty of parts available,although if buying from a dealer,pricey.Have had four airheads 1967-1981 and enjoyed them all.
CaptRich is offline
post #3 of 5 Old Sep 3rd, 2006, 9:56 pm
Buy it, join the Airheads. http://www.airheads.org/
widebmw is offline
post #4 of 5 Old Sep 3rd, 2006, 10:00 pm
mneblett's Avatar
Generally agree; one thing to note, the U.S. '79 models had a one-year-only ignition "can" in which the points are mounted. Hard to find a replacement, but rarely a problem, so not a reason to worry if the bike runs.
Plan on rebuilding the carbs with new gaskets/diaphrams, and perhaps the need to use solvents to clean some of the very small passages which old gas deposits clog. Also, the choke gaskets usually dry out and permit significant vacuum leaks.
Unless the starter was turning over *very* slowly, it may be ok. Back then BMW used a very heavy, slow-turning Bosch starter motor. The starter cover comes off easily once the fuel tank is off if you want to chase down the "smoke." BTW, it may not be electrical -- the area also contains the crankcase vent and the air intake.
Do *NOT* use the kickstarter unless absolutely necessary. The kickstarter on the 5-speed transmissions is notoriously fragile -- parts of the mechanism inside the tranny break easily.
HTH!
Mark Neblett
Fairfax, VA
mneblett is offline
post #5 of 5 Old Sep 4th, 2006, 7:40 pm Thread Starter
alanforn's Avatar
Thanks for the replies, looks like another bike in the garage,(oh darn)!
alanforn is offline
Trouble with Reverse Enagement redfisher K1200LT 7 Apr 28th, 2006 1:03 pm
Have you seen this two legged dog walk? BUGKILLER Chit Chat 2 Apr 1st, 2006 4:52 am
R80RT or R100RT Question Mockingbird Other R-Bike Discussion 14 Jan 21st, 2006 7:19 pm
