2015 R1200 R front suspension - BMW Luxury Touring Community
 1Likes
  • 1 Post By Hammam
post #1 of 15 Old Jan 1st, 2015, 5:19 pm Thread Starter
Hammam's Avatar
I am not sure I understand what kind of front suspension BMW have put on the new R. They tell us about ESA, but are those golden inverted front forks some kind of electronic forks, albeit without Telelever, and how do they work? Or are they just conventional sliding forks, thus contradicting the ESA claim? Thank you.
Hammam is offline
post #2 of 15 Old Jan 1st, 2015, 6:02 pm
patrick2000's Avatar
Re: 2015 R1200 R front suspension
Same as conventional forks mounted upside Down (USD) which has been the norm for modern sport bikes. They would have had to split the radiator in two to fit the Telelever in . That'd have been ugly on a naked bike.
patrick2000 is offline
post #3 of 15 Old Jan 1st, 2015, 8:00 pm
lkchris's Avatar
It's a cost saving measure, not an improvement.
Kent Christensen
Albuquerque
lkchris is offline
post #4 of 15 Old Jan 1st, 2015, 11:52 pm
Couldn't it be a cost saving measure and an improvement?
post #5 of 15 Old Jan 2nd, 2015, 5:59 am
ka5ysy's Avatar
It's a "feature". They all do that.
And Now the really important question .....
What Kind of Oil Do I Use In The Forks ????
Doug Stracener
2011 RT polar metallic
Attorney,
MSF #127350,
Instructor, Motorcycle Safety Program Louisiana Department of Public Safety
NAUI Scuba Instructor #36288
Divers Alert Network Board member
ka5ysy is offline
post #6 of 15 Old Jan 2nd, 2015, 11:20 am Thread Starter
Hammam's Avatar
So, basically, when BMW claim ESA on the new R, with all its (undeniable) virtues, it's only half true, right?
Hammam is offline
post #7 of 15 Old Jan 2nd, 2015, 11:20 am Thread Starter
Hammam's Avatar
That would be a first.
patrick2000 likes this.
Hammam is offline
post #8 of 15 Old Feb 11th, 2015, 5:26 am
ShooterSteve's Avatar
What matters is how it works in comparison. I think it looks better with standard forks and maybe the new computerized DDC is superior to the older single shock ESA system. If that's the case it makes sense from all respects. It may also attract new buyers to BMW who were turned off by the older designs in a roadster and naked bike. It seemed to be a major hit with the S1000RR and R.
Steve Sanacore
2018 R1200RT
2016 R1200RS
2014 S1000R
2014 BMW RT
2009 BMW K1300S
1997 Honda VFR 750
2009 HD Streetglide
2007 HD VROD
2001 Yamaha 1700 Warrior
1998 Vulcan 1500
ShooterSteve is offline
post #9 of 15 Old Feb 11th, 2015, 12:03 pm
The forks are ESA (if they are gold) the silver forks are conventional. Why do you doubt they have the functionality? Just because they don't look ugly like all the other ESA shocks?
Now granted I am not sure if they have pre load adjustment but that alone is not criteria for ESA as long as damping can be adjusted electronically they meet the requirement.
post #10 of 15 Old Feb 11th, 2015, 1:14 pm Thread Starter
Hammam's Avatar
Just because an issue is of no interest to YOU means it is of no interest to everybody?
Hammam is offline
post #11 of 15 Old Feb 11th, 2015, 1:40 pm Thread Starter
Hammam's Avatar
«Just because they don't look ugly...» Do you think I am THAT stupid? Besides, I don't find the ESA forks much uglier than the RS' forks. So, there.
I doubt they have what BMW have always called ESA just because I don't see how you can have front ESA and it's coil spring and paraphernalia, offering both pre-load and damping adjustments without the Telever. Hence my QUESTION. That was a question, you see, and I don't think it deserved your contemptuous comment.
Hammam is offline
post #12 of 15 Old Feb 12th, 2015, 3:51 pm
You said it I didn't and you were the one that came off negative and doubtful from the get go.
Well why can't you have it in a fork? I have seen forks you can adjust manually they are every where, but make it controlled by a button it is now ESA. Electronically Adjusted Suspension.
I have a full ESA shock on my LT rear from Wilbers and it has full preload and damping adjustment on the fly, plus it looks good. My GS had "ugly" ESA shocks (large blocks of hardware external to the shock) on my GS. That is all I was referring to.
post #13 of 15 Old Feb 12th, 2015, 4:16 pm Thread Starter
Hammam's Avatar
Exactly where did I SAY they didn't have ESA? I was not negative, nor doubtful. I ASKED TWO QUESTIONS! This is what my original post read like:
«I am not sure I understand what kind of front suspension BMW have put on the new R. They tell us about ESA, but are those golden inverted front forks some kind of electronic forks, albeit without Telelever, and how do they work? Or are they just conventional sliding forks, thus contradicting the ESA claim? Thank you.»
You probably missed the two question marks. These little signs indicate a QUESTION. How about just ANSWERING said questions, instead of replying like I was some kind of moron?
Hammam is offline
post #14 of 15 Old Feb 13th, 2015, 10:33 am
Again you said it I didn't. And I did answer the question with "The forks are ESA (if they are gold) the silver forks are conventional."
I should leave this area of the forum as I do not own an RT at this time.
Bye
post #15 of 15 Old Feb 15th, 2015, 4:50 am
John,
I am disappointed that someone is upset with your comments. I have always found you to be supportive and informative. My own experience dealing with you can only be described as positive.
Please continue to impart the knowledge that you have amassed from your own experiences and those that fellow web members have passed onto you.
Naysayers can go jump.
Brian
bfree is offline
How do I get this bolt out of the front suspension control arm? Sticka RT Series 24 Aug 29th, 2014 11:30 am
Suspension question BigKev GS Series 3 Jul 21st, 2014 7:05 am
Front Spring Info, If Available Dragonwing K1200LT 15 Feb 6th, 2014 2:21 pm
Front suspension seems very hard qisback K1200LT 13 Oct 24th, 2013 4:57 am
BMW and their contribution to the world of motorbike suspension pcra K1200LT 3 Jan 4th, 2006 12:40 am
