Electrical issuet - BMW Luxury Touring Community
post #1 of 3 Old Aug 15th, 2013, 7:06 pm Thread Starter
Electrical issuet
I was installing a headlight modulator on my 1994 K 1100 Lt SE everything was working so I put the fairing back together and when I went to start the bike it turnred over then everything went Black. I tested the battery and it was totally gone 0 volt showing on meter. I check fuses on side and all are fine. Is there a master fuse some where else that might be gone? I recharged the battery over night and got it up to 10 volts and installed it but no response at all when I turned the key. I'm installing a new battery tomorrow.
ScottBMW2002 is offline
post #2 of 3 Old Aug 16th, 2013, 10:00 pm
Re: Electrical issuet
I think it is a coincidence that your battery failed just as you did that work and they are not related. If you went to 0 on the battery it has an open in it somewhere or a really dead cell. Charging it up to only 10 v over night and the fact you put it back in and got nothing is a sure sign it is dead. Time for a new one.
post #3 of 3 Old Oct 27th, 2013, 10:54 am Thread Starter
Problem solved. When I was installing modulator I unplugged the small parking light above the head light once I reconnected it problem solved.
Thanks for the input.
Scott
Electrical Noise Isolation on LT deputy5211 K1200LT 7 Aug 12th, 2012 7:40 pm
electrical gremlins oldtimer54 K1200LT 7 May 28th, 2012 11:51 pm
GPS causing complete electrical shutdown BMWCharlie GPS 6 Jun 10th, 2008 3:21 pm
Bussed Electrical System? 2wheeljunkie Batteries, Chargers, & Electrical 8 May 12th, 2008 6:04 pm
Electrical diagram advise, please pozo_izquierdo Batteries, Chargers, & Electrical 2 Nov 18th, 2006 9:49 am
