Compression on a k 75 - BMW Luxury Touring Community
post #1 of 2 Old Dec 20th, 2012, 1:55 pm Thread Starter
Did a comp check on my 87 k75 with cold motor and throttle closed all 3 cyl were 115 psi. I then warmed it up and checked with throttle open , all 3 were 190 psi. Just wondering if this seemed normal.
mwood7800 is offline
post #2 of 2 Old Dec 20th, 2012, 3:14 pm
lkchris's Avatar
Re: Compression on a k 75
It's the throttle position that made the difference.
Compression checks are supposed to be made with open throttle.
On an Airhead FWIW it's easiest just to take the carbs off.
Kent Christensen
Albuquerque
lkchris is offline
Low Compression in Cylinder 2 - Next Steps? sully2028 K1200LT 41 Apr 30th, 2014 1:15 pm
LD Comfort vs Compression Shorts Travman Rider's Gear & Luggage 15 Aug 14th, 2011 8:48 am
rear shocks with compression settings? johnT K1200LT 5 Feb 20th, 2011 7:13 am
Fuel Shutoff for Compression Test sully2028 K1200LT 3 May 24th, 2010 8:48 pm
Compression simoncharles K1200LT 9 Dec 11th, 2009 4:33 pm
