Pulled the wires out of my heated grip - BMW Luxury Touring Community
post #1 of 6 Old Jan 5th, 2012, 4:44 pm Thread Starter
I have a 1992 K75, I am completely new to BMW ownership. I love the bike. Just wanted to put lower bars on it. In beginning to tear things down, I pulled the left grip off. I did not know that the wires were routed inside the bars.
The wires seem to have pulled out of the grip, cleanly. I'm wondering if this can be repaired.
RedK75 is offline
post #2 of 6 Old Jan 5th, 2012, 4:52 pm
seahabit's Avatar
Re: Pulled the wires out of my heated grip
I once tore mine up using the same system as you. In my case, there was enough residual wire to solder and shrink tube. Are you able to get to the wire in the grip and is there any remaining portion to solder?
seahabit is offline
post #3 of 6 Old Jan 5th, 2012, 5:17 pm
Matt's Avatar
Same here on my LT.
What seahabit said.
Matt
95 Honda Magna (sold)
97 R1100RT (sold)
00 LTc, Canyon Red "Tarkus" (sold)
01 F650GS (wifey's, sold)
01 Ducati S4 Monster "LittleOne"
04 R1150RT (turned to scrap)
99 R1100RT Tundra Green
Kalamazoo, MI
"Worry does not rob tomorrow of it's sorrow. It saps the strength of today."
Matt is offline
post #4 of 6 Old Jan 5th, 2012, 5:26 pm Thread Starter
The wires pulled cleanly out of the grip. But, the connector is so far down in the grip, I don't know how I'd be able to reach it to re-connect or to solder it.
RedK75 is offline
post #5 of 6 Old Jan 5th, 2012, 6:24 pm
seahabit's Avatar
You'll most probably be buying a new one. It may be worth a try to cut off or drill out the other end to gain access for a better view. It does sound to be a lost cause, but it's worth a try.
seahabit is offline
post #6 of 6 Old Jan 5th, 2012, 7:11 pm
seahabit's Avatar
Do a "Search" using "cutting grips". The thread I followed was started by cccpastorjack. It was titled---- Replacing Grips
seahabit is offline
$7.00 Heated Grip Repair!! ridinredfox K1200LT 7 Jan 19th, 2012 7:56 pm
Heated right hand grip stays on after key is turned off. DanDiver K1200LT 11 Jan 28th, 2011 6:15 pm
Heated grip (singular) failure lemiller K1200LT 2 Sep 13th, 2009 12:00 pm
Need procedure for removing and replacing the COMPLETE heated grip Assembly wildwestrider K1200LT 6 Feb 11th, 2008 8:22 am
Performed successful surgery on my heated grip Toolman K1200LT 1 Apr 16th, 2006 7:12 pm
