1991 K100RS won't start????? - BMW Luxury Touring Community
post #1 of 4 Old Sep 23rd, 2011, 7:47 am Thread Starter
oilhead110's Avatar
I have a problem I hope someone can help with, I have a 1991 BMW K100RS 16V, when I attempt to start the bike, the starter turns over but the engine wonít start. While the starter is turning over the engine the headlight will flash on and off/flicker instead of staying off during the starting cycle. Any ideas?
DC
oilhead110 is offline
post #2 of 4 Old Oct 4th, 2011, 6:58 pm
haughty's Avatar
Re: 1991 K100RS won't start?????
This is where i go when i have a question on the bricks. Smart people just like here and you might get steered into the right direction. I cant say what exactly might be the problem.
Good luck.
Bmw k100 rt forum
They do the 1100s as well.
Mikey
Don't be afraid to say what you feel, as those that matter DOnt mind and those that mind Dont matter.
Dr.Suess-
1980 YAMAHA XJ650 MAXIM (RIP)
1982 YAMAHA 750 VIRAGO (SHES GONE)
1982 SUZUKI GS1000 (GONE)
2001 BMW K1200LT
2004 BMW R 1150 RT Sold.....
2007 BMW R 1200 GS
1986 BMW K100RT WITH A FLEXIT SIDECAR
1985 BMW K100 RT ( parts bike, but its too nice to do that, so it runs)
haughty is offline
post #3 of 4 Old Oct 4th, 2011, 9:13 pm
DC
The starter on the K100 is the grounding point for the Load shead relay in this system.
If you are having the lights come and go the load shead relay is not grounding properly. The first thing I would do is remove and clean the starter and fix the grounding problem this will probably cure your problem. The starter on the RS should easily accessed from the top. There are just two allen head bolts holding the starter in. One thing that could be happening is the bolts on the starter are loose which will cause the same problem.
Good Luck
Jim Davidson
2007 R1200RT
hp1bmw is offline
post #4 of 4 Old Dec 1st, 2011, 11:36 am
If the starter checks out fine it might be the relay.
moralem is offline
Rough Start (video)!! I need HELP...please!! BlauBeeMr K1200LT 46 Feb 9th, 2011 11:37 am
Another LT That Won't Start. Vegas9mm K1200LT 9 Jul 12th, 2010 1:26 pm
Finally finished a restoration of my old 1991 K100RS. oilhead110 Other K-Bikes Discussion 16 Feb 4th, 2009 2:16 pm
2003 LT a No Start Problem knlkern K1200LT 11 Aug 26th, 2008 9:00 pm
