Only starts in neutral - BMW Luxury Touring Community
post #1 of 5 Old Jul 4th, 2011, 10:33 pm Thread Starter
I have a 2005 k1200s. It will only start in neutral. I replaced the clutch lever switch and I thought that the problem was solved, then it started again only turning over and starting in neutral. I pulled the switch out and when you suppress the spring on the switch you can here it click. Any Ideas what my problem might be and how do I go about fixing it?
Thanks Carl
cw1200lt is offline
post #2 of 5 Old Jul 5th, 2011, 7:53 am
CohesiveTechnology's Avatar
Re: Only starts in neutral
It is very likely the side stand switch. Do not rely on the mechanical clicking sound. Instead get a DVM and measure the continuity across contacts when engaged.
Better yet, just replace it. If in doubt, swap it out.
David Falkenstein
Cohesive Technology - seamless is everything
P: (603) 283-7624
CohesiveTechnology is offline
post #3 of 5 Old Jul 5th, 2011, 8:17 am
ironbuttwannabe's Avatar
Might be cheaper,easier, and less hassle down the road to just bypass them all
Neil '00 K1200LT '08 KLR
"Far away, is far away...
Only if you don't go!!!"
ironbuttwannabe is offline
post #4 of 5 Old Jul 5th, 2011, 10:39 am
JPSpen's Avatar
Def, Def. Definately the side stand switch....
Or..
You were trying to start the bike with the side stand down...
91 R100GS "It'sNotAMoneyPit"
JPSpen is offline
post #5 of 5 Old Jul 6th, 2011, 8:01 pm Thread Starter
Thanks for all of your replies.As soon you mentioned the side stand switch I knew that was it, boy did I feel dumb. I had to replace one on my 2000 lt. That is the one of the greatest things about this forum. If you got a problem all you have to do is ask and there is plenty of help. Thanks for all your help.
Carl
cw1200lt is offline
Problem shifting out of neutral to first c_ford K1200LT 16 Aug 28th, 2011 8:22 pm
R1100RT starts ok but sputters and stalls even with choke Hydrilla RT Series 8 Sep 15th, 2009 9:32 am
2004 R1150rtp Knocking In Neutral Sometimes ska987 RT Series 5 Jun 6th, 2009 12:45 pm
What word starts with an 'F' and ends in 'K' ? hagar Humor 0 Dec 9th, 2006 3:13 pm
What starts with F and ends with K? KeithTxDallas Humor 0 Nov 30th, 2006 6:26 pm
