Exhaust Smoke - BMW Luxury Touring Community
post #1 of 4 Old Sep 2nd, 2010, 5:26 pm Thread Starter
Exhaust Smoke
I have a 1985 K100 RT (have had it 3 years and have put on over 30,000 miles no other problems) and recently (2500 miles ago) instead of using a BMW brand oil filter, I used a HiFlo filter (part 14-0163, oil used Castrol, 10W-40 and I change oil and filter every 3,000 miles). Now at time of start up the bike is smoking more than when I was using a BMW filter. Fortunately, after a few minutes the smoke goes away. Has anyone else had this problem with a HiFlo filter and what can be done to reduce startup exhaust smoke (when I use my side I put a block under stand arm). I have heard that a BMW filter has a check valve to prevent this is this true? Advice would be appreciated.
hfsmall is offline
post #2 of 4 Old Sep 2nd, 2010, 7:33 pm
BMW Guru
Ted Shred's Avatar
Re: Exhaust Smoke
That's pretty common for the flying brick motor if left on the side stand. Have you always used the center stand?
__________
2016 R1200GS Adventure
2006 DRZ400E
2007 G650 X Challenge
2006 GT200
2005 R1200GS
Ted Shred is offline
post #3 of 4 Old Sep 2nd, 2010, 8:12 pm
Re: Exhaust Smoke
Happens-sporadically-with my 91K75, 93K1100 and 2003 K12lt. Helps minimize the risk of Nile virus here in the upper Rio Grande Valley.
ljjohns is offline
post #4 of 4 Old Oct 30th, 2010, 2:31 pm
beech's Avatar
Re: Exhaust Smoke
OEM filters, if they are too expensive for you mail order them.
Beech
beech is offline
Valve seals and smoke ? CharlieVT K1200LT 16 Jul 2nd, 2010 10:31 am
Cracked exhaust and vibration bowlesj K1200LT 2 Aug 4th, 2009 11:48 am
Exhaust systems question. Dick K1200LT 9 Apr 15th, 2008 8:48 am
'07 R1200RT exhaust upgrade switz RT Series 3 Mar 11th, 2008 6:34 pm
