A K1200RS FD failure - BMW Luxury Touring Community
post #1 of 2 Old Jul 13th, 2010, 5:24 pm Thread Starter
CharlieVT's Avatar
Pics posted for owner of the drive and others who might be interested
Bike is a 2001 K1200RS with 45K miles on it.
Owner noticed roughness, no oil leak.
(would have been leaking very soon.)
Addendum:
Calculations for new bearing done.
Original shimming was (0.40+0.50mm)= 0.90mm
My calculations (excel spreadsheet attached) yielded recommended shim thickness of 0.55mm using both DMAN's dial indicator method and the BMW service manual depth micrometer method. That would suggest that this FD that failed at 45Kmiles was overshimmed by (0.90-0.55)=0.35mm
Name:	K1200RS bearing 003.jpg
ID:	28123   Click image for larger version
Name:	K1200RS bearing 005.jpg
ID:	28124   Click image for larger version
Name:	K1200RS bearing 006.jpg
ID:	28125   Click image for larger version
Name:	K1200RS bearing 008.jpg
CharlieVT is offline
post #2 of 2 Old Jul 14th, 2010, 10:17 pm
Guest
11862's Avatar
Re: A K1200RS FD failure
Curtis - I had not seen that posting. Interesting how much discrepancy between the BMW Book recommendation & the actual, and how your method came out the same as the recommended method. That bearing is so much toast that there probably isn't anything to be learned from it.
I've been trying to think of a way that the axial deflection of the hub could be measured under a thrust load. The thrust could be applied by a fixture supporting the case, & using a non-rotating drill press & a torque wrench on the drill press handle. The deflection could be measured with a dial indicator & an appropriate zero stress fixture to hold the dial indicator with respect to the housing. Sort of like you have now.
I would expect that the line of contact between the races and the balls shifts quite radically as the preload force is applied. Too low a preload = lot of deflection, & very little preload = not much deflection. It might make a way that the preload could be approximated on an assembled unit. This would allow a more direct measurement of preload than the present assembly method which is probably sensitive to things such as shaft diameters etc.
It would be necessary to both push as well as pull on the hub measuring hub-to-housing deflection. I would expect a force of maybe 500 lbs would be necessary.
Of course the tapered roller bearing would also enter into any deflection vs load measurement, but I suspect the line-of-action of the tapered roller bearing remains very consistent.
11862 is offline
Final Drive failure - no BMW warranty support BobbyLT K1200LT 28 Aug 21st, 2014 3:14 pm
Final Drive Failure (Warning Light System) Tourdog K1200LT 26 Nov 3rd, 2008 8:02 pm
Questions: What is final drive failure and clutch slave failure? hip001 K1200LT 9 Jan 30th, 2008 11:41 am
Final Drive Failures at 4% rate? hallzee K1200LT 27 Nov 24th, 2007 3:49 pm
Bridgestone BT020R 160/70R-17 tire failure. mudman Tires 23 Aug 28th, 2006 2:36 am
